impovich
- May 12, 2021
Hi all, a few weeks ago I noticed spam in logs that a container removal is failed due to a missing dataset, could you suggest what I can do about it?
logs:
truenas# docker ps -a CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES d39f9d831680 openebs/zfs-driver "/usr/local/bin/zfs-…" 4 weeks ago Removal In Progress k8s_openebs-zfs-plugin_openebs-zfs-node-ds5sd_kube-system_d692ac39-ac25-4da6-adbb-93615d9cef3b_203 4f7053116229 rancher/pause:3.1 "/pause" 4 weeks ago Exited (255) 4 weeks ago k8s_POD_openebs-zfs-node-ds5sd_kube-system_d692ac39-ac25-4da6-adbb-93615d9cef3b_27
truenas# k get pods -A NAMESPACE NAME READY STATUS RESTARTS AGE kube-system openebs-zfs-node-ds5sd 0/2 Terminating 315 106d kube-system coredns-7448499f4d-hmsv9 1/1 Running 0 8h kube-system openebs-zfs-controller-0 5/5 Running 0 8h
logs:
Oct 27 01:36:10 truenas k3s[8629]: I1027 01:36:10.703743 8629 scope.go:111] "RemoveContainer" containerID="d39f9d83168090d640c8473d2311ec52be722e58951549aef32f187e59f90f8b" Oct 27 01:36:10 truenas dockerd[8071]: time="2021-10-27T01:36:10.739172443+02:00" level=error msg="Error removing mounted layer d39f9d83168090d640c8473d2311ec52be722e58951549aef32f187e59f90f8b: exit status 1: \"/usr/sbin/zfs fs destroy -r storage_404/ix-applications/docker/3114cdddca0eb01f1de848925eba4d027796b424b91f12d843673e174667bd24\" => cannot open 'storage_404/ix-applications/docker/3114cdddca0eb01f1de848925eba4d027796b424b91f12d843673e174667bd24': dataset does not exist\n" Oct 27 01:36:10 truenas dockerd[8071]: time="2021-10-27T01:36:10.739870694+02:00" level=error msg="Handler for DELETE /v1.41/containers/d39f9d83168090d640c8473d2311ec52be722e58951549aef32f187e59f90f8b returned error: container d39f9d83168090d640c8473d2311ec52be722e58951549aef32f187e59f90f8b: driver \"zfs\" failed to remove root filesystem: exit status 1: \"/usr/sbin/zfs fs destroy -r storage_404/ix-applications/docker/3114cdddca0eb01f1de848925eba4d027796b424b91f12d843673e174667bd24\" => cannot open 'storage_404/ix-applications/docker/3114cdddca0eb01f1de848925eba4d027796b424b91f12d843673e174667bd24': dataset does not exist\n" Oct 27 01:36:10 truenas k3s[8629]: E1027 01:36:10.740889 8629 remote_runtime.go:296] "RemoveContainer from runtime service failed" err="rpc error: code = Unknown desc = failed to remove container \"d39f9d83168090d640c8473d2311ec52be722e58951549aef32f187e59f90f8b\": Error response from daemon: container d39f9d83168090d640c8473d2311ec52be722e58951549aef32f187e59f90f8b: driver \"zfs\" failed to remove root filesystem: exit status 1: \"/usr/sbin/zfs fs destroy -r storage_404/ix-applications/docker/3114cdddca0eb01f1de848925eba4d027796b424b91f12d843673e174667bd24\" => cannot open 'storage_404/ix-applications/docker/3114cdddca0eb01f1de848925eba4d027796b424b91f12d843673e174667bd24': dataset does not exist" containerID="d39f9d83168090d640c8473d2311ec52be722e58951549aef32f187e59f90f8b" Oct 27 01:36:10 truenas k3s[8629]: E1027 01:36:10.741271 8629 kuberuntime_gc.go:146] "Failed to remove container" err="rpc error: code = Unknown desc = failed to remove container \"d39f9d83168090d640c8473d2311ec52be722e58951549aef32f187e59f90f8b\": Error response from daemon: container d39f9d83168090d640c8473d2311ec52be722e58951549aef32f187e59f90f8b: driver \"zfs\" failed to remove root filesystem: exit status 1: \"/usr/sbin/zfs fs destroy -r storage_404/ix-applications/docker/3114cdddca0eb01f1de848925eba4d027796b424b91f12d843673e174667bd24\" => cannot open 'storage_404/ix-applications/docker/3114cdddca0eb01f1de848925eba4d027796b424b91f12d843673e174667bd24': dataset does not exist" containerID="d39f9d83168090d640c8473d2311ec52be722e58951549aef32f187e59f90f8b"
