Has anyone else notice that the nightlies after 21.04 the Apps wont load the ones you have installed. I just updated from a 3 or 4 weeks old nightly to TrueNAS-SCALE-21.05-MASTER-20210504-053713 and now I cants see any of my installed apps.
Cheer I noticed this too when I upgrade from 21.04 to check out a bug to see if it was resolved, but having my apps not working became a bigger issue.
Luckily my test environment has a replication of data so I just had to change nat pointers.
It is fixed on latest nightlies. BUT for now any apps that have submenus to open up from a checkbox (eg. Reverse proxy on truecharts) is not working.
That means, if you already have installed apps you will be ok. BUT you can't add new ones or edit your existing apps. because installer will check for values validity even if the checkbox is unchecked and it will fail.
You can stay on 21.04 release.
Nothing major in the nightlies. My box is just for testing, so I can spare it to catch some bugs and not worry if I can't access anything in it
My box was originally just for testing old AMD FX tower. But then Locast2plex stopped working on core about a month or so ago so I have the one on scale connected to the Core box and I also added xTeVe to scale to get IPTV on my Plex much cheaper than cable. Testing so far has been great docker containers for things I have VM's running on core will be a nice change. I'll be able to get rid of 2 of my vm's. Then I just need to figure out how to set up Nextcloud and connect a dataset to it. I haven't come across a good tutorial for it.
