I've installed freenas 9.3 and plugins for sabnzbd and sickrage.
i copied the autoprocess.tv script from sickrage jail over to sabnzbd and change ownership of files so sabnzbd user can run them.
first issue was that the .py files had the wrong path to python. that i fixed with editing the files manually.
issue now is that the script exists with "you need to install python libraries" or something similar (not home atm so can't check).
i've tried installing py27, pip etc, but still no luck.
my personal take on the issue is that it's one of the following;
1) either i use the wrong autoprocessTV scripts into sabnzbd jail.. and should get them some from another place than the script folder inside the SickRage plugin jail?
2) Sabnzbd jail installs with python path/package issue?
does anyone else have this issue?
