Hello, I just update Truenas to TrueNAS-SCALE-22.12-RC.1 from TrueNAS-SCALE-22.12-BETA2.
The only application that don't want to start is Medusa.
I'm just a newbie, so anybody can help me ?!
Thanks ^^
Application Events :
Infos from Console :
Thanks ^^
2022-12-01 21:21:40 Startup probe failed: dial tcp 172.16.1.150:8081: connect: connection refused 2022-12-01 21:21:28 Started container medusa 2022-12-01 21:21:27 Started container prepare 2022-12-01 21:21:27 Container image "tccr.io/truecharts/medusa:1.0.9@sha256:a55234e59f4ace11d8f4d3a351f6b63612552a1593630debda4c893e89e439d4" already present on machine 2022-12-01 21:21:27 Created container medusa 2022-12-01 21:21:26 Add eth0 [172.16.1.150/16] from ix-net 2022-12-01 21:21:26 Container image "tccr.io/truecharts/ubuntu:jammy-20221101@sha256:4b9475e08c5180d4e7417dc6a18a26dcce7691e4311e5353dbb952645c5ff43f" already present on machine 2022-12-01 21:21:26 Created container prepare 2022-12-01 21:21:25 Scaled up replica set medusa-8586594845 to 1 2022-12-01 21:21:25 Created pod: medusa-8586594845-mjc48 2022-12-01 21:21:25 Successfully assigned ix-medusa/medusa-8586594845-mjc48 to ix-truenas 2022-12-01 21:21:13 Deleted pod: medusa-56ccf6cf65-xgcjr 2022-12-01 21:21:12 Job completed 2022-12-01 21:21:12 Scaled down replica set medusa-56ccf6cf65 to 0 from 1 2022-12-01 21:21:01 Started container medusa-manifests 2022-12-01 21:21:00 Created container medusa-manifests 2022-12-01 21:20:59 Add eth0 [172.16.1.149/16] from ix-net 2022-12-01 21:20:59 Container image "tccr.io/truecharts/ubuntu:jammy-20221101@sha256:4b9475e08c5180d4e7417dc6a18a26dcce7691e4311e5353dbb952645c5ff43f" already present on machine 2022-12-01 21:20:56 Created pod: medusa-manifests-ts6lj 2022-12-01 21:20:56 Successfully assigned ix-medusa/medusa-manifests-ts6lj to ix-truenas 2022-12-01 21:19:15 Startup probe failed: dial tcp 172.16.1.133:8081: connect: connection refused 2022-12-01 21:19:14 Created container medusa 2022-12-01 21:19:14 Started container medusa 2022-12-01 21:19:13 Container image "tccr.io/truecharts/medusa:1.0.9@sha256:a55234e59f4ace11d8f4d3a351f6b63612552a1593630debda4c893e89e439d4" already present on machine 2022-12-01 21:19:11 Container image "tccr.io/truecharts/ubuntu:jammy-20221101@sha256:4b9475e08c5180d4e7417dc6a18a26dcce7691e4311e5353dbb952645c5ff43f" already present on machine 2022-12-01 21:19:11 Created container prepare 2022-12-01 21:19:11 Started container prepare 2022-12-01 21:19:07 MountVolume.MountDevice failed for volume "pvc-da263a00-74a0-4d53-9e9c-4f3842680e7f" : kubernetes.io/csi: attacher.MountDevice failed to create newCsiDriverClient: driver name zfs.csi.openebs.io not found in the list of registered CSI drivers 2022-12-01 21:18:28 Add eth0 [172.16.1.133/16] from ix-net 2022-12-01 21:18:22 network is not ready: container runtime network not ready: NetworkReady=false reason:NetworkPluginNotReady message:docker: network plugin is not ready: cni config uninitialized 2022-12-01 21:18:09 AttachVolume.FindAttachablePluginBySpec failed for volume "pvc-da263a00-74a0-4d53-9e9c-4f3842680e7f" 2022-12-01 21:18:09 AttachVolume.FindAttachablePluginBySpec failed for volume "pvc-da263a00-74a0-4d53-9e9c-4f3842680e7f" 2022-12-01 21:18:06 Successfully assigned ix-medusa/medusa-56ccf6cf65-xgcjr to ix-truenas 2022-12-01 21:18:03 MountVolume.SetUp failed for volume "kube-api-access-sw6jj" : object "ix-medusa"/"kube-root-ca.crt" not registered 2022-12-01 21:18:03 MountVolume.MountDevice failed for volume "pvc-da263a00-74a0-4d53-9e9c-4f3842680e7f" : kubernetes.io/csi: attacher.MountDevice failed to create newCsiDriverClient: driver name zfs.csi.openebs.io not found in the list of registered CSI drivers 2022-12-01 21:18:02 Predicate TaintToleration failed 2022-12-01 21:18:02 error killing pod: failed to "KillPodSandbox" for "bb4ffc69-ed24-4aeb-bd3b-35527ecd7a96" with KillPodSandboxError: "rpc error: code = Unknown desc = networkPlugin cni failed to teardown pod \"medusa-56ccf6cf65-vw98t_ix-medusa\" network: cni config uninitialized" 2022-12-01 21:17:59 Applied LoadBalancer DaemonSet kube-system/svclb-medusa-4bba2ae4 2022-12-01 21:17:59 Ensuring load balancer 2022-12-01 21:17:59 There are no available nodes for LoadBalancer 2022-12-01 21:17:57 0/1 nodes are available: 1 node(s) had untolerated taint {ix-svc-stop: }. preemption: 0/1 nodes are available: 1 Preemption is not helpful for scheduling. 2022-12-01 21:17:27 Created pod: medusa-56ccf6cf65-xgcjr 2022-12-01 21:17:27 0/1 nodes are available: 1 node(s) had untolerated taint {ix-svc-stop: }. preemption: 0/1 nodes are available: 1 Preemption is not helpful for scheduling. 2022-12-01 21:17:27 Marking for deletion Pod ix-medusa/medusa-56ccf6cf65-vw98t
root@truenas[~]# k3s kubectl get pods --all-namespaces -o wide NAMESPACE NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES ix-jdownloader jdownloader-jdownloader2-5bdc59bf67-h96t6 1/1 Running 0 57m 172.16.1.135 ix-truenas <none> <none> ix-cyberchef cyberchef-64bb57c4d4-l4kn6 1/1 Running 0 57m 172.16.1.121 ix-truenas <none> <none> kube-system svclb-pihole-dns-tcp-eee06c2f-47f6z 1/1 Running 0 56m 172.16.1.113 ix-truenas <none> <none> kube-system svclb-photoprism-c204138b-jdwwk 1/1 Running 0 56m 172.16.1.114 ix-truenas <none> <none> kube-system svclb-couchpotato-74857bdf-8xbnm 1/1 Running 0 56m 172.16.1.146 ix-truenas <none> <none> ix-jackett jackett-d484b4f88-s5dxk 1/1 Running 0 57m 172.16.1.132 ix-truenas <none> <none> kube-system svclb-pihole-1891fd12-mf2nn 1/1 Running 0 56m 172.16.1.116 ix-truenas <none> <none> kube-system svclb-transmission-torrentudp-d4b14371-zm4q2 1/1 Running 0 56m 172.16.1.120 ix-truenas <none> <none> kube-system svclb-flaresolverr-b10cd404-cwmn7 1/1 Running 0 56m 172.16.1.117 ix-truenas <none> <none> kube-system svclb-jdownloader-jdownloader2-vnc-2af2f4fe-mwj9s 1/1 Running 0 56m 172.16.1.145 ix-truenas <none> <none> cnpg-system cnpg-controller-manager-7cfc948649-ckpc5 1/1 Running 0 57m 172.16.1.118 ix-truenas <none> <none> kube-system openebs-zfs-node-md8t7 2/2 Running 0 56m 192.168.1.3 ix-truenas <none> <none> kube-system amdgpu-device-plugin-daemonset-lnbfj 1/1 Running 0 56m 172.16.1.143 ix-truenas <none> <none> kube-system svclb-plex-411480b3-hpw29 1/1 Running 0 56m 172.16.1.119 ix-truenas <none> <none> kube-system svclb-pihole-dns-655052c6-7ppd9 1/1 Running 0 56m 172.16.1.126 ix-truenas <none> <none> ix-photoprism photoprism-mariadb-0 1/1 Running 0 56m 172.16.1.137 ix-truenas <none> <none> ix-pihole pihole-645684656f-v9qzj 1/1 Running 0 57m 172.16.1.130 ix-truenas <none> <none> ix-transmission transmission-5c7d9f9d9d-jvj5f 1/1 Running 0 57m 172.16.1.128 ix-truenas <none> <none> ix-plex plex-ffcc99f86-7269w 1/1 Running 0 57m 172.16.1.129 ix-truenas <none> <none> kube-system openebs-zfs-controller-0 5/5 Running 0 56m 172.16.1.124 ix-truenas <none> <none> kube-system svclb-jackett-0b9bc961-vj7fs 1/1 Running 0 56m 172.16.1.123 ix-truenas <none> <none> kube-system svclb-transmission-torrent-f87cf473-pq5kt 1/1 Running 0 56m 172.16.1.142 ix-truenas <none> <none> metallb-system controller-6c58495cbb-hl879 1/1 Running 0 57m 172.16.1.122 ix-truenas <none> <none> kube-system svclb-cyberchef-8aa97e58-7zft7 1/1 Running 0 56m 172.16.1.139 ix-truenas <none> <none> kube-system coredns-d76bd69b-dwqgz 1/1 Running 0 57m 172.16.1.138 ix-truenas <none> <none> ix-couchpotato couchpotato-594d964c8d-grjjm 1/1 Running 0 57m 172.16.1.136 ix-truenas <none> <none> kube-system svclb-home-assistant-4c88f64d-hnhvw 1/1 Running 0 56m 172.16.1.125 ix-truenas <none> <none> kube-system svclb-medusa-4bba2ae4-6kqzb 1/1 Running 0 56m 172.16.1.140 ix-truenas <none> <none> kube-system svclb-transmission-750fbcff-h5rkf 1/1 Running 0 56m 172.16.1.144 ix-truenas <none> <none> prometheus-operator prometheus-operator-7b4d465f47-wsw86 1/1 Running 0 57m 172.16.1.115 ix-truenas <none> <none> kube-system svclb-jdownloader-jdownloader2-myjd-7bdd72d7-vpq7x 1/1 Running 0 56m 172.16.1.141 ix-truenas <none> <none> kube-system svclb-jdownloader-jdownloader2-41d35b86-j6ddb 1/1 Running 0 56m 172.16.1.147 ix-truenas <none> <none> metallb-system speaker-ww927 1/1 Running 0 55m 192.168.1.3 ix-truenas <none> <none> ix-flaresolverr flaresolverr-86884656ff-7rfc6 1/1 Running 2 (56m ago) 57m 172.16.1.127 ix-truenas <none> <none> ix-home-assistant home-assistant-postgresql-0 1/1 Running 0 55m 172.16.1.148 ix-truenas <none> <none> ix-home-assistant home-assistant-bdc5cfc5d-4gddv 1/1 Running 0 57m 172.16.1.131 ix-truenas <none> <none> ix-photoprism photoprism-76f44dc8bc-ghsgj 1/1 Running 0 57m 172.16.1.134 ix-truenas <none> <none> ix-medusa medusa-8586594845-mjc48 0/1 Running 10 (14s ago) 53m 172.16.1.150 ix-truenas <none> <none>
