I have a problem with my VM. I created a VM and try to pass USB but I break something :(
Now I can't launch my existing VM and I can't create another VM there is always the same error : failed to connect to libvirt
I reboot and there is the same error.
I try the command: service middlewared status
libvirt: XML-RPC error : Failed to connect socket to '/run/truenas_libvirt/libvirt-sock': No such file or directory
Another command:
truenas# ls -l /var/run/libvirt/libvirt-sock
srw-rw-rw- 1 root root 0 Jul 8 21:51 /var/run/libvirt/libvirt-sock
I don't know what I need to do. I need to create a symbolic link into /run/truenas_libvirt/?
JenJen
Another command:
JenJen
