Simond
- Sep 18, 2015
I need help to diagnose a problem on a FreeNas 9.3 server.
When I scrub the volume, drive becomes faulty randomly ; when I reboot or replace it, it comes back online.
I made short and long smart tests, all completed successfully.
I tried to group relevant informations below.
Do you have an idea why scrub makes a drive faulty so often ?
Do you think desactivate SSD for Logs and Cache could help ?
Thanks
Simon
Thanks
Simon
first scrub : NAME STATE READ WRITE CKSUM gptid/72b34089-3454-11e5-9824-001e67c53f64 FAULTED 6 47 0 too many errors this id corresponds to the disk da5 with serial number WD-WX71DA4A07DF I replaced it, it resilvered it successfully second scrub : gptid/caaae6e2-3534-11e5-9824-001e67c53f64 FAULTED 3 43 0 too many errors da11 WD-WXM1H84ADTNV reboot -> resilvered -> ok third scrub : (only time scrub finished without faulty drive but with one CheckSum error) gptid/caaae6e2-3534-11e5-9824-001e67c53f64 ONLINE 0 0 1 da11 WD-WXM1H84ADTNV fourth scrub : around 41.24 % it declared a faulty drive, I interrupted it gptid/74b62efe-3454-11e5-9824-001e67c53f64 FAULTED 3 39 0 too many errors da8 WD-WX21DB41SD3H replace with the first supposedly faulty drive ( WD-WX71DA4A07DF ) -> resilvered -> ok fifth scrub : around 5.83 % it declared a faulty drive, I interrupted it gptid/73b902ef-3454-11e5-9824-001e67c53f64 FAULTED 3 43 0 too many errors da6 WD-WX11D15P361L reboot -> resilvered -> ok
Server 2U intel R2000GZ
Build FreeNAS-9.3-STABLE-201506292332
Platform Intel(R) Xeon(R) CPU E5-2609 v2 @ 2.50GHz
Memory 98199MB
Disk 12 x WD Red 6TB NAS SATA 6 Gb/s 64MB Cache 3.5 Inch
2 x 60GB SSD for Logs and CacheCode:
result of "zpool status data" (when there isn't error) : pool: data state: ONLINE scan: resilvered 6.55M in 0h36m with 0 errors on Fri Nov 13 10:42:04 2015 config: NAME STATE READ WRITE CKSUM data ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/6fc9b15b-3454-11e5-9824-001e67c53f64 ONLINE 0 0 0 gptid/cb682217-36d4-11e5-9824-001e67c53f64 ONLINE 0 0 0 gptid/70c28b41-3454-11e5-9824-001e67c53f64 ONLINE 0 0 0 gptid/713e6970-3454-11e5-9824-001e67c53f64 ONLINE 0 0 0 gptid/71b9f04f-3454-11e5-9824-001e67c53f64 ONLINE 0 0 0 gptid/72366cfb-3454-11e5-9824-001e67c53f64 ONLINE 0 0 0 gptid/e4958922-7991-11e5-af7a-001e67c53f64 ONLINE 0 0 0 gptid/7337ab74-3454-11e5-9824-001e67c53f64 ONLINE 0 0 0 gptid/73b902ef-3454-11e5-9824-001e67c53f64 ONLINE 0 0 0 gptid/caaae6e2-3534-11e5-9824-001e67c53f64 ONLINE 0 0 0 gptid/ef5ab67c-8955-11e5-a182-001e67c53f64 ONLINE 0 0 0 gptid/752e1552-3454-11e5-9824-001e67c53f64 ONLINE 0 0 0 logs gptid/6861928a-3455-11e5-9824-001e67c53f64 ONLINE 0 0 0 cache gptid/a964d2da-3455-11e5-9824-001e67c53f64 ONLINE 0 0 0 errors: No known data errors
# df -h Filesystem Size Used Avail Capacity Mounted on freenas-boot/ROOT/default 7G 508M 6.5G 7% / devfs 1.0k 1.0k 0B 100% /dev tmpfs 32M 5.3M 26M 16% /etc tmpfs 4.0M 8.0k 4M 0% /mnt tmpfs 32G 16M 32G 0% /var freenas-boot/grub 6.5G 6.8M 6.5G 0% /boot/grub data 30T 219k 30T 0% /mnt/data data/data 30T 95G 30T 0% /mnt/data/data data/jails 30T 219k 30T 0% /mnt/data/jails data/simon 47T 17T 30T 36% /mnt/data/simon data/.system 30T 314M 30T 0% /var/db/system data/.system/cores 30T 4.6M 30T 0% /var/db/system/cores data/.system/samba4 30T 868k 30T 0% /var/db/system/samba4 data/.system/syslog-f1ae6c68bbe041c7bb38cadeec088781 30T 4M 30T 0% /var/db/system/syslog-f1ae6c68bbe041c7bb38cadeec088781 data/.system/rrd-f1ae6c68bbe041c7bb38cadeec088781 30T 46M 30T 0% /var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781 data/.system/configs-f1ae6c68bbe041c7bb38cadeec088781 30T 219k 30T 0% /var/db/system/configs-f1ae6c68bbe041c7bb38cadeec088781
# zpool list NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT data 65T 22.6T 42.4T - 21% 34% 1.00x ONLINE /mnt freenas-boot 7.50G 786M 6.73G - - 10% 1.00x ONLINE -
# zfs list NAME USED AVAIL REFER MOUNTPOINT data 17.2T 30.7T 219K /mnt/data data/.system 371M 30.7T 314M legacy data/.system/configs-f1ae6c68bbe041c7bb38cadeec088781 219K 30.7T 219K legacy data/.system/cores 4.62M 30.7T 4.62M legacy data/.system/rrd-f1ae6c68bbe041c7bb38cadeec088781 46.8M 30.7T 46.8M legacy data/.system/samba4 868K 30.7T 868K legacy data/.system/syslog-f1ae6c68bbe041c7bb38cadeec088781 3.95M 30.7T 3.95M legacy data/data 96.1G 30.7T 95.0G /mnt/data/data data/jails 219K 30.7T 219K /mnt/data/jails data/simon 17.1T 30.7T 17.1T /mnt/data/simon freenas-boot 786M 6.50G 31K none freenas-boot/ROOT 770M 6.50G 25K none freenas-boot/ROOT/FreeNAS-9.3-STABLE-201509160044 254M 6.50G 511M / freenas-boot/ROOT/Initial-Install 1K 6.50G 508M legacy freenas-boot/ROOT/Wizard-2015-07-24_16:44:30 440K 6.50G 508M legacy freenas-boot/ROOT/default 515M 6.50G 509M / freenas-boot/grub 13.6M 6.50G 6.79M legacy
# camcontrol devlist <TOSHIBA THNSNJ060GCSU JUGA0101> at scbus0 target 0 lun 0 (pass0,ada0) <TOSHIBA THNSNJ060GCSU JUGA0101> at scbus1 target 0 lun 0 (pass1,ada1) <ATA WDC WD60EFRX-68T 0A82> at scbus6 target 0 lun 0 (pass2,da0) <ATA WDC WD60EFRX-68T 0A82> at scbus6 target 3 lun 0 (pass3,da1) <ATA WDC WD60EFRX-68T 0A82> at scbus6 target 4 lun 0 (pass4,da2) <ATA WDC WD60EFRX-68T 0A82> at scbus6 target 5 lun 0 (pass5,da3) <ATA WDC WD60EFRX-68T 0A82> at scbus6 target 6 lun 0 (pass6,da4) <ATA WDC WD60EFRX-68T 0A82> at scbus6 target 7 lun 0 (pass7,da5) <ATA WDC WD60EFRX-68T 0A82> at scbus6 target 8 lun 0 (pass8,da6) <ATA WDC WD60EFRX-68T 0A82> at scbus6 target 9 lun 0 (pass9,da7) <ATA WDC WD60EFRX-68T 0A82> at scbus6 target 10 lun 0 (pass10,da8) <ATA WDC WD60EFRX-68T 0A82> at scbus6 target 13 lun 0 (pass11,da9) <ATA WDC WD60EFRX-68M 0A82> at scbus6 target 14 lun 0 (pass12,da10) <ATA WDC WD60EFRX-68M 0A82> at scbus6 target 15 lun 0 (pass13,da11) <USB Flash DISK 1100> at scbus8 target 0 lun 0 (pass14,da12)
# dmesg aesni0: <AES-CBC,AES-XTS> on motherboard padlock0: No ACE support. acpi0: <INTEL S2600GZ> on motherboard acpi0: Power Button (fixed) acpi0: reservation of 0, 9d000 (3) failed cpu0: <ACPI CPU> on acpi0 cpu1: <ACPI CPU> on acpi0 cpu2: <ACPI CPU> on acpi0 cpu3: <ACPI CPU> on acpi0 cpu4: <ACPI CPU> on acpi0 cpu5: <ACPI CPU> on acpi0 cpu6: <ACPI CPU> on acpi0 cpu7: <ACPI CPU> on acpi0 hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 Timecounter "HPET" frequency 14318180 Hz quality 950 Event timer "HPET" frequency 14318180 Hz quality 550 atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0 atrtc0: Warning: Couldn't map I/O. Event timer "RTC" frequency 32768 Hz quality 0 attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0 Timecounter "i8254" frequency 1193182 Hz quality 0 Event timer "i8254" frequency 1193182 Hz quality 100 Timecounter "ACPI-fast" frequency 3579545 Hz quality 900 acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0 pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 pci0: <ACPI PCI bus> on pcib0 pcib1: <ACPI PCI-PCI bridge> irq 47 at device 1.0 on pci0 pci1: <ACPI PCI bus> on pcib1 pcib2: <ACPI PCI-PCI bridge> irq 47 at device 1.1 on pci0 pci2: <ACPI PCI bus> on pcib2 igb0: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0x1060-0x107f mem 0xd0960000-0xd097ffff,0xd09b0000-0xd09b3fff irq 27 at device 0.0 on pci2 igb0: Using MSIX interrupts with 9 vectors igb0: Ethernet address: 00:1e:67:c5:3f:64 igb0: Bound queue 0 to cpu 0 igb0: Bound queue 1 to cpu 1 igb0: Bound queue 2 to cpu 2 igb0: Bound queue 3 to cpu 3 igb0: Bound queue 4 to cpu 4 igb0: Bound queue 5 to cpu 5 igb0: Bound queue 6 to cpu 6 igb0: Bound queue 7 to cpu 7 igb1: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0x1040-0x105f mem 0xd0940000-0xd095ffff,0xd09a0000-0xd09a3fff irq 30 at device 0.1 on pci2 igb1: Using MSIX interrupts with 9 vectors igb1: Ethernet address: 00:1e:67:c5:3f:65 igb1: Bound queue 0 to cpu 0 igb1: Bound queue 1 to cpu 1 igb1: Bound queue 2 to cpu 2 igb1: Bound queue 3 to cpu 3 igb1: Bound queue 4 to cpu 4 igb1: Bound queue 5 to cpu 5 igb1: Bound queue 6 to cpu 6 igb1: Bound queue 7 to cpu 7 igb2: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0x1020-0x103f mem 0xd0920000-0xd093ffff,0xd0990000-0xd0993fff irq 28 at device 0.2 on pci2 igb2: Using MSIX interrupts with 9 vectors igb2: Ethernet address: 00:1e:67:c5:3f:66 igb2: Bound queue 0 to cpu 0 igb2: Bound queue 1 to cpu 1 igb2: Bound queue 2 to cpu 2 igb2: Bound queue 3 to cpu 3 igb2: Bound queue 4 to cpu 4 igb2: Bound queue 5 to cpu 5 igb2: Bound queue 6 to cpu 6 igb2: Bound queue 7 to cpu 7 igb3: <Intel(R) PRO/1000 Network Connection version - 2.4.0> port 0x1000-0x101f mem 0xd0900000-0xd091ffff,0xd0980000-0xd0983fff irq 29 at device 0.3 on pci2 igb3: Using MSIX interrupts with 9 vectors igb3: Ethernet address: 00:1e:67:c5:3f:67 igb3: Bound queue 0 to cpu 0 igb3: Bound queue 1 to cpu 1 igb3: Bound queue 2 to cpu 2 igb3: Bound queue 3 to cpu 3 igb3: Bound queue 4 to cpu 4 igb3: Bound queue 5 to cpu 5 igb3: Bound queue 6 to cpu 6 igb3: Bound queue 7 to cpu 7 pcib3: <ACPI PCI-PCI bridge> irq 47 at device 2.0 on pci0 pci4: <ACPI PCI bus> on pcib3 pcib4: <ACPI PCI-PCI bridge> irq 47 at device 2.2 on pci0 pci5: <ACPI PCI bus> on pcib4 pcib5: <ACPI PCI-PCI bridge> irq 16 at device 3.0 on pci0 pci6: <ACPI PCI bus> on pcib5 pcib6: <ACPI PCI-PCI bridge> irq 16 at device 3.2 on pci0 pci7: <ACPI PCI bus> on pcib6 pcib7: <ACPI PCI-PCI bridge> irq 16 at device 17.0 on pci0 pci8: <ACPI PCI bus> on pcib7 pci0: <simple comms> at device 22.0 (no driver attached) pci0: <simple comms> at device 22.1 (no driver attached) ehci0: <EHCI (generic) USB 2.0 controller> mem 0xd0b20000-0xd0b203ff irq 22 at device 26.0 on pci0 usbus0: EHCI version 1.0 usbus0 on ehci0 pcib8: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0 pci9: <ACPI PCI bus> on pcib8 pcib9: <ACPI PCI-PCI bridge> irq 19 at device 28.7 on pci0 pci10: <ACPI PCI bus> on pcib9 vgapci0: <VGA-compatible display> mem 0xea000000-0xeaffffff,0xd0810000-0xd0813fff,0xd0000000-0xd07fffff irq 19 at device 0.0 on pci10 vgapci0: Boot video device ehci1: <EHCI (generic) USB 2.0 controller> mem 0xd0b10000-0xd0b103ff irq 20 at device 29.0 on pci0 usbus1: EHCI version 1.0 usbus1 on ehci1 pcib10: <ACPI PCI-PCI bridge> at device 30.0 on pci0 pci11: <ACPI PCI bus> on pcib10 isab0: <PCI-ISA bridge> at device 31.0 on pci0 isa0: <ISA bus> on isab0 ahci0: <Intel Patsburg AHCI SATA controller> port 0x2070-0x2077,0x2060-0x2063,0x2050-0x2057,0x2040-0x2043,0x2020-0x203f mem 0xd0b00000-0xd0b007ff irq 21 at device 31.2 on pci0 ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported ahcich0: <AHCI channel> at channel 0 on ahci0 ahcich1: <AHCI channel> at channel 1 on ahci0 ahcich2: <AHCI channel> at channel 2 on ahci0 ahcich3: <AHCI channel> at channel 3 on ahci0 ahcich4: <AHCI channel> at channel 4 on ahci0 ahcich5: <AHCI channel> at channel 5 on ahci0 pcib11: <ACPI Host-PCI bridge> on acpi0 pci128: <ACPI PCI bus> on pcib11 pcib12: <ACPI PCI-PCI bridge> irq 71 at device 1.0 on pci128 pci129: <ACPI PCI bus> on pcib12 pcib13: <ACPI PCI-PCI bridge> irq 71 at device 2.0 on pci128 pci130: <ACPI PCI bus> on pcib13 mps0: <LSI SAS2116> port 0xc000-0xc0ff mem 0xec280000-0xec283fff,0xec240000-0xec27ffff irq 56 at device 0.0 on pci130 mps0: Firmware: 16.00.00.00, Driver: 16.00.00.00-fbsd mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc> pcib14: <ACPI PCI-PCI bridge> irq 71 at device 2.2 on pci128 pci131: <ACPI PCI bus> on pcib14 pcib15: <ACPI PCI-PCI bridge> irq 71 at device 3.0 on pci128 pci132: <ACPI PCI bus> on pcib15 pcib16: <ACPI PCI-PCI bridge> irq 71 at device 3.2 on pci128 pci133: <ACPI PCI bus> on pcib16 acpi_button0: <Sleep Button> on acpi0 pcib17: <ACPI Host-PCI bridge> on acpi0 pci127: <ACPI PCI bus> on pcib17 pcib18: <ACPI Host-PCI bridge> on acpi0 pci255: <ACPI PCI bus> on pcib18 uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0 ichwd0 on isa0 ichwd0: ICH WDT present but disabled in BIOS or hardware device_attach: ichwd0 attach returned 6 ichwd0 at port 0x430-0x437,0x460-0x47f on isa0 ichwd0: ICH WDT present but disabled in BIOS or hardware device_attach: ichwd0 attach returned 6 orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xcdfff on isa0 sc0: <System console> at flags 0x100 on isa0 sc0: VGA <16 virtual consoles, flags=0x300> vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff coretemp0: <CPU On-Die Thermal Sensors> on cpu0 est0: <Enhanced SpeedStep Frequency Control> on cpu0 coretemp1: <CPU On-Die Thermal Sensors> on cpu1 est1: <Enhanced SpeedStep Frequency Control> on cpu1 coretemp2: <CPU On-Die Thermal Sensors> on cpu2 est2: <Enhanced SpeedStep Frequency Control> on cpu2 coretemp3: <CPU On-Die Thermal Sensors> on cpu3 est3: <Enhanced SpeedStep Frequency Control> on cpu3 coretemp4: <CPU On-Die Thermal Sensors> on cpu4 est4: <Enhanced SpeedStep Frequency Control> on cpu4 coretemp5: <CPU On-Die Thermal Sensors> on cpu5 est5: <Enhanced SpeedStep Frequency Control> on cpu5 coretemp6: <CPU On-Die Thermal Sensors> on cpu6 est6: <Enhanced SpeedStep Frequency Control> on cpu6 coretemp7: <CPU On-Die Thermal Sensors> on cpu7 est7: <Enhanced SpeedStep Frequency Control> on cpu7 ZFS filesystem version: 5 ZFS storage pool version: features support (5000) Timecounters tick every 1.000 msec ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled usbus0: 480Mbps High Speed USB v2.0 usbus1: 480Mbps High Speed USB v2.0 ugen0.1: <Intel> at usbus0 uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0 ugen1.1: <Intel> at usbus1 uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 uhub0: 2 ports with 2 removable, self powered uhub1: 2 ports with 2 removable, self powered ugen0.2: <vendor 0x8087> at usbus0 uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0 ugen1.2: <vendor 0x8087> at usbus1 uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1 uhub2: 6 ports with 6 removable, self powered uhub3: 8 ports with 8 removable, self powered ugen1.3: <Minicom Advanced System Ltd.> at usbus1 ukbd0: <Minicom Advanced System Ltd. USB keyboard and mouse device, class 0/0, rev 1.00/60.00, addr 3> on usbus1 kbd0 at ukbd0 ums0: <Minicom Advanced System Ltd. USB keyboard and mouse device, class 0/0, rev 1.00/60.00, addr 3> on usbus1 ums0: 8 buttons and [XYZ] coordinates ID=1 ums0: 8 buttons and [Z] coordinates ID=2 ugen1.4: <USB> at usbus1 umass0: <USB Flash DISK, class 0/0, rev 2.00/11.00, addr 4> on usbus1 umass0: SCSI over Bulk-Only; quirks = 0x4000 umass0:8:0:-1: Attached to scbus8 ugen1.5: <American Megatrends Inc.> at usbus1 ukbd1: <Keyboard Interface> on usbus1 kbd2 at ukbd1 ums1: <Mouse Interface> on usbus1 ums1: 3 buttons and [Z] coordinates ID=0 da0 at mps0 bus 0 scbus6 target 0 lun 0 da0: <ATA WDC WD60EFRX-68T 0A82> Fixed Direct Access SCSI-6 device da0: Serial Number WD-WX11D153XVEY da0: 600.000MB/s transfers da0: Command Queueing enabled da0: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da0: quirks=0x8<4K> da1 at mps0 bus 0 scbus6 target 3 lun 0 da1: <ATA WDC WD60EFRX-68T 0A82> Fixed Direct Access SCSI-6 device da1: Serial Number WD-WX21DC4D5ZFD da1: 600.000MB/s transfers da1: Command Queueing enabled da1: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da1: quirks=0x8<4K> da2 at mps0 bus 0 scbus6 target 4 lun 0 da2: <ATA WDC WD60EFRX-68T 0A82> Fixed Direct Access SCSI-6 device da2: Serial Number WD-WX31DC4CKVZ9 da2: 600.000MB/s transfers da2: Command Queueing enabled da2: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da2: quirks=0x8<4K> da3 at mps0 bus 0 scbus6 target 5 lun 0 da3: <ATA WDC WD60EFRX-68T 0A82> Fixed Direct Access SCSI-6 device da3: Serial Number WD-WX11DC449ZCP da3: 600.000MB/s transfers da3: Command Queueing enabled da3: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da3: quirks=0x8<4K> da4 at mps0 bus 0 scbus6 target 6 lun 0 da4: <ATA WDC WD60EFRX-68T 0A82> Fixed Direct Access SCSI-6 device da4: Serial Number WD-WX11DB4H89KR da4: 600.000MB/s transfers da4: Command Queueing enabled da4: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da4: quirks=0x8<4K> da5 at mps0 bus 0 scbus6 target 7 lun 0 da5: <ATA WDC WD60EFRX-68T 0A82> Fixed Direct Access SCSI-6 device da5: Serial Number WD-WX71DA4A07DF da5: 600.000MB/s transfers da5: Command Queueing enabled da5: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da5: quirks=0x8<4K> da6 at mps0 bus 0 scbus6 target 8 lun 0 da6: <ATA WDC WD60EFRX-68T 0A82> Fixed Direct Access SCSI-6 device da6: Serial Number WD-WX31DC46JSJY da6: 600.000MB/s transfers da6: Command Queueing enabled da6: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da6: quirks=0x8<4K> da7 at mps0 bus 0 scbus6 target 9 lun 0 da7: <ATA WDC WD60EFRX-68T 0A82> Fixed Direct Access SCSI-6 device da7: Serial Number WD-WX11D15P361L da7: 600.000MB/s transfers da7: Command Queueing enabled da7: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da7: quirks=0x8<4K> ada0 at ahcich0 bus 0 scbus0 target 0 lun 0 da8 at mps0 bus 0 scbus6 target 10 lun 0 da8: <ATA WDC WD60EFRX-68T 0A82> Fixed Direct Access SCSI-6 device da8: Serial Number WD-WX31DC4CKTU5 da8: 600.000MB/s transfers da8: Command Queueing enabled da8: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da8: quirks=0x8<4K> da9 at mps0 bus 0 scbus6 target 13 lun 0 da9: <ATA WDC WD60EFRX-68T 0A82> Fixed Direct Access SCSI-6 device da9: Serial Number WD-WX11DC4FK4HR da9: 600.000MB/s transfers da9: Command Queueing enabled da9: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da9: quirks=0x8<4K> da11 at mps0 bus 0 scbus6 target 15 lun 0 da11: <ATA WDC WD60EFRX-68M 0A82> Fixed Direct Access SCSI-6 device da11: Serial Number WD-WX81D65D9D8F da11: 600.000MB/s transfers da11: Command Queueing enabled da11: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da11: quirks=0x8<4K> da10 at mps0 bus 0 scbus6 target 14 lun 0 da10: <ATA WDC WD60EFRX-68M 0A82> Fixed Direct Access SCSI-6 device da10: Serial Number WD-WXM1H84ADTNV da10: 600.000MB/s transfers da10: Command Queueing enabled da10: 5723166MB (11721045168 512 byte sectors: 255H 63S/T 729601C) da10: quirks=0x8<4K> da12 at umass-sim0 bus 0 scbus8 target 0 lun 0 da12: <USB Flash DISK 1100> Removable Direct Access SCSI-4 device da12: Serial Number 1408032790000372 da12: 40.000MB/s transfers da12: 7728MB (15826944 512 byte sectors: 255H 63S/T 985C) da12: quirks=0x2<NO_6_BYTE> ada0: <TOSHIBA THNSNJ060GCSU JUGA0101> ATA-9 SATA 3.x device ada0: Serial Number 25JS107OT9PW ada0: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes) ada0: Command Queueing enabled ada0: 57241MB (117231408 512 byte sectors: 16H 63S/T 16383C) ada0: Previously was known as ad4 ada1 at ahcich1 bus 0 scbus1 target 0 lun 0 ada1: <TOSHIBA THNSNJ060GCSU JUGA0101> ATA-9 SATA 3.x device ada1: Serial Number 25JS107AT9PW ada1: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes) ada1: Command Queueing enabled ada1: 57241MB (117231408 512 byte sectors: 16H 63S/T 16383C) ada1: Previously was known as ad6 SMP: AP CPU #6 Launched! SMP: AP CPU #3 Launched! SMP: AP CPU #5 Launched! SMP: AP CPU #1 Launched! SMP: AP CPU #7 Launched! SMP: AP CPU #2 Launched! SMP: AP CPU #4 Launched! Swap zone entries reduced from 12196265 to 5420562. Timecounter "TSC-low" frequency 1247019324 Hz quality 1000 Trying to mount root from zfs:freenas-boot/ROOT/default []... GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) ichwd0 at port 0x430-0x437,0x460-0x47f on isa0 ichwd0: ICH WDT present but disabled in BIOS or hardware device_attach: ichwd0 attach returned 6 wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff GEOM_ELI: Device da0p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da8p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da1p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da2p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da3p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da4p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da11p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da6p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da7p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da10p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da5p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da9p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware vboxdrv: fAsync=0 offMin=0x35f offMax=0x7375 pid 2482 (syslog-ng), uid 0: exited on signal 6 (core dumped)
