Scale Apps have no external connection
roosey
After upgrading from nightly master builds to TrueNAS-SCALE-22.02.0.1.
Installed apps cannot connect outside my local network.
$ curl google.com
curl: (7) Failed to connect to google.com port 80: No route to host
I can ping external from a shell
ping google.com
PING google.com (142.251.33.110) 56(84) bytes of data.
64 bytes from sea30s10-in-f14.1e100.net (142.251.33.110): icmp_seq=1 ttl=118 time=30.1 ms
I could use some direction on how to troubleshoot this issue please.
Thanks
morganL
Captain Morgan
Administrator
It's usually either DNS, default gateway or a bridge configuration issue.
Either document or eliminate each.
roosey
I ended up reseting my configuration to default. The issue was that when I bound my Route v4 Interface NIC in Kubernetes Settings my connection takes a dump. Humm... it worked fine in beta
thatdrh
Did you ever find a solution? I just installed truenas scale on spare machine last week.. I have the same issue... on the apps page (availible applications) page, they dont load.. So I installed truenas on a virtual machine. There is no diffence in settings and it can load the apps page...
on my machine though, I can ping anywhere outside my network using shell, but it just can't see.. I double checked the DNS, I even tried other DNS...
