SOLVED SABNZBD 4.0
hmvh1
Hello the sabnzbd port recently moved to news/sabnzbd. How do I change the port origin for my jail from sabnzbdplus to sabnzbd?
Currently my jail shows this info:
root@SAB:~ # pkg info sabnzbdplus
sabnzbdplus-3.7.2,1
Version : 3.7.2,1
Installed on : Mon Feb 27 22:28:51 2023 EST
Origin : news/sabnzbdplus
Architecture : FreeBSD:13:*
Prefix : /usr/local
Categories : news
Licenses : PSFL and MIT and ISCL and GPLv2+ and BSD3CLAUSE and BSD2CLAUSE
Maintainer : james@french.id.au
WWW : https://sabnzbd.org/
Comment : Web-interface based binary newsgrabber in python, with nzb support
Options :
7ZIP : on
DBUS : off
DOCS : on
NOTIFY2 : off
PYGOBJECT : off
SSL : on
Annotations :
repo_type : binary
repository : FreeBSD
Flat size : 6.45MiB
Description :
SABnzbd is a cross-platform binary newsreader. It makes downloading
from Usenet easy by automating the whole thing. You give it an NZB
file or an RSS feed, it does the rest. Has a web-browser based UI
and an API for 3rd-party apps. Ideal for servers too.
Will either these commands work?
pkg set --change-origin news/sabnzbdplus:news/sabnzbd
pkg set -o news/sabnzbdplus:news/sabnzbd
Thank you.
What worked for me:
pkg remove sabnzbdplus
pkg install sabnzbd
All config and permissions were retained.
PnoT
I ran into this issue the other day because the tools were updated but Sab is still on v4.0.0 in the repository.
The solution was to manually remove v7.1.0 of the sabctools and install an older, v7.0.2, from my pkg cache folder.
pkg delete -f py39-sabctools-7.1.0
pkg add /var/cache/pkg/py39-sabctools-7.0.2.pkg
bsc78
Hi PnoT,
same problem here. But I can't find py39-sabctools-7.0.2.pkg
Where did you get that file?
Thx
Xor
Care to share py39-sabctools-7.0.2.pkg please? I rebuilt my entire TrueNAS box and, obviously, I no longer have this file in the cache.
Chade
Is this related to why I can't install the sabnzbd plugin at the moment? I'm receiving this error:
Error: sabnzbd had a failure Exception: RuntimeError Message: pkg error: - sabnzbdplus : Refusing to fetch artifact and run post_install.sh! Partial plugin destroyed
pkg error: - sabnzbdplus certainly suggests it might be that the plugin still refers to the outdated pkg (although I think it's still there, so shouldn't be a complete showstopper).
itsryan
Hi PnoT,
Thx
I had this same problem. I will try and explain what I did to fix this.
removed the package py39-sabctools-7.1.0.pkg
installed pip
installed wget for the tar file
downloaded version 7.0.1 from github
used pip to install 7.0.1
restarted
/var/cashe/pkg still shows version 7.1.0 installed but sabnzbd says version 7.0.1 is installed
no more errors and tested and working correctly.
pkg remove py39-sabctools-7.1.0.pkg
pkg install py39-pip
pkg install wget
wget https://github.com/sabnzbd/sabctools/releases/download/v7.0.1/sabctools-7.0.1.tar.gz
pip install sabctools-7.0.1.tar.gz
I have a feeling I'm missing something as it took me about 3 hours to figure this out but this should send you down the same google rabbit hole I traveled down.
Xor
installed pip
restarted
Thank you! It worked.
For reference, here's the code:
pkg install wget
pkg delete -y py-sabctools
JJT211
Strange, so I already had "py39-sabctools-7.0.1.pkg" installed but still couldnt update from 4.0.0
So from above, I just installed this
pkg install wget
And then finally I was able to update.
Scharbag
Rock on community - rock on!!
