savathuntechquestion
- Aug 6, 2022
I'm new to Truenas and new to using SABNZbd using Version: TrueNAS-13.0-U1 and sabnzbd version 3.6.0 off a fresh install via the GUI. I'm really struggling to get SABnzbd setup and pointed at the right downloads folder which would be in my PlexMedia dataset. I don't want SABnzbd to be downloading anything into it's jail. Originally I had SABnzbd pointed inside the Downloads dataset but I learned that that would make copying files between completed folder and Plex much slower.
I've been following this guide: https://www.truenas.com/community/t...arr-transmission-and-sabnzbd-11-3-u3-2.86031/ but am stuck.
Here is a picture of my pool dataset:
Here is what the folders look like in PlexMedia:
Here is the mounts:
Here's what the SABnzbd web interface sees which is nothing
If I try to force it it doesn't like it.
A friend suggested it is file permissions issues but SABnzbd has all the same permissions as the Plex Plugin (I set them to be in the same usergroup) and Plex is working fine. I've read that messing with ACLs inside the iocage jails is a quick way to break things so i haven't touched them. Any help would be appreciated, thanks
Here is the mounts:
