After running FreeNAS for years, I finally just enabled email alerts. I got my first security run output this morning and I was looking at it and noticed something weird.
For my drives ADA3 and ADA4, the log shows 150MB (SATA) while my other three drives (ADA0,1,2) have 300B (SATA 2.X). When I run a
This shows my drive is running at SATA 3.0Gb/s which is more inline with the 300MB/s. I'm trying to understand why these two drives are showing different in my report than the other 3 drives. What am I missing here? I'm pretty technical but FreeNAS has very much been a set and forget project for me. My first goal is to make sure all my drives are configured and performing. The specs for my ASUS MB is SATA 3Gb/s for all 6 SATA Ports.
This might be unrelated, but I do know ADA4 is currently in a DEGRADED state as I'm seeing high Checksum errors in the Volume Status, but SMARTCTL long test reports the drive is fine. I'm guessing the drive is on it's way out...
EDIT: Including my hardware specs:
Motherboard is ASUS M4A78LT-M
CPU is AMD Athalon II X2 250
RAM is 8GB
HDs: Seagate 1TB ST1000DM003-1ER162
FreeNAS Version is FreeNAS-9.10.2-U3 (e1497f269)
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0 ada0: <ST1000DM003-1ER162 CC46> ACS-2 ATA SATA 3.x device ada0: Serial Number Z4YCD15F ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada0: Command Queueing enabled ada0: 953869MB (1953525168 512 byte sectors) ada0: quirks=0x1<4K> ada0: Previously was known as ad4 ada1 at ahcich2 bus 0 scbus2 target 0 lun 0 ada1: <ST1000DM003-1ER162 CC46> ACS-2 ATA SATA 3.x device ada1: Serial Number Z4YC3E7H ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada1: Command Queueing enabled ada1: 953869MB (1953525168 512 byte sectors) ada1: quirks=0x1<4K> ada1: Previously was known as ad8 ada2 at ahcich3 bus 0 scbus3 target 0 lun 0 ada2: <ST1000DM003-1ER162 CC46> ACS-2 ATA SATA 3.x device ada2: Serial Number Z4YBQMJX ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada2: Command Queueing enabled ada2: 953869MB (1953525168 512 byte sectors) ada2: quirks=0x1<4K> ada2: Previously was known as ad10 ada3 at ata1 bus 0 scbus5 target 0 lun 0 ada3: <ST1000DM003-1ER162 CC46> ACS-2 ATA SATA 3.x device ada3: Serial Number Z4YBKW5N ada3: 150.000MB/s transfers (SATA, UDMA6, PIO 8192bytes) ada3: 953869MB (1953525168 512 byte sectors) ada3: quirks=0x1<4K> ada3: Previously was known as ad2 ada4 at ata1 bus 0 scbus5 target 1 lun 0 ada4: <ST1000DM003-1ER162 CC46> ACS-2 ATA SATA 3.x device ada4: Serial Number Z4YBZAS3 ada4: 150.000MB/s transfers (SATA, UDMA6, PIO 8192bytes) ada4: 953869MB (1953525168 512 byte sectors) ada4: quirks=0x1<4K> ada4: Previously was known as ad3
smartcl -a /dev/ada4, I getCode:
Model Family: Seagate Barracuda 7200.14 (AF) Device Model: ST1000DM003-1ER162 Serial Number: Z4YBKW5N LU WWN Device Id: 5 000c50 087b68c15 Firmware Version: CC46 User Capacity: 1,000,204,886,016 bytes [1.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Tue May 9 09:06:57 2017 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled
RAM is 8GB
