I have been searching for a while now, and I haven't found anything matching my case 100%, so I'll try my luck posting my problems to you guys. Sorry if my problem is obvious or already answered! Also, as you may notice, I'm quite a noobie, so please forgive any stupid questions.
One thread I found that was pretty similar, but I believe not completely the same was these:
https://forums.freenas.org/index.php?threads/lost-zpool-please-help.13878/
https://forums.freenas.org/index.ph...-one-disk-offline-cannot-be-put-online.14104/
So, my problem is this:
I build a FreeNAS v8 server some years ago, but then suddenly the motherboard died. I took out the 6 disks and almost forgot about them for a long while. I then set up a virtual Debian machine on my Windows 10 computer, and made copies of the disks to virtual harddisks of all of the disks, except for one of the disks which experienced a hardware error rendering it useless (it connected/disconnected repeatedly) and therefore I have no backup if this one.
Now I have set up the remaining 5 disks in a virtual FreeNAS install, and I've tried 8.3.2 and 9.10.2-U1 with same results: When I run
I also ran
I'm not sure how to proceed, so I'll just post the output of some of the commands I've stumbled across, in case they can prove helpful.
Some observations I make is:
zpool import
I see that 2 of the 6 disks is UNAVAIL, and not just the one I haven't connected to the virtual machine.Code:
[root@freenas] /# zpool import pool: RaidZ id: 13844435100348741427 state: UNAVAIL status: One or more devices are missing from the system. action: The pool cannot be imported. Attach the missing devices and try again. see: http://illumos.org/msg/ZFS-8000-3C config: RaidZ UNAVAIL insufficient replicas raidz1-0 UNAVAIL insufficient replicas gptid/c7259a85-0b0e-11e2-baee-001fd0af0df8 ONLINE gptid/c7ac0491-0b0e-11e2-baee-001fd0af0df8 ONLINE 5596984570285208485 UNAVAIL cannot open 6519031140053721195 UNAVAIL cannot open gptid/c929c4be-0b0e-11e2-baee-001fd0af0df8 ONLINE gptid/c9a6908b-0b0e-11e2-baee-001fd0af0df8 ONLINE
glabel status | grep p2
gives the following output (ada5p2 is missing):Code:
[root@freenas] /# glabel status | grep p2 gptid/c7ac0491-0b0e-11e2-baee-001fd0af0df8 N/A ada1p2 gptid/c9a6908b-0b0e-11e2-baee-001fd0af0df8 N/A ada2p2 gptid/c7259a85-0b0e-11e2-baee-001fd0af0df8 N/A ada3p2 gptid/c929c4be-0b0e-11e2-baee-001fd0af0df8 N/A ada4p2
I also ran
gpart show -l
and then the output said the GPT was corrupt on all of the disks. If I remember correctly, I ran gpart recover /dev/ada1
on all of the disks (ada[1-5]), and then the "corrupt" label disappeared when I ran gpart show -l
again.I'm not sure how to proceed, so I'll just post the output of some of the commands I've stumbled across, in case they can prove helpful.
gpart status
[root@freenas] /# gpart status Name Status Components ada0p1 OK ada0 ada0p2 OK ada0 ada1p1 OK ada1 ada1p2 OK ada1 ada2p1 OK ada2 ada2p2 OK ada2 ada3p1 OK ada3 ada3p2 OK ada3 ada4p1 OK ada4 ada4p2 OK ada4 ada5p1 OK ada5 ada5p2 OK ada5
gpart list
[root@freenas] /# gpart list Geom name: ada0 modified: false state: OK fwheads: 16 fwsectors: 63 last: 16777182 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada0p1 Mediasize: 524288 (512K) Sectorsize: 512 Stripesize: 0 Stripeoffset: 17408 Mode: r0w0e0 rawuuid: e288176c-dd09-11e6-8b42-08002710025b rawtype: 21686148-6449-6e6f-744e-656564454649 label: (null) length: 524288 offset: 17408 type: bios-boot index: 1 end: 1057 start: 34 2. Name: ada0p2 Mediasize: 8589369344 (8.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 544768 Mode: r1w1e1 rawuuid: e28a74ff-dd09-11e6-8b42-08002710025b rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 8589369344 offset: 544768 type: freebsd-zfs index: 2 end: 16777175 start: 1064 Consumers: 1. Name: ada0 Mediasize: 8589934592 (8.0G) Sectorsize: 512 Mode: r1w1e2 Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 4294965214 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r0w0e0 rawuuid: c793d511-0b0e-11e2-baee-001fd0af0df8 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 1998251367936 (1.8T) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 rawuuid: c7ac0491-0b0e-11e2-baee-001fd0af0df8 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251367936 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029134 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 2199022206976 (2.0T) Sectorsize: 512 Mode: r0w0e0 Geom name: ada2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 4294965214 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r0w0e0 rawuuid: c991b271-0b0e-11e2-baee-001fd0af0df8 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada2p2 Mediasize: 1998250286080 (1.8T) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 rawuuid: c9a6908b-0b0e-11e2-baee-001fd0af0df8 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998250286080 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907027021 start: 4194432 Consumers: 1. Name: ada2 Mediasize: 2199022206976 (2.0T) Sectorsize: 512 Mode: r0w0e0 Geom name: ada3 modified: false state: OK fwheads: 16 fwsectors: 63 last: 4294965214 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r0w0e0 rawuuid: c7123a39-0b0e-11e2-baee-001fd0af0df8 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada3p2 Mediasize: 1998251367936 (1.8T) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 rawuuid: c7259a85-0b0e-11e2-baee-001fd0af0df8 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251367936 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029134 start: 4194432 Consumers: 1. Name: ada3 Mediasize: 2199022206976 (2.0T) Sectorsize: 512 Mode: r0w0e0 Geom name: ada4 modified: false state: OK fwheads: 16 fwsectors: 63 last: 4294965214 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada4p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r0w0e0 rawuuid: c914ad72-0b0e-11e2-baee-001fd0af0df8 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada4p2 Mediasize: 1998251367936 (1.8T) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 rawuuid: c929c4be-0b0e-11e2-baee-001fd0af0df8 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251367936 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029134 start: 4194432 Consumers: 1. Name: ada4 Mediasize: 2199022206976 (2.0T) Sectorsize: 512 Mode: r0w0e0 Geom name: ada5 modified: false state: OK fwheads: 16 fwsectors: 63 last: 4294965214 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada5p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r0w0e0 rawuuid: c7123a39-0b0e-11e2-baee-001fd0af0df8 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada5p2 Mediasize: 1998251367936 (1.8T) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 rawuuid: c7259a85-0b0e-11e2-baee-001fd0af0df8 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251367936 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029134 start: 4194432 Consumers: 1. Name: ada5 Mediasize: 2199022206976 (2.0T) Sectorsize: 512 Mode: r0w0e0
camcontrol devlist
[root@freenas] /# camcontrol devlist <VBOX HARDDISK 1.0> at scbus0 target 0 lun 0 (pass0,ada0) <VBOX CD-ROM 1.0> at scbus0 target 1 lun 0 (pass1,cd0) <VBOX HARDDISK 1.0> at scbus2 target 0 lun 0 (pass2,ada1) <VBOX HARDDISK 1.0> at scbus3 target 0 lun 0 (pass3,ada2) <VBOX HARDDISK 1.0> at scbus4 target 0 lun 0 (pass4,ada3) <VBOX HARDDISK 1.0> at scbus5 target 0 lun 0 (pass5,ada4) <VBOX HARDDISK 1.0> at scbus6 target 0 lun 0 (pass6,ada5)
dmesg
[root@freenas] /# dmesg Copyright (c) 1992-2016 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. FreeBSD 10.3-STABLE #0 r295946+1805185(9.10.2-STABLE): Wed Jan 11 17:12:42 UTC 2017 root@gauntlet:/freenas-9.10-releng/_BE/objs/freenas-9.10-releng/_BE/os/sys/FreeNAS.amd64 amd64 FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512 CPU: Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz (3197.81-MHz K8-class CPU) Origin="GenuineIntel" Id=0x106a5 Family=0x6 Model=0x1a Stepping=5 Features=0x78bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2> Features2=0x180209<SSE3,MON,SSSE3,SSE4.1,SSE4.2> AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM> AMD Features2=0x1<LAHF> TSC: P-state invariant real memory = 4831838208 (4608 MB) avail memory = 4110860288 (3920 MB) Event timer "LAPIC" quality 400 ACPI APIC Table: <VBOX VBOXAPIC> random: <Software, Yarrow> initialized WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. ioapic0 <Version 1.1> irqs 0-23 on motherboard kbd1 at kbdmux0 aesni0: No AESNI support. padlock0: No ACE support. cryptosoft0: <software crypto> on motherboard acpi0: <VBOX VBOXXSDT> on motherboard acpi0: Power Button (fixed) acpi0: Sleep Button (fixed) cpu0: <ACPI CPU> on acpi0 attimer0: <AT timer> port 0x40-0x43,0x50-0x53 on acpi0 Timecounter "i8254" frequency 1193182 Hz quality 0 Event timer "i8254" frequency 1193182 Hz quality 100 Timecounter "ACPI-safe" frequency 3579545 Hz quality 850 acpi_timer0: <32-bit timer at 3.579545MHz> port 0x4008-0x400b on acpi0 pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 pci0: <ACPI PCI bus> on pcib0 isab0: <PCI-ISA bridge> at device 1.0 on pci0 isa0: <ISA bus> on isab0 atapci0: <Intel PIIX4 UDMA33 controller> port 0x1f0-0x1f7,0x3f6,0x170-0x177,0x376,0xd000-0xd00f at device 1.1 on pci0 ata0: <ATA channel> at channel 0 on atapci0 ata1: <ATA channel> at channel 1 on atapci0 vgapci0: <VGA-compatible display> mem 0xe0000000-0xe07fffff irq 18 at device 2.0 on pci0 vgapci0: Boot video device em0: <Intel(R) PRO/1000 Legacy Network Connection 1.1.0> port 0xd010-0xd017 mem 0xf0000000-0xf001ffff irq 19 at device 3.0 on pci0 em0: Ethernet address: 08:00:27:10:02:5b pci0: <multimedia, audio> at device 5.0 (no driver attached) ohci0: <OHCI (generic) USB controller> mem 0xf0804000-0xf0804fff irq 22 at device 6.0 on pci0 usbus0 on ohci0 pci0: <bridge> at device 7.0 (no driver attached) em1: <Intel(R) PRO/1000 Legacy Network Connection 1.1.0> port 0xd240-0xd247 mem 0xf0820000-0xf083ffff irq 16 at device 8.0 on pci0 em1: Ethernet address: 08:00:27:50:fa:84 ehci0: <Intel 82801FB (ICH6) USB 2.0 controller> mem 0xf0840000-0xf0840fff irq 19 at device 11.0 on pci0 usbus1: EHCI version 1.0 usbus1 on ehci0 ahci0: <Intel ICH8M AHCI SATA controller> port 0xd248-0xd24f,0xd258-0xd25f,0xd270-0xd27f mem 0xf0842000-0xf0843fff irq 21 at device 13.0 on pci0 ahci0: AHCI v1.10 with 6 3Gbps ports, Port Multiplier not supported ahcich0: <AHCI channel> at channel 0 on ahci0 ahcich1: <AHCI channel> at channel 1 on ahci0 ahcich2: <AHCI channel> at channel 2 on ahci0 ahcich3: <AHCI channel> at channel 3 on ahci0 ahcich4: <AHCI channel> at channel 4 on ahci0 ahcich5: <AHCI channel> at channel 5 on ahci0 acpi_acad0: <AC Adapter> on acpi0 atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0 atkbd0: <AT Keyboard> irq 1 on atkbdc0 kbd0 at atkbd0 atkbd0: [GIANT-LOCKED] psm0: <PS/2 Mouse> irq 12 on atkbdc0 psm0: [GIANT-LOCKED] psm0: model IntelliMouse Explorer, device ID 4 qpi0: <QPI system bus> on motherboard orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xe2000-0xe2fff on isa0 sc0: <System console> at flags 0x100 on isa0 sc0: VGA <16 virtual consoles, flags=0x300> vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 atrtc0: <AT realtime clock> at port 0x70 irq 8 on isa0 Event timer "RTC" frequency 32768 Hz quality 0 ZFS NOTICE: Prefetch is disabled by default if less than 4GB of RAM is present; to enable, add "vfs.zfs.prefetch_disable=0" to /boot/loader.conf. ZFS filesystem version: 5 ZFS storage pool version: features support (5000) Timecounters tick every 1.000 msec ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled em0: link state changed to UP em1: link state changed to UP usbus0: 12Mbps Full Speed USB v1.0 usbus1: 480Mbps High Speed USB v2.0 ugen0.1: <Apple> at usbus0 uhub0: <Apple OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0 ugen1.1: <Intel> at usbus1 uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 uhub0: 12 ports with 12 removable, self powered uhub1: 12 ports with 12 removable, self powered random: unblocking device. ada0 at ata0 bus 0 scbus0 target 0 lun 0 ada0: <VBOX HARDDISK 1.0> ATA-6 device ada0: Serial Number VB1b86c12f-ff9f85ed ada0: 33.300MB/s transfers (UDMA2, PIO 65536bytes) ada0: 8192MB (16777216 512 byte sectors) ada0: Previously was known as ad0 ada1 at ahcich0 bus 0 scbus2 target 0 lun 0 ada1: <VBOX HARDDISK 1.0> ATA-6 SATA 2.x device ada1: Serial Number VB1329485b-40a7f2a8 ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada1: Command Queueing enabled ada1: 2097151MB (4294965248 512 byte sectors) ada1: Previously was known as ad4 ada2 at ahcich1 bus 0 scbus3 target 0 lun 0 ada2: <VBOX HARDDISK 1.0> ATA-6 SATA 2.x device ada2: Serial Number VBe1186804-10b17d7a ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada2: Command Queueing enabled ada2: 2097151MB (4294965248 512 byte sectors) ada2: Previously was known as ad6 ada3 at ahcich2 bus 0 scbus4 target 0 lun 0 ada3: <VBOX HARDDISK 1.0> ATA-6 SATA 2.x device ada3: Serial Number VBfd2afe42-8d9623c3 ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada3: Command Queueing enabled ada3: 2097151MB (4294965248 512 byte sectors) ada3: Previously was known as ad8 ada4 at ahcich3 bus 0 scbus5 target 0 lun 0 ada4: <VBOX HARDDISK 1.0> ATA-6 SATA 2.x device ada4: Serial Number VBa292eddb-372ecccf ada4: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada4: Command Queueing enabled ada4: 2097151MB (4294965248 512 byte sectors) ada4: Previously was known as ad10 ada5 at ahcich4 bus 0 scbus6 target 0 lun 0 ada5: <VBOX HARDDISK 1.0> ATA-6 SATA 2.x device ada5: Serial Number VBb0677f0e-eaf0d780 ada5: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada5: Command Queueing enabled ada5: 2097151MB (4294965248 512 byte sectors) ada5: Previously was known as ad12 cd0 at ata0 bus 0 scbus0 target 1 lun 0 cd0: <VBOX CD-ROM 1.0> Removable CD-ROM SCSI device cd0: Serial Number VB1-01f003f6 cd0: 33.300MB/s transfers (UDMA2, ATAPI 12bytes, PIO 65534bytes) cd0: Attempt to query device size failed: NOT READY, Medium not present Timecounter "TSC-low" frequency 1598904247 Hz quality 1000 Trying to mount root from zfs:freenas-boot/ROOT/default []... GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) hwpc_core: unknown PMC architecture: 0 hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI>
zdb -l /dev/ada5p2
[root@freenas] /# zdb -l /dev/ada5p2 -------------------------------------------- LABEL 0 -------------------------------------------- version: 15 name: 'RaidZ' state: 0 txg: 13018627 pool_guid: 13844435100348741427 hostid: 3271116453 hostname: 'freenas.local' top_guid: 6075442249147471512 guid: 15374796970963134483 vdev_tree: type: 'raidz' id: 0 guid: 6075442249147471512 nparity: 1 metaslab_array: 23 metaslab_shift: 36 ashift: 12 asize: 11989471985664 is_log: 0 children[0]: type: 'disk' id: 0 guid: 15374796970963134483 path: '/dev/gptid/c7259a85-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c7259a85-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 158 children[1]: type: 'disk' id: 1 guid: 6420862054695758756 path: '/dev/gptid/c7ac0491-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c7ac0491-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 157 children[2]: type: 'disk' id: 2 guid: 5596984570285208485 path: '/dev/gptid/c826480a-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c826480a-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 156 children[3]: type: 'disk' id: 3 guid: 6519031140053721195 path: '/dev/gptid/c8ac96f2-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c8ac96f2-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 not_present: 1 DTL: 155 children[4]: type: 'disk' id: 4 guid: 5085730408897018382 path: '/dev/gptid/c929c4be-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c929c4be-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 154 children[5]: type: 'disk' id: 5 guid: 2261504104292084216 path: '/dev/gptid/c9a6908b-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c9a6908b-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 99 -------------------------------------------- LABEL 1 -------------------------------------------- version: 15 name: 'RaidZ' state: 0 txg: 13018627 pool_guid: 13844435100348741427 hostid: 3271116453 hostname: 'freenas.local' top_guid: 6075442249147471512 guid: 15374796970963134483 vdev_tree: type: 'raidz' id: 0 guid: 6075442249147471512 nparity: 1 metaslab_array: 23 metaslab_shift: 36 ashift: 12 asize: 11989471985664 is_log: 0 children[0]: type: 'disk' id: 0 guid: 15374796970963134483 path: '/dev/gptid/c7259a85-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c7259a85-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 158 children[1]: type: 'disk' id: 1 guid: 6420862054695758756 path: '/dev/gptid/c7ac0491-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c7ac0491-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 157 children[2]: type: 'disk' id: 2 guid: 5596984570285208485 path: '/dev/gptid/c826480a-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c826480a-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 156 children[3]: type: 'disk' id: 3 guid: 6519031140053721195 path: '/dev/gptid/c8ac96f2-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c8ac96f2-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 not_present: 1 DTL: 155 children[4]: type: 'disk' id: 4 guid: 5085730408897018382 path: '/dev/gptid/c929c4be-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c929c4be-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 154 children[5]: type: 'disk' id: 5 guid: 2261504104292084216 path: '/dev/gptid/c9a6908b-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c9a6908b-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 99 -------------------------------------------- LABEL 2 -------------------------------------------- version: 15 name: 'RaidZ' state: 0 txg: 13018627 pool_guid: 13844435100348741427 hostid: 3271116453 hostname: 'freenas.local' top_guid: 6075442249147471512 guid: 15374796970963134483 vdev_tree: type: 'raidz' id: 0 guid: 6075442249147471512 nparity: 1 metaslab_array: 23 metaslab_shift: 36 ashift: 12 asize: 11989471985664 is_log: 0 children[0]: type: 'disk' id: 0 guid: 15374796970963134483 path: '/dev/gptid/c7259a85-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c7259a85-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 158 children[1]: type: 'disk' id: 1 guid: 6420862054695758756 path: '/dev/gptid/c7ac0491-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c7ac0491-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 157 children[2]: type: 'disk' id: 2 guid: 5596984570285208485 path: '/dev/gptid/c826480a-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c826480a-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 156 children[3]: type: 'disk' id: 3 guid: 6519031140053721195 path: '/dev/gptid/c8ac96f2-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c8ac96f2-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 not_present: 1 DTL: 155 children[4]: type: 'disk' id: 4 guid: 5085730408897018382 path: '/dev/gptid/c929c4be-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c929c4be-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 154 children[5]: type: 'disk' id: 5 guid: 2261504104292084216 path: '/dev/gptid/c9a6908b-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c9a6908b-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 99 -------------------------------------------- LABEL 3 -------------------------------------------- version: 15 name: 'RaidZ' state: 0 txg: 13018627 pool_guid: 13844435100348741427 hostid: 3271116453 hostname: 'freenas.local' top_guid: 6075442249147471512 guid: 15374796970963134483 vdev_tree: type: 'raidz' id: 0 guid: 6075442249147471512 nparity: 1 metaslab_array: 23 metaslab_shift: 36 ashift: 12 asize: 11989471985664 is_log: 0 children[0]: type: 'disk' id: 0 guid: 15374796970963134483 path: '/dev/gptid/c7259a85-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c7259a85-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 158 children[1]: type: 'disk' id: 1 guid: 6420862054695758756 path: '/dev/gptid/c7ac0491-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c7ac0491-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 157 children[2]: type: 'disk' id: 2 guid: 5596984570285208485 path: '/dev/gptid/c826480a-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c826480a-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 156 children[3]: type: 'disk' id: 3 guid: 6519031140053721195 path: '/dev/gptid/c8ac96f2-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c8ac96f2-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 not_present: 1 DTL: 155 children[4]: type: 'disk' id: 4 guid: 5085730408897018382 path: '/dev/gptid/c929c4be-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c929c4be-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 154 children[5]: type: 'disk' id: 5 guid: 2261504104292084216 path: '/dev/gptid/c9a6908b-0b0e-11e2-baee-001fd0af0df8' phys_path: '/dev/gptid/c9a6908b-0b0e-11e2-baee-001fd0af0df8' whole_disk: 0 DTL: 99
- In the last output, I see that the fourth disk (id: 3) is "not_present: 1", which corresponds with my previous observation that the fourth disk was the one with the hardware error.
- The third disk (id: 2) is connected, but doesn't show in
glabel status
