, I upgraded, and now I don't see the error in the logs. But the message displayed in the browser is the same, it tells me to look at the webserver log. In case it helps, here's the caddy.log (copied the last few lines; they repeat quite a few times, I'm guessing since the upgrade).
{"level":"info","ts":1632549030.6529791,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/stop","remote_addr":"127.0.0.1:54657","headers":{"Accept-Encoding":["gzip"],"Content-Length":["0"],"Origin":["localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
{"level":"warn","ts":1632549030.653143,"logger":"admin.api","msg":"exiting; byeee!! "}
{"level":"info","ts":1632549030.653379,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0003705b0"}
{"level":"info","ts":1632549030.6547458,"logger":"admin","msg":"stopped previous server","address":"tcp/localhost:2019"}
{"level":"info","ts":1632549030.6548004,"logger":"admin.api","msg":"shutdown complete","exit_code":0}
{"level":"info","ts":1632549039.4043186,"msg":"using provided configuration","config_file":"/usr/local/www/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1632549039.4077785,"logger":"caddy.logging.encoders.single_field","msg":"the 'single_field' encoder is deprecated and will be removed soon!"}
{"level":"info","ts":1632549039.4083643,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["127.0.0.1:2019","localhost:2019","[::1]:2019"]}
{"level":"info","ts":1632549039.4085803,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
{"level":"info","ts":1632549039.4086554,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000508230"}
{"level":"info","ts":1632549039.4095757,"msg":"autosaved config (load with --resume flag)","file":"/var/db/caddy/config/caddy/autosave.json"}
{"level":"info","ts":1632549039.4095964,"msg":"serving initial configuration"}
{"level":"info","ts":1632549039.409691,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/db/caddy/data/caddy"}
{"level":"info","ts":1632549039.4097474,"logger":"tls","msg":"finished cleaning storage units"}
Successfully started Caddy (pid=30284) - Caddy is running in the background
{"level":"info","ts":1632549671.229789,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/stop","remote_addr":"127.0.0.1:19760","headers":{"Accept-Encoding":["gzip"],"Content-Length":["0"],"Origin":["localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
{"level":"warn","ts":1632549671.2298543,"logger":"admin.api","msg":"exiting; byeee!! "}
{"level":"info","ts":1632549671.2311752,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc000508230"}
{"level":"info","ts":1632549671.2325566,"logger":"admin","msg":"stopped previous server","address":"tcp/localhost:2019"}
{"level":"info","ts":1632549671.2326279,"logger":"admin.api","msg":"shutdown complete","exit_code":0}
{"level":"info","ts":1632549918.4919648,"msg":"using provided configuration","config_file":"/usr/local/www/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1632549918.5052853,"logger":"caddy.logging.encoders.single_field","msg":"the 'single_field' encoder is deprecated and will be removed soon!"}
{"level":"info","ts":1632549918.5129905,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1632549918.5132294,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
{"level":"info","ts":1632549918.513316,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00024a930"}
{"level":"info","ts":1632549918.5149682,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/db/caddy/data/caddy"}
{"level":"info","ts":1632549918.515049,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1632549918.5326812,"msg":"autosaved config (load with --resume flag)","file":"/var/db/caddy/config/caddy/autosave.json"}
{"level":"info","ts":1632549918.5327,"msg":"serving initial configuration"}
Successfully started Caddy (pid=2287) - Caddy is running in the background
I think perhaps my initial searches had lead me down the wrong path.
I assumed this was a caddy issue (since it told me to check webserver log), but disregarding that, I found a few similar issues. They mostly seem to relate to either (1) nextcloud config.php (e.g.
), (2) incompatible app (e.g.
; any idea how to remove everything onlyoffice from CLI?), or (3) something with permissions (but I haven't touched permissions inside the jail). But because of this, I thought it might be useful to share nextcloud logs from
{"reqId":"M8eDuChHRoYmIqqK5RPY","level":3,"time":"2021-06-15T20:40:40+00:00","remoteAddr":"","user":"admin","app":"no app in context","method":"","url":"--","message":{"Exception":"OCP\\AppFramework\\QueryException","Message":"Could not resolve trashManager! Class trashManager does not exist","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":126,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["trashManager"]},{"file":"/usr/local/www/nextcloud/lib/private/ServerContainer.php","line":162,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["trashManager",true]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":434,"function":"query","class":"OC\\ServerContainer","type":"->","args":["trashManager",true]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":56,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["trashManager"]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":58,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["trashManager"]},{"function":"OC\\AppFramework\\Bootstrap\\{closure}","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":68,"function":"array_map","args":[{"__class__":"Closure"},[{"name":"serverContainer","__class__":"ReflectionParameter"},{"name":"logger","__class__":"ReflectionParameter"},{"name":"appManager","__class__":"ReflectionParameter"},"*** sensitive parameter replaced ***"]]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":52,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->","args":[[{"__class__":"OCA\\Files_Trashbin\\AppInfo\\Application"},"registerTrashBackends"]]},{"file":"/usr/local/www/nextcloud/apps/files_trashbin/lib/AppInfo/Application.php","line":57,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->","args":[[{"__class__":"OCA\\Files_Trashbin\\AppInfo\\Application"},"registerTrashBackends"]]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":176,"function":"boot","class":"OCA\\Files_Trashbin\\AppInfo\\Application","type":"->","args":[{"__class__":"OC\\AppFramework\\Bootstrap\\BootContext"}]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_App.php","line":197,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":["files_trashbin"]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_App.php","line":137,"function":"loadApp","class":"OC_App","type":"::","args":["files_trashbin"]},{"file":"/usr/local/www/nextcloud/apps/dav/lib/AppInfo/Application.php","line":124,"function":"loadApps","class":"OC_App","type":"::","args":[["dav"]]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":176,"function":"boot","class":"OCA\\DAV\\AppInfo\\Application","type":"->","args":[{"__class__":"OC\\AppFramework\\Bootstrap\\BootContext"}]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_App.php","line":197,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":["dav"]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_App.php","line":137,"function":"loadApp","class":"OC_App","type":"::","args":["dav"]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_Util.php","line":203,"function":"loadApps","class":"OC_App","type":"::","args":[["filesystem"]]},{"file":"/usr/local/www/nextcloud/lib/private/User/Session.php","line":554,"function":"setupFS","class":"OC_Util","type":"::","args":["*** sensitive parameter replaced ***"]},{"file":"/usr/local/www/nextcloud/lib/private/User/Session.php","line":415,"function":"prepareUserLogin","class":"OC\\User\\Session","type":"->","args":[true,"*** sensitive parameter replaced ***"]},{"file":"/usr/local/www/nextcloud/lib/private/User/Session.php","line":624,"function":"completeLogin","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/lib/private/User/Session.php","line":367,"function":"loginWithPassword","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/lib/private/Setup.php","line":440,"function":"login","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/core/Command/Maintenance/Install.php","line":108,"function":"install","class":"OC\\Setup","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Install","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/usr/local/www/nextcloud/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/usr/local/www/nextcloud/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"OC\\Core\\Command\\Maintenance\\Install"},{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/usr/local/www/nextcloud/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/usr/local/www/nextcloud/lib/private/Console/Application.php","line":215,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/usr/local/www/nextcloud/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/occ","line":11,"args":["/usr/local/www/nextcloud/console.php"],"function":"require_once"}],"File":"/usr/local/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","Line":115,"CustomMessage":"Could not boot files_trashbinCould not resolve trashManager! Class trashManager does not exist"},"userAgent":"--","version":"21.0.2.1"}
{"reqId":"M8eDuChHRoYmIqqK5RPY","level":3,"time":"2021-06-15T20:40:40+00:00","remoteAddr":"","user":"admin","app":"no app in context","method":"","url":"--","message":{"Exception":"OCP\\AppFramework\\QueryException","Message":"Could not resolve OCA\\Files_Versions\\Versions\\IVersionManager! Class can not be instantiated","Code":0,"Trace":[{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":126,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Files_Versions\\Versions\\IVersionManager"]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":459,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Files_Versions\\Versions\\IVersionManager"]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":431,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Files_Versions\\Versions\\IVersionManager"]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":56,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Files_Versions\\Versions\\IVersionManager"]},{"file":"/usr/local/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php","line":121,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Files_Versions\\Versions\\IVersionManager"]},{"file":"/usr/local/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php","line":108,"function":"loadBackend","class":"OCA\\Files_Versions\\AppInfo\\Application","type":"->","args":[{"@attributes":{"for":"OCP\\Files\\Storage\\IStorage"},"@value":"OCA\\Files_Versions\\Versions\\LegacyVersionsBackend"},{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"__class__":"OC\\AppFramework\\Logger"}]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Bootstrap/FunctionInjector.php","line":68,"function":"registerVersionBackends","class":"OCA\\Files_Versions\\AppInfo\\Application","type":"->","args":[{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"__class__":"OC\\App\\AppManager"},{"__class__":"OC\\AppFramework\\Logger"}]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Bootstrap/BootContext.php","line":52,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\FunctionInjector","type":"->","args":[{"__class__":"Closure"}]},{"file":"/usr/local/www/nextcloud/apps/files_versions/lib/AppInfo/Application.php","line":93,"function":"injectFn","class":"OC\\AppFramework\\Bootstrap\\BootContext","type":"->","args":[{"__class__":"Closure"}]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":176,"function":"boot","class":"OCA\\Files_Versions\\AppInfo\\Application","type":"->","args":[{"__class__":"OC\\AppFramework\\Bootstrap\\BootContext"}]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_App.php","line":197,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":["files_versions"]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_App.php","line":137,"function":"loadApp","class":"OC_App","type":"::","args":["files_versions"]},{"file":"/usr/local/www/nextcloud/apps/dav/lib/AppInfo/Application.php","line":124,"function":"loadApps","class":"OC_App","type":"::","args":[["dav"]]},{"file":"/usr/local/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php","line":176,"function":"boot","class":"OCA\\DAV\\AppInfo\\Application","type":"->","args":[{"__class__":"OC\\AppFramework\\Bootstrap\\BootContext"}]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_App.php","line":197,"function":"bootApp","class":"OC\\AppFramework\\Bootstrap\\Coordinator","type":"->","args":["dav"]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_App.php","line":137,"function":"loadApp","class":"OC_App","type":"::","args":["dav"]},{"file":"/usr/local/www/nextcloud/lib/private/legacy/OC_Util.php","line":203,"function":"loadApps","class":"OC_App","type":"::","args":[["filesystem"]]},{"file":"/usr/local/www/nextcloud/lib/private/User/Session.php","line":554,"function":"setupFS","class":"OC_Util","type":"::","args":["*** sensitive parameter replaced ***"]},{"file":"/usr/local/www/nextcloud/lib/private/User/Session.php","line":415,"function":"prepareUserLogin","class":"OC\\User\\Session","type":"->","args":[true,"*** sensitive parameter replaced ***"]},{"file":"/usr/local/www/nextcloud/lib/private/User/Session.php","line":624,"function":"completeLogin","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/lib/private/User/Session.php","line":367,"function":"loginWithPassword","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/lib/private/Setup.php","line":440,"function":"login","class":"OC\\User\\Session","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/core/Command/Maintenance/Install.php","line":108,"function":"install","class":"OC\\Setup","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/usr/local/www/nextcloud/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OC\\Core\\Command\\Maintenance\\Install","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/usr/local/www/nextcloud/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/usr/local/www/nextcloud/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"OC\\Core\\Command\\Maintenance\\Install"},{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/usr/local/www/nextcloud/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/usr/local/www/nextcloud/lib/private/Console/Application.php","line":215,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/usr/local/www/nextcloud/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->","args":[]},{"file":"/usr/local/www/nextcloud/occ","line":11,"args":["/usr/local/www/nextcloud/console.php"],"function":"require_once"}],"File":"/usr/local/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","Line":111,"CustomMessage":"Could not boot files_versionsCould not resolve OCA\\Files_Versions\\Versions\\IVersionManager! Class can not be instantiated"},"userAgent":"--","version":"21.0.2.1"}
as well as my config.php (since this was what I edited when this all started; perhaps I missed something that I messed up?)
