Sabnzbd/Radarr
Bill Jaremco
On TrueNas 12.0-U1, Sabnzbd 3.0.2, Radarr 0.2.0.1504 I am having an issue with the completed downloaded files on my media dataset where the video file throws an error "the permissions on ...... are incorrectly ordered". Yet the jpg and nfo files in the same folder have no such issue. When I do a properties on them via windows 10 on the share for windows.
On the TrueNas side, I am the owner of the dataset, and a member of the Media_users owner group and and set both with basic rights and full control with inheritance. The plug root users for Radarr, 352, and Sabnzbd, 350, UIDs have been dublicated on the TrueNas side and included in the Media_Users group. I have tried using 777 as the setting in Sabnzbd for "Permissions for completed downloads" and also independantly tried setting 664 as the "File chmod mask" on Radarr. Neither altered the perm issue with the video file.
This is what I expect my rights as owner of the dataset should be on a file in the downloaded movie directory.
But the video file in the same folder has these perms:
Any idea what the heck is going on?
rob90033
You are much further along than i. Did you have a guide or how to online that details how to setup sonarr/radarr and sabnzbd with truenas 12?
Bill Jaremco
I kept notes from my first setup years ago on ver 9. It caused me weeks of issues till i figured out that the users inside the jails were entirely separate from those on FreeNas but you could spoof them by duplicating their user id "UID" from their jail on FreeNas. On TrueNas 12, plugin/Jail setups are a couple of clicks :). I did find a couple good youtubes that walk you through it though:
TrueNAS Core 12 Plex Plugin Install and Setup
https://www.ixsystems.com/blog/plex-permissions/
This thread also discusses plug in perms
https://www.truenas.com/community/t...plugins-write-permissions-to-your-data.27273/
rob90033
making progress... When trying to connect sonarr/radarr to sabnzbd using host, port, api key it will not connect. I tried local host and the ip address. I got the indexer connected so i know has internet access.
Bill Jaremco
Do you get a sorting error during your test? If so click the link or manually go to Sabnzbd and disable the sorting for movies and tv shows.
