Worth getting a Mobo with 3+ LAN ports and onboard SATA vs. a SAS card?
BobRoss
Hey everyone, second post!
I have everything ready to go except my MoBo, this will be used for large file storage and a media server 8x 4TB drives
I have a really nice 24-port corporate grade switch, and my main PC has 3x 1GB LAN ports (aggregated). How important the network connection speeds? Should I get a MoBo that also has 3 LAN ports?
Also I do have a LSI SAS 9211-8i 6Gb/s SAS Host Bus Adapter. Would it be worth using this card over on-board SATA? Chances are I will be getting a board with only 1x PCI-Express 2.0 x8 slot. Should I sacrifice the slot for the SAS card or for additional network ports?
Thanks for any advise!
Well I assume 3x GB to 3x GB over a network is going to be faster transfer than 1GB to 1GB?
If it worked like that, which it doesn't.
depasseg
FreeNAS Replicant
No, unless this server will be handling simultaneous multiple high bandwidth requests from 3 or more client machines.
pirateghost
Unintelligible Geek
I'm going to assume the OP uses Windows NIC teaming...which does what everyone wished LACP or LAGG would do in every other OS. It doesn't work like that on any other OS
BobRoss
I do. Here is a picture of my LAND connection setup:
So this setup isn't going to help file transfer any better than a singe LAN port to my NAS machine at all (assuming my NAS has multiple LAN ports)?
Also what about the SATA situation? Is onboard good enough or should I use my LSI SAS 9211-8i 6Gb/s SAS Host Bus Adapter?
BTW thank you for the help everyone!
jgreco
Resident Grinch
Imagine you have 1 car that does 200 miles/h. If you have 3 cars will they do 600 miles/h?
You really need to put a C&C warning (cats and coffee) on stuff like that. Geeeeeeeeez...!
jgreco
Resident Grinch
Picture didn't work I guess? Maybe try uploading it as a file and then inserting a thumbnail.
Onboard actually performs a little better than the 9211-8i, assuming that the onboard is "something Intel."
pirateghost
Unintelligible Geek
FreeBSD and Linux don't aggregate ports like Windows does. Windows isn't LACP or fail over LAGG which are your options on FreeNAS. LACP requires a compatible switch and will not do what you want.
BobRoss
I have a Netgear GS724T switch that supports both LACP and static LAG. So this is confusing. FreeNas will use link aggregation with this switch and even though my windows ports are bonded they still wont talk to FreeNas at 3GB... This is really confusing.
pirateghost
Unintelligible Geek
Windows doesn't use standard LAGG/LACP. FreeNAS will not aggregate links to increase speed to one client. It will aggregate links to create more available pipe for MANY clients to push through
jgreco
Resident Grinch
"Aggregate ports" is a poorly defined concept and a horribly executed technology anyways, which is why there was so much angst and handwringing when they made the LACP protocol.
Ok got it. Stop B.S.ing around and just upgrade to 10Gbe haha.
Yeah, pretty much, I know that may not be what you wanted to hear, but it is the practical takeaway.
jgreco
Resident Grinch
Certainly cheaper. However, in the end, the FreeNAS box is probably a lot more capable and more powerful. It's a tradeoff.
