Sabnzbd plugin
pcdokter36
Everybody a good and healthy 2014 ! and i want to thank everybody who makes Freenas possible !
I have a question about Freenas 9.2.0. After installing the sabnzbd plugin everything worked fine, yesterday :) sabnzbd downloaded many files for me, all oke. no problems. I changed nothing and today i started the server with Freenas on it, now the plugin sabnzbd service status is off and stays off ?:( (i can't put it on and no faulty messages) so sabnzbd is not available, at programmed webadress. what is the problem ? i am a new user of Freenas, i hope someone can help me ?
Thanks in advance,
Wim
The Netherlands
D
dlavigne
Guest
Did the IP address happen to change when the system was restarted?
pcdokter36
No, the ipadress of the Freenas server is static (the same) and ipadress of sabnzbd is the same.
when i look, sabnzbd can be find here. it wants to open the same ipadress as before.
thanks for your response.
greetings
Wim
D
dlavigne
Guest
Anything in /var/log/messages when you try to start the service?
pcdokter36
Dear dlavigne,
i am a new unix/linux user, is this the answer ? how do i get to see a log ?
the jail from sabnzbd1 is still running, but no service of sabnzbd..
greetins
Wim
ps look at the pictures
pcdokter36
when is use more, command unkown.
when i use var/log/messages: access denied ??
greetings
Wim
