Has anyone had any luck setting this up behind a reverse proxy (I'm using Nginx proxy manager)? I've search the thread and found it referenced but no definitive answer.
I ran the script with NO_CERT using the nextcloud jail IP as the hostname, which worked and I could access nextcloud from the IP. With the proxy set up I either get a 'too many redirects' error, or a blank page loads. I think I need edit the caddy file but am unsure what is needed. Any help would be greatly appreciated.
Here is my config.php
and my caddyfile
<?php
$CONFIG = array (
  'passwordsalt' => 'abc123',
  'secret' => 'abc123',
  'trusted_domains' =>
  array (
    0 => 'localhost',
    1 => 'nextcloud local IP',
    2 => 'reverse proxy local IP',
    3 => 'cloud.fqdn.com',
  'datadirectory' => '/mnt/files',
  'dbtype' => 'mysql',
  'version' => '22.2.0.2',
  'overwrite.cli.url' => 'https://cloud.fqdn.com/',
  'forwarded_for_headers' => 'HTTP_X_FORWARDED_FOR',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost:/tmp/mysql.sock',
  'dbport' => '',
  'dbtableprefix' => 'oc_',
  'mysql.utf8mb4' => true,
  'dbuser' => 'nextcloud',
  'dbpassword' => 'abc123',
  'installed' => true,
  'instanceid' => 'ocwk5qcyzdxm',
  'logtimezone' => 'Europe/London',
  'default_phone_region' => 'GB',
  'log_type' => 'file',
  'logfile' => '/var/log/nextcloud/nextcloud.log',
  'loglevel' => '2',
  'logrotate_size' => '104847600',
  'memcache.local' => '\\OC\\Memcache\\APCu',
  'redis' =>
  array (
    'host' => '/var/run/redis/redis.sock',
    'port' => 0,
  'memcache.distributed' => '\\OC\\Memcache\\Redis',
  'memcache.locking' => '\\OC\\Memcache\\Redis',
  'overwritehost' => 'cloud.fqdn.com',
  'overwriteprotocol' => 'https',
  'overwriteconaddr' => 'reverse proxy local IP'
  'htaccess.RewriteBase' => '/',
  'trusted_proxies' => 'reverse proxy local IP',
  'updater.secret' => 'abc123.',
  'maintenance' => false,
  'theme' => '',
);and my caddyfile
    # debug
192.168.1.x:80 {
    root * /usr/local/www/nextcloud
    file_server
    log {
        output file /var/log/192.168.1.x.log
        format single_field common_log
    php_fastcgi 127.0.0.1:9000 {
        env front_controller_active true
    # client support (e.g. os x calendar / contacts)
    redir /.well-known/carddav /remote.php/dav 301
    redir /.well-known/caldav /remote.php/dav 301
    redir /.well-known/webfinger /index.php/.well-known/webfinger 301
    redir /.well-known/nodeinfo /index.php/.well-known/nodeinfo 301
    # .htaccess / data / config / ... shouldn't be accessible from outside
    @forbidden {
        path /.htaccess
        path /data/*
        path /config/*
        path /db_structure
        path /.xml
        path /README
        path /3rdparty/*
        path /lib/*
        path /templates/*
        path /occ
        path /console.php
    respond @forbidden 404
