Greetings all. I am going to be building FreeNAS on older hardware but I will need additional SATA ports than the board has. Can anyone recommend a good SATA bus card that will go into a PCI Express slot or PCI-16 slot?
Yes, you probably don't want a "SATA bus card" because who knows what chipset it has. The best way to add disks to FreeNAS is with a host bus adapter (HBA). This is basically the enterprise SAS equivalent of a "SATA bus card" except that it's much more likely to work well.
Please check out the following links in their entirety
The HBA card in sig was $25 on ebay ..it was listed as an IBM ServeRaid M1015 and then I flashed it to IT mode. .. you can add up to 8 sata or sas drives.. break out sata cables was $7.. an HBA card flashed to IT mode is going to be your best bet
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
