SabNZBD cannot delete ADMIN folder
Dhruv Govil
Hey guys,
So I'm using Sickbeard with sabnzbd and it works most of the time, but lately I've been having failed downloads for certain episodes.
Log file is attached.
I think its failing when it's trying to delete the __ADMIN__ folder, but could it also be that its failing to verify the Par2? The logs don't seem uber clear on where its failing.
When I tell it to delete the folder, it goes right ahead and the permissions are _sabnzb:wheel so that rules permissions out I think?
Is sickbeard just grabbing bad nzb files?
Any ideas?
Thanks very much.
  • sabnzbd.txt
For SabNZBD support you should go to their forums. We only provide good support with getting the jail running. We don't specialize supporting the plugin itself so your results may not be favorable here.
Dhruv Govil
Fair enough. I thought maybe it might be to do with how I set up my plugins but I'll try on their forums.
Cheers
grendel69
Have you installed tbb in the jail? If not ssh into the jail and do "pkg_add -r tbb" without the quotes.
