SOLVED Scale 21.04 apps not working
marmoset
Yesterday sometime after I updated to 21.04 I tried installing jellyfin and it didn't work (for some reason I don't remember/didn't research, only mentioning it in case it is relevant) and it looked like things got cleaned up afterwards.
I went back to try again today, and no apps show as available (no community or official).
I did docker ps, and there were only two containers running, but I didn't take note of which two.
I tried changing the pool for apps, thinking that might reset the state of whatever is messed up, but then no docker containers were running at all.
I rebooted, still the same, then I unset the pool for apps, rebooted again, and when I went to apps and was prompted to pick a pool, which I did, and now there's 3 containers running, but still no apps listed as available (refreshed multiple times).
Current running containers are:
root@truenas:~# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
fdb9779e1a63 rancher/pause:3.1 "/pause" 28 minutes ago Up 28 minutes k8s_POD_openebs-zfs-controller-0_kube-system_63bc78b6-6023-49c5-bca7-ef0fb5af9dae_2
bd380054d9dd rancher/pause:3.1 "/pause" 28 minutes ago Up 28 minutes k8s_POD_openebs-zfs-node-j7nt5_kube-system_565b7304-e067-4ba2-8bd8-d5ade9ab695d_0
606501c2f33c rancher/pause:3.1 "/pause" 29 minutes ago Up 29 minutes k8s_POD_coredns-854c77959c-g2jkm_kube-system_0b092553-99d1-42c4-9e89-b8c80206f474_0
root@truenas:~#
Any suggestions about where to look for what's wrong? I've never had any apps running so there's nothing to try and salvage or anything like that.
Thanks!
waqarahmed
@marmoset can you please email me a debug of your system at waqar at the rate of ixsystems.com. ( Debug can be retrieved via System Settings -> Advanced -> Save Debug ). Looking forward to hearing from you. Thank you
