jmoschetti45
- Mar 19, 2020
Few questions, I've read a lot about SAS, and I think I got it, but just in case...
Main box: 24 bay supermicro with BPN-SAS2-846EL1 backplane, LSI 9210-8i in IT.
Currently has 2 SFF8087 cables from backplane to HBA, although the book says you only need 1.
Getting filled with SATA3 drives.
Benefits to 2? More lanes for more bandwidth? Redundancy?
External box: CSE-216 CSE-PTJBOD-CB2 with BPN-SAS2-216EB and 2 SAS2-216EL2 expanders.
Has 2 SFF8087 cables from each expander to 2 external SFF8088 ports (so 4 ports total).
Getting filled with SATA3 SSD and spinning rust, probably 50/50.
From what makes sense to me from the SATA days. 1 cable from each "out" port to one of the 2 "in" ports on a second HBA in the main box.
I've seen people run 4, 2 from each to 2 separate HBAs. More bandwidth? Redundancy? (would need dual port sas drives tho???)
Since each of the expanders have 3 ports, could I run 4 cables up to the main box to 2 HBAs for maximum bandwidth, then use the remaining 2 to eventually add a second box downstream with reduced bandwidth? (eg: fill this one with SSD, 2nd box with rust?)
