Hello all !
I'm trying to convert from standalone versions of sabnzbd & Sickbeard, and use the sabnzbd & sickrage plugins.
After installing the plugins, I was met with my old friend permissions issues. After the expected tweeking, googling, standing on my head with a finger in one ear and other magic incantations they still do not work fully.
Currently it seems impossible to set the download directories in sabnzbd as no matter what you put in there, it throws the 'cannot create download folder'. Based on things I found googling I tried :
- Mounting a storage outside the jail, with permissions, and adding the sabnzbd UID/GID to the users - Did not work ( cannot create folder )
- Using the /media directory from inside of the jail - Did not work ( cannot create folder )
- Tried using other directories within the jail - Did not work ( cannot create folder )
- Creating folder, then pointing to it from within sabnzbd ( Same error )
I've tried a few creative solutions found while googling that ranged from changing names, altering ( the dreaded 777! ) permissions, but still nothing.
I'm open to suggestions!
Note : Previously I had both programs set up on another computer and outputting to a SMB share on Freenas, which worked well. I just watned to free up the computer I had them installed on and use plugins instead.
