Milhouse
 - Jun 1, 2011
These Samsung HD204UI 2TB drives are apparently 4K sectors internally, but the Samsung drive firmware presents them as 512 bytes at the hardware level.
Question is, when creating a ZFS volume is it better to select 4K support or not with these drives? I'm guessing not, as they're seen as 512 byte drives, but just wanted to sanity check this theory!
I suppose the problem then becomes when you replace these drives as they fail, most likely with true 4K sector drives, would it then have been better to use 4K support from the outset even if these Samsung drives are 512 byte?
