Seggr
- May 16, 2016
My New Build:
SUPERMICRO 846E1-R900B CSE-846
X8DTE-F,
2x L5520,
64GB RAM,
24x 3TB SAS,
Chelsio 10GB 2-Port PCI-e OPT Adapter Card 110-1088-30
MegaRAID SAS 9240-8i (Flashed to 9211 IT mode)
2x 8GB USB Thumb drives
FreeNAS-9.10-STABLE-201605021851
Preface:
Please point something out plainly if you feel I have missed something obvious, my ego would rather just fix this.
I kinda resolved an issue I have/had with booting from USB devices, I was unable to boot to USB devices at all until I disabled the Optional ROM for all of the slots other than the SAS Controller.
Now I can boot to them but ONLY AFTER I attempt to boot them, get an error about no operating system found, reseat the thumb drives, see the message "GRUB", and reset then system. I have to repeat this process when ever I reboot atm.
Problems:
During Boot-up I see the following errors:
(These would leave me to believe this is a driver issue.)
All of 24 of the drives are showing as having 600.00MB/s throughput.
(This would leave me to believe this is a drive issue.)
I am unable to wipe the drives I get the a permissions error.
I've attempted to run the following command after reading some old posts to no avail.
X8DTE-F,
2x L5520,
64GB RAM,
24x 3TB SAS,
Preface:
Problems:
(da0:mps0:0:8:0): READ(16). CDB: 88 00 00 00 00 01 5d 50 a3 71 00 00 00 04 00 00
(da0:mps0:0:8:0): CAM status: SCSI Status Error
(da0:mps0:0:8:0): SCSI status: Check Condition
(da0:mps0:0:8:0): SCSI sense: ILLEGAL REQUEST asc:20,0 (Invalid command operation code)
(da0:mps0:0:8:0): Field Replaceable Unit: 0
(da0:mps0:0:8:0): Descriptor 0x80: 00 00 05 20 00 00 ff ff ff ff ff ff 00 00
(da0:mps0:0:8:0): Error 22, Unretryable error
(da0:mps0:0:8:0): READ(16). CDB: 88 00 00 00 00 01 5d 50 a3 af 00 00 00 01 00 00
(da0:mps0:0:8:0): READ(16). CDB: 88 00 00 00 00 01 5d 50 a3 ae 00 00 00 01 00 00
dd if=/dev/zero of=/dev/da0 bs=512 count=1
1+0 records in
1+0 records out
512 bytes transferred in 1.689685 secs (303 bytes/sec)
(SCSI Errors Followed.)1+0 records in
1+0 records out
Here are some command results to maybe shed some light on this...LSI Corporation SAS2 IR Configuration Utility.
Version 20.00.00.00 (2014.09.18)
Copyright (c) 2008-2014 LSI Corporation. All rights reserved.
Read configuration has been initiated for controller 0
Controller information
Controller type : SAS2008
BIOS version : 7.39.02.00
Firmware version : 20.00.07.00
Channel description : 1 Serial Attached SCSI
Initiator ID : 0
Maximum physical devices : 255
Concurrent commands supported : 3432
Slot : 6
Segment : 0
Bus : 8
Device : 0
Function : 0
RAID Support : No
IR Volume information
Physical device information
Initiator at ID #0
Device is a Hard disk
Enclosure # : 2
Slot # : 0
SAS Address : 5000c50-0-83e3-0fc5
State : Ready (RDY)
Size (in MB)/(in sectors) : 2861588/5860533167
Manufacturer : IBM-ESXS
Model Number : ST3000NM0023
Firmware Revision : BC5E
Serial No : Z1Z9201A0211BC5E
GUID : N/A
Protocol : SAS
Drive Type : SAS_HDD
Initiator ID : 0
Slot : 6
Segment : 0
Bus : 8
Device : 0
Function : 0
RAID Support : No
Initiator at ID #0
Enclosure # : 2
Slot # : 0
State : Ready (RDY)
GUID : N/A
Protocol : SAS
