Daily security run output - is it a problem?
Adures
Do I have to worry? What does it mean?
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <ST1000DM003-1CH162 CC57> s/n S1DDMC15 detached
GEOM_MIRROR: Device swap1: provider ada2p1 disconnected.
(ada2:ahcich2:0:0:0): Periph destroyed
ada2: <ST1000DM003-1CH162 CC57> ACS-2 ATA SATA 3.x device
ada2: Serial Number S1DDMC15
ada2: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 953869MB (1953525168 512 byte sectors)
ada2: quirks=0x1<4K>
GEOM_ELI: Device mirror/swap1.eli destroyed.
GEOM_MIRROR: Device swap1: provider destroyed.
GEOM_MIRROR: Device swap1 destroyed.
GEOM_MIRROR: Device mirror/swap1 launched (2/2).
GEOM_ELI: Device mirror/swap1.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI: Crypto: hardware
Chris Moore
Did you remove a drive from your NAS repeatedly? If you are not taking this drive out and putting it back in, over and over, you have some kind of hardware fault. Please tell us all about your hardware so we may suggest some troubleshooting steps.
Guidance here: https://forums.freenas.org/index.php?threads/updated-forum-rules-8-3-16.45124/
Also:
Hard Drive Troubleshooting Guide (All Versions of FreeNAS)
https://forums.freenas.org/index.ph...bleshooting-guide-all-versions-of-freenas.17/
Adures
No i did not remove a drive repeatedly.
My hardware:
MB:Asrock e3v5 ws
CPU: Intel Pentium G4560
RAM: 1 stick 8gb 2133 mhz
HD: 4x 1 TB Toshiba P300, 1x 1 TB Seagate Barracuda, 1 x TB WD Caviar Blue all in RAID-Z2
All Drives are connected directly to motherboard.
Network Card: intel Ethernet Connection I219-LM
Chris Moore
The first thing I would suggest checking is both the power cable to the drive and the data cable. If either of those connections are loose, or defective, it could cause this. Also, what about the power supply? We have seen bad power leads, from the factory, on power supplies.
Adures
PS: Silentium PC Supremo L2
I'm currently on build: FreeNAS-11.2-BETA3
The connections are not loose. I think I will switch data cable to see if that solves the problem.
I also got error: freenas savecore: /dev/ada3p1: Operation not permitted
kdragon75
Adures
Ok, now the system doesn't want to shutdown.
u just get:
usm0: detached
ugen0.2: <Logitech USB Optical Mouse> at usbus0
ums0 on uhub0
usm0: <Logitech USB Optical Mouse, class 0/0, rev 2.00/63.00, addr9> on usbus0
ums0: 3 buttons and [XYZ] coordinates ID=0
over and over, but the system doesn't shutdown.
EDIT: Should I just wait? It still didn't shutdown and it's been like 15 minutes.
Adures
Ok, I'm not really sure what is going on.
The seagate drive stopped responding and freenas couldn't see it. For a moment i switched it with my old drive with some bad sectors (just for testing), to check if freenas can see it from this port. Everything seemed fine.
I shut it down and tried again with seagate drive with swapped cables (was just respinning. Looks like it's dead). However my new WD drive (less than a week old)also sounded like it was respinning over and over again (but wasn't showing any errors).
Maybe the WD drive was just looking for something i don't know.
I'm shutting the system down until i get new drive so I can start resilvering, then i can check WD drive.
Adures
It looks like it was both data cable and hard drive. After changing both, problem stopped.
