pinoli
- Feb 20, 2021
I have been receiving weird S.M.A.R.T. results on one of my disks.
I am running TrueNAS SCALE Bluefin 22.12.1 with a Broadcom 9405W-16i HBA (rest in signature) and never had issues with my other 9 drives.
The disk in question is a Seagate X18 SAS 18TB (ST18000NM004J), part of a mirrored vdev.
TrueNAS SCALE has been randomly showing these errors in the UI.
when I run
what puzzles me is the fact that the drive looks perfect aside from this section
when the S.M.A.R.T. test fails it says
also the
this drive has been in use almost a year and never had any issue, weird S.M.A.R.T. alerts aside.
as you can see I waited a bit before opening a thread about this issue, but this behavior has always stayed the same for almost 9 months.
I am not sure what to do, I can still RMA the disk since it's within the warranty period, but not seeing any error on the drive and having zero issues with my data up until now, makes me think this might be something different. maybe those two blocks are unreadable? but then the read error count should go up, and yet it is zero.
shall I run some specific test? any help would be greatly appreciated, thanks.
when I run
sudo smartctl -x /dev/sde
I get thisCode:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: SEAGATE Product: ST18000NM004J Revision: E001 Compliance: SPC-5 User Capacity: 18,000,207,937,536 bytes [18.0 TB] Logical block size: 512 bytes Physical block size: 4096 bytes LU is fully provisioned Rotation Rate: 7200 rpm Form Factor: 3.5 inches Logical Unit id: 0x5000c500d85c582f Serial number: ZR56JHQZ0000C216GKBL Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Thu Mar 16 04:05:39 2023 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled Read Cache is: Enabled Writeback Cache is: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Grown defects during certification <not available> Total blocks reassigned during format <not available> Total new blocks reassigned <not available> Power on minutes since format <not available> Current Drive Temperature: 33 C Drive Trip Temperature: 60 C Manufactured in week 51 of year 2021 Specified cycle count over device lifetime: 50000 Accumulated start-stop cycles: 60 Specified load-unload count over device lifetime: 600000 Accumulated load-unload cycles: 12008 Elements in grown defect list: 0 Vendor (Seagate Cache) information Blocks sent to initiator = 3677215160 Blocks received from initiator = 3828203624 Blocks read from cache and sent to initiator = 469201710 Number of read and write commands whose size <= segment size = 133715517 Number of read and write commands whose size > segment size = 3781631 Vendor (Seagate/Hitachi) factory information number of hours powered up = 6534.43 number of minutes until next internal SMART test = 49 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 0 0 0 0 0 272153.845 0 write: 0 0 0 0 0 67948.050 0 verify: 0 0 0 0 0 208.749 0 Non-medium error count: 0 [GLTSD (Global Logging Target Save Disable) set. Enable Save with '-S on'] SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Failed in segment --> - 6532 35143810608 [0x3 0x11 0x0] # 2 Background short Completed - 6508 - [- - -] # 3 Background short Completed - 6484 - [- - -] # 4 Background short Completed - 6460 - [- - -] # 5 Background short Failed in segment --> - 6436 35145130168 [0x3 0x11 0x0] # 6 Background short Completed - 6412 - [- - -] # 7 Background short Failed in segment --> - 6388 35145130168 [0x3 0x11 0x0] # 8 Background short Completed - 6364 - [- - -] # 9 Background short Completed - 6340 - [- - -] #10 Background short Failed in segment --> - 6316 35143810608 [0x3 0x11 0x0] #11 Background short Completed - 6292 - [- - -] #12 Background short Failed in segment --> - 6268 35145130168 [0x3 0x11 0x0] #13 Background short Completed - 6244 - [- - -] #14 Background short Completed - 6220 - [- - -] #15 Background short Completed - 6196 - [- - -] #16 Background short Failed in segment --> - 6172 35143810608 [0x3 0x11 0x0] #17 Background short Failed in segment --> - 6148 35143810608 [0x3 0x11 0x0] #18 Background short Failed in segment --> - 6124 35145130168 [0x3 0x11 0x0] #19 Background short Completed - 6100 - [- - -] #20 Background short Failed in segment --> - 6076 35143810608 [0x3 0x11 0x0] Long (extended) Self-test duration: 65535 seconds [1092.2 minutes] Background scan results log Status: no scans active Accumulated power on time, hours:minutes 6534:26 [392066 minutes] Number of background scans performed: 0, scan progress: 0.00% Number of background medium scans performed: 0 # when lba(hex) [sk,asc,ascq] reassign_status 1 843:45 0000000820a74870 [1,18,4] Recovered via rewrite in-place 2 844:01 000000082a91c0c0 [1,18,8] Recovered via rewrite in-place 3 844:01 000000082a973580 [3,11,0] Recovered via rewrite in-place 4 844:02 000000082ac4d178 [1,18,8] Recovered via rewrite in-place 5 844:08 000000082ec152d8 [3,11,0] Require Write or Reassign Blocks command 6 844:09 000000082ec15b78 [3,11,0] Require Write or Reassign Blocks command 7 844:09 000000082ed020b8 [3,11,0] Require Write or Reassign Blocks command 8 844:09 000000082ed03ab8 [3,16,0] Require Write or Reassign Blocks command 9 844:09 000000082ed03aa0 [3,11,0] Require Write or Reassign Blocks command 10 844:10 000000082ebbfe30 [3,11,0] Require Write or Reassign Blocks command 49152 844:01 0001000105523818 [1,18,8] Recovered via rewrite in-place 49153 844:02 0001000105589a2f [1,18,8] Recovered via rewrite in-place Protocol Specific port log page for SAS SSP relative target port id = 1 generation code = 2 number of phys = 1 phy identifier = 0 attached device type: SAS or SATA device attached reason: unknown reason: unknown negotiated logical link rate: phy enabled; 12 Gbps attached initiator port: ssp=1 stp=1 smp=1 attached target port: ssp=0 stp=0 smp=0 SAS address = 0x5000c500d85c582d attached SAS address = 0x500605b00fe37e22 attached phy identifier = 2 Invalid DWORD count = 1 Running disparity error count = 1 Loss of DWORD synchronization = 126 Phy reset problem = 26 Phy event descriptors: Invalid word count: 1 Running disparity error count: 1 Loss of dword synchronization count: 126 Phy reset problem count: 26 relative target port id = 2 generation code = 2 number of phys = 1 phy identifier = 1 attached device type: no device attached attached reason: unknown reason: unknown negotiated logical link rate: phy enabled; unknown attached initiator port: ssp=0 stp=0 smp=0 attached target port: ssp=0 stp=0 smp=0 SAS address = 0x5000c500d85c582e attached SAS address = 0x0 attached phy identifier = 0 Invalid DWORD count = 0 Running disparity error count = 0 Loss of DWORD synchronization = 0 Phy reset problem = 0 Phy event descriptors: Invalid word count: 0 Running disparity error count: 0 Loss of dword synchronization count: 0 Phy reset problem count: 0
but doesn't show the segment.also the
LBA_first_err
sectors are just those two, and every failed test involves one of those two sectors (35143810608 or 35145130168).this drive has been in use almost a year and never had any issue, weird S.M.A.R.T. alerts aside.
