Log and Hardware Mismatch on SATA performance...
djseto
After running FreeNAS for years, I finally just enabled email alerts. I got my first security run output this morning and I was looking at it and noticed something weird.
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <ST1000DM003-1ER162 CC46> ACS-2 ATA SATA 3.x device
ada0: Serial Number Z4YCD15F
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 953869MB (1953525168 512 byte sectors)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad4
ada1 at ahcich2 bus 0 scbus2 target 0 lun 0
ada1: <ST1000DM003-1ER162 CC46> ACS-2 ATA SATA 3.x device
ada1: Serial Number Z4YC3E7H
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 953869MB (1953525168 512 byte sectors)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad8
ada2 at ahcich3 bus 0 scbus3 target 0 lun 0
ada2: <ST1000DM003-1ER162 CC46> ACS-2 ATA SATA 3.x device
ada2: Serial Number Z4YBQMJX
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 953869MB (1953525168 512 byte sectors)
ada2: quirks=0x1<4K>
ada2: Previously was known as ad10
ada3 at ata1 bus 0 scbus5 target 0 lun 0
ada3: <ST1000DM003-1ER162 CC46> ACS-2 ATA SATA 3.x device
ada3: Serial Number Z4YBKW5N
ada3: 150.000MB/s transfers (SATA, UDMA6, PIO 8192bytes)
ada3: 953869MB (1953525168 512 byte sectors)
ada3: quirks=0x1<4K>
ada3: Previously was known as ad2
ada4 at ata1 bus 0 scbus5 target 1 lun 0
ada4: <ST1000DM003-1ER162 CC46> ACS-2 ATA SATA 3.x device
ada4: Serial Number Z4YBZAS3
ada4: 150.000MB/s transfers (SATA, UDMA6, PIO 8192bytes)
ada4: 953869MB (1953525168 512 byte sectors)
ada4: quirks=0x1<4K>
ada4: Previously was known as ad3
For my drives ADA3 and ADA4, the log shows 150MB (SATA) while my other three drives (ADA0,1,2) have 300B (SATA 2.X). When I run a smartcl -a /dev/ada4, I get
Model Family:	 Seagate Barracuda 7200.14 (AF)
Device Model:	 ST1000DM003-1ER162
Serial Number:	Z4YBKW5N
LU WWN Device Id: 5 000c50 087b68c15
Firmware Version: CC46
User Capacity:	1,000,204,886,016 bytes [1.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	7200 rpm
Form Factor:	  3.5 inches
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:	Tue May  9 09:06:57 2017 EDT
SMART support is: Enabled
This shows my drive is running at SATA 3.0Gb/s which is more inline with the 300MB/s. I'm trying to understand why these two drives are showing different in my report than the other 3 drives. What am I missing here? I'm pretty technical but FreeNAS has very much been a set and forget project for me. My first goal is to make sure all my drives are configured and performing. The specs for my ASUS MB is SATA 3Gb/s for all 6 SATA Ports.
This might be unrelated, but I do know ADA4 is currently in a DEGRADED state as I'm seeing high Checksum errors in the Volume Status, but SMARTCTL long test reports the drive is fine. I'm guessing the drive is on it's way out...
EDIT: Including my hardware specs:
Motherboard is ASUS M4A78LT-M
CPU is AMD Athalon II X2 250
RAM is 8GB
HDs: Seagate 1TB ST1000DM003-1ER162
FreeNAS Version is FreeNAS-9.10.2-U3 (e1497f269)
SweetAndLow
Sweet'NASty
Hardware specs and FreeNAS version are required with your post. No one can help you until you provide that info.
djseto
OK. Sorry. It's been a long time since I've asked for help. I've added the specs into my edited post above.
SweetAndLow
Sweet'NASty
First of all your motherboard is only $70 so or expectations should be pretty low. You also have some other hardware problems but I'll leave that for now.
Start by checking all Sata cables are attached and double check they support sata 2. You can also try taking down the serial number of the drives and then switching the ports and and see if the problem follows the drives or the port. We can also test your individual disk speed if needed but don't worry yet.
Lastly you need to fix that degraded disk as your first step. If smart is ok the problem is probably somewhere else. I think the motherboard is the problem because it's kind of garbage quality.
djseto
Ha. Thanks for the garbage insults. This MB has worked for the last few years and it wasn't $70 when I bought it. I have a spare drive so I can swap it out with the degraded disk. I also have two cables I can swap.
Since the log and smarctl aren't showing the same thing, which is wrong?
SweetAndLow
Sweet'NASty
Replace the disk then we can know more. If you provide smart output we can actually tell you what's wing with your disk.
That motherboard has realtek lan which is terrible on freebsd. It also had audio which is useless and can cause problems. I can't find any specs on the Sata controller so that makes me think it's not Intel and thats bad. Most amd systems use very cheap parts that cause all kinds of problems. Great for a gaming/Facebook machine running Windows and nothing more.
djseto
What specific smart command do you need output from?
I'm using FreeNAS as nothing more than a TimeMachine target for my Macs and for some backup storage. I don't need high performance. I work for VMware and I'm running all flash VSAN in my lab for virtual machines. I didn't splurge on a MB because I was trying to keep the build of this machine less than just going out and buying a DROBO or Synlogy box. This box has been running for close to 6 years now.
SweetAndLow
Sweet'NASty
smartctl -a /dev/adaX for all disks
djseto
Disk replaced. Running Resilver process now...
I also swapped out the SATA cable for this drive while I was at it.
thanks for your continued help
djseto
ADA0
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Serial Number:	Z4YCD15F
LU WWN Device Id: 5 000c50 09091d163
Local Time is:	Tue May  9 11:04:30 2017 EDT
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
Self-test execution status:	  (   0)	The previous self-test routine completed
					been run.
data collection:		 (   80) seconds.
capabilities:			 (0x7b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:			(0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:		(0x01)	Error logging supported.
Short self-test routine
recommended polling time:	 (   1) minutes.
Extended self-test routine
recommended polling time:	 ( 109) minutes.
Conveyance self-test routine
recommended polling time:	 (   2) minutes.
SCT capabilities:		   (0x1085)	SCT Status supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x000f   117   099   006	Pre-fail  Always	   -	   155924016
  3 Spin_Up_Time			0x0003   098   097   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   21
  5 Reallocated_Sector_Ct   0x0033   100   100   010	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   077   060   030	Pre-fail  Always	   -	   53190650
  9 Power_On_Hours		  0x0032   089   089   000	Old_age   Always	   -	   9925
 10 Spin_Retry_Count		0x0013   100   100   097	Pre-fail  Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   21
183 Runtime_Bad_Block	   0x0032   100   100   000	Old_age   Always	   -	   0
184 End-to-End_Error		0x0032   100   100   099	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   100   100   000	Old_age   Always	   -	   0
188 Command_Timeout		 0x0032   100   100   000	Old_age   Always	   -	   0 0 0
189 High_Fly_Writes		 0x003a   100   100   000	Old_age   Always	   -	   0
190 Airflow_Temperature_Cel 0x0022   065   040   045	Old_age   Always   In_the_past 35 (2 99 35 32 0)
191 G-Sense_Error_Rate	  0x0032   100   100   000	Old_age   Always	   -	   0
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   12
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   66
194 Temperature_Celsius	 0x0022   035   060   000	Old_age   Always	   -	   35 (0 15 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0010   100   100   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   0
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   9925h+02m+17.799s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   9346095172
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   111608464678
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
ADA1
Serial Number:	Z4YC3E7H
LU WWN Device Id: 5 000c50 087f2a64e
Local Time is:	Tue May  9 11:05:39 2017 EDT
					been run.
					command.
					power-saving mode.
recommended polling time:	 ( 104) minutes.
  1 Raw_Read_Error_Rate	 0x000f   116   099   006	Pre-fail  Always	   -	   108149880
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   19
  7 Seek_Error_Rate		 0x000f   077   060   030	Pre-fail  Always	   -	   52378199
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   19
190 Airflow_Temperature_Cel 0x0022   065   044   045	Old_age   Always   In_the_past 35 (0 48 35 32 0)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   11
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   64
194 Temperature_Celsius	 0x0022   035   056   000	Old_age   Always	   -	   35 (0 10 0 0 0)
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   9925h+49m+57.717s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   9346886660
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   150320392881
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
ADA2
Serial Number:	Z4YBQMJX
LU WWN Device Id: 5 000c50 087cccb19
Local Time is:	Tue May  9 11:06:06 2017 EDT
					been run.
					command.
					power-saving mode.
recommended polling time:	 ( 106) minutes.
  1 Raw_Read_Error_Rate	 0x000f   113   099   006	Pre-fail  Always	   -	   58666880
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   16
  7 Seek_Error_Rate		 0x000f   077   060   030	Pre-fail  Always	   -	   55483270
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   16
190 Airflow_Temperature_Cel 0x0022   066   043   045	Old_age   Always   In_the_past 34 (0 129 34 31 0)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   7
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   61
194 Temperature_Celsius	 0x0022   034   057   000	Old_age   Always	   -	   34 (0 11 0 0 0)
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   9924h+59m+36.091s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   9346881588
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   163212424718
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
ADA3
Local Time is:	Tue May  9 11:06:48 2017 EDT
					been run.
					command.
					power-saving mode.
recommended polling time:	 ( 105) minutes.
  1 Raw_Read_Error_Rate	 0x000f   116   099   006	Pre-fail  Always	   -	   101184360
  7 Seek_Error_Rate		 0x000f   077   060   030	Pre-fail  Always	   -	   50651803
190 Airflow_Temperature_Cel 0x0022   067   044   045	Old_age   Always   In_the_past 33 (0 19 33 31 0)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   9
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   62
194 Temperature_Celsius	 0x0022   033   056   000	Old_age   Always	   -	   33 (0 9 0 0 0)
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   9925h+53m+23.829s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   9395447228
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   17167138347
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
ADA4
Serial Number:	Z4YCD7WA
LU WWN Device Id: 5 000c50 09092493d
Local Time is:	Tue May  9 11:07:32 2017 EDT
					been run.
					command.
					power-saving mode.
  1 Raw_Read_Error_Rate	 0x000f   100   100   006	Pre-fail  Always	   -	   36112
  3 Spin_Up_Time			0x0003   098   098   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   7
  7 Seek_Error_Rate		 0x000f   100   253   030	Pre-fail  Always	   -	   67677
  9 Power_On_Hours		  0x0032   100   100   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   7
190 Airflow_Temperature_Cel 0x0022   069   069   045	Old_age   Always	   -	   31 (Min/Max 26/31)
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   6
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   11
194 Temperature_Celsius	 0x0022   031   040   000	Old_age   Always	   -	   31 (0 23 0 0 0)
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   0h+16m+48.851s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   26645644
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   28100
No Errors Logged
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
djseto
I should add that ADA 4 above is the NEW replacement drive. Once resilver is done I can re-attach the drive in the 6th drive bay and get a smartctl for the "degraded" drive. I have 6 SATA ports but I only have 5 populated. I didn't need the extra capacity of a 6th drive so I bought a 6th drive as a backup for when one fails (which I used today)
SweetAndLow
Sweet'NASty
Dude you need to run some smart tests. You have never executed one. This should be auto running weekly if you setup FreeNAS correctly.
djseto
Like I said, I set this system up like 6 years ago. I clearly didn't do it 100% right. Looking at the docs now, I don't see anything that says it's required which is probably why I skipped it 6 years ago. Who knows?
I'm still doing a re-silver so nothing I can do now around smart tests. What other hardware problems do you see? You mentioned in post #4 that you saw other ones. Until this re-silver is done, there doesn't appear to be much else that can be done so if I can dig into what these other issues are, that would be great.
With some help, the goal is to get this back to set and forget. If it ends up taking a lot of effort to maintain this, I may eventually end up going to a commercial solution. I enjoy DIY stuff, but my life is a whole lot busier these days so free time is not plentiful anymore.
SweetAndLow
Sweet'NASty
I think in my signature there is a link to best practices for setup. I can't see signatures right now so I can't check.
Basically you need emails configured, smart configured and email, ups email configured, scrubs configured, static IP, backup config.
djseto
Cool. I'll give it a read. The only thing I'm missing is SMART tests. Everything else is configured.
djseto
One of the guides says NOT to use Autotune. I've been using it since Day 1. If I uncheck it, doesn't it make a difference at this point or would I need to fresh install?
SweetAndLow
Sweet'NASty
Uncheck it, it does nothing important. You will also have to remove the tunable that it set. One thing that might make me not remove it is the fact that you have a realtek nic and if it's actually working I wouldn't change anything. That nic has a very hard time on FreeBSD system.
djseto
The NIC has worked from day 1. I've never had to fuss with it. Since the NIC works..should I NOT un-check it then? Your answer was a little vague.
How do you know it's a Realtek NIC? I don't see anything in the Specs or Manual about who makes the actual on board NIC
SweetAndLow
Sweet'NASty
It's a gamble. Disabling Autotune should not affect the nic working.
djseto
Put another way: does leaving it checked do anything negative to performance? If I'm getting less peformance form my hardware, Ill un-check it. As for the NIC, i'd assume it working is a function of the FreeBSD NIC driver...which we know apparently works...
