- Aug 16, 2011
This sounds like another instance of the clusterf*ck that Let's Encrypt has caused (or at least highlighted) with their recent change in the certificate chain--which isn't helped by the fact that you're using an EOL OS. See:
Best answer is probably to download the "Root X1" certificate and install it on the client system(s) as a trusted root CA:
Or try getting the cert from ZeroSSL instead. Make this change in the Caddyfile to do that:
Change acme_ca to
DST Root CA X3 Expiration (September 2021)
Update Feb 05, 2024 It’s been two years, and the Android compatibility cross-sign mentioned below is close to expiring. See our recent blog post for a detailed explanation of the changes coming over the course of 2024. Update September 30, 2021 As planned, the DST Root CA X3 cross-sign has...
letsencrypt.org
Chains of Trust
This page describes all of the current and relevant historical Certification Authorities operated by Let’s Encrypt. Note that a CA is most correctly thought of as a key and a name: any given CA may be represented by multiple certificates which all contain the same Subject and Public Key...
letsencrypt.org
# debug
acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
email youremailhere
Change acme_ca to
https://acme.zerossl.com/v2/DV90, then restart Caddy.
