I'm trying to change the amount of ram allocated to a VM and its not saving no matter what I try.
No matter what I change nothing saves, description field etc..
The vm is stopped.
Can anyone else please test and let me know if they see the same behavior?
I also looked up and found that it might be possible to edit vm settings in the terminal using virsh but that doesnt work either:
The vm is stopped.
virsh list
error: failed to connect to the hypervisor
error: Failed to connect socket to '/var/run/libvirt/libvirt-sock': No such file or directory
