Hello.
I've just built my first NAS server, but have issues with the Samsung drives used.
Im aware that they use the new 4K sectors instead of the common 512b ones.
Installed the FreeNAS-8.0.1-BETA3-amd64 version of FreeNAS, which allows to tick the 4K checkbox when creating a RAIDZ volume.
I did the dd-read/write tests;
Im a bit dazzled how the write actually is almost twice as fast as reading from the drives. How is that possible?
Other people report 'normal' r/w speeds;
http://hardforum.com/showthread.php?t=1561366
I've read multiple posts here on the freenas board, but still wonder how to proceed.
Samsung drive thread 4K / 512b
http://forums.freenas.org/showthread.php?199-Samsung-HD204UI-2TB-4k-or-512
zdb gives this; (ashift = 12, as opposed to 9, indicating 4K sectors..)
Ive also done a diskutil to verify the 4K configuration;
The RAIDZ volume reports only 5.1 TB available space, the same issue this guy faces;
http://forums.freenas.org/showthread.php?905-RaidZ-and-4x2Tb-yeilds-5.3Tb-available-space-is-this-right
I guess a rough estimate would be that 1/N-drivespace 'dissappears' when creating a RAIDZ/RAID5 volume, but this seems a little to much?
I know that there is an issue with a batch of Samsung HD204UI 2TB drives, Rev A manufactured last year (2010). Luckily my drives are newer than those, and probably not affected by this issue.
My current build is:
4x 2TB Samsung HD204UI
4GB Ram
Gigabyte D525 Motherboard (ATOM 1.8GHZ)
Any hints/tips/ideas would be very welcome.
Thanks for reading a newbie's post.
Andreas.
freenas# dd if=/dev/zero of=/mnt/nas/ddfile bs=1m count=10000 10000+0 records in 10000+0 records out 10485760000 bytes transferred in 57.899730 secs (181102053 bytes/sec) freenas# dd if=/mnt/nas/ddfile of=/dev/zero bs=1m count=10000 10000+0 records in 10000+0 records out 10485760000 bytes transferred in 101.018096 secs (103800808 bytes/sec)
nas
version=15
name='nas'
state=0
txg=2596
pool_guid=7692156913126981140
hostid=3781610956
hostname=''
vdev_tree
type='root'
id=0
children[0]
type='raidz'
id=0
guid=8960000534887433963
nparity=1
metaslab_array=23
metaslab_shift=36
ashift=12
asize=7992986566656
is_log=0
children[0]
type='disk'
id=0
guid=16499009846811762149
path='/dev/gptid/b040bc5d-a8d8-11e0-8354-1c6f65ff36d1'
whole_disk=0
children[1]
type='disk'
id=1
guid=6775391256335755402
path='/dev/gptid/b15d47d3-a8d8-11e0-8354-1c6f65ff36d1'
whole_disk=0
children[2]
type='disk'
id=2
guid=11791736992082363252
path='/dev/gptid/b247551b-a8d8-11e0-8354-1c6f65ff36d1'
whole_disk=0
children[3]
type='disk'
id=3
guid=10837461982030907558
path='/dev/gptid/b337913d-a8d8-11e0-8354-1c6f65ff36d1'
whole_disk=0
freenas# diskinfo -v /dev/ada0
/dev/ada0
512 # sectorsize
2000398934016 # mediasize in bytes (1.8T)
3907029168 # mediasize in sectors
0 # stripesize
0 # stripeoffset
3876021 # Cylinders according to firmware.
16 # Heads according to firmware.
63 # Sectors according to firmware.
S2H7JD2B422328 # Disk ident.
freenas# diskinfo -v /dev/ada1
/dev/ada1
512 # sectorsize
0 # stripesize
0 # stripeoffset
S2H7JD2B422335 # Disk ident.
freenas# diskinfo -v /dev/ada2
/dev/ada2
512 # sectorsize
0 # stripesize
0 # stripeoffset
S2H7JD2B422332 # Disk ident.
freenas# diskinfo -v /dev/ada3
/dev/ada3
512 # sectorsize
0 # stripesize
0 # stripeoffset
S2H7JD2B422330 # Disk ident.
4GB Ram
Andreas.
