pinoli
 - Feb 20, 2021
I have been receiving weird S.M.A.R.T. results on one of my disks.
I am running TrueNAS SCALE Bluefin 22.12.1 with a Broadcom 9405W-16i HBA (rest in signature) and never had issues with my other 9 drives.
The disk in question is a Seagate X18 SAS 18TB (ST18000NM004J), part of a mirrored vdev.
TrueNAS SCALE has been randomly showing these errors in the UI.
when I run
what puzzles me is the fact that the drive looks perfect aside from this section
when the S.M.A.R.T. test fails it says
also the
this drive has been in use almost a year and never had any issue, weird S.M.A.R.T. alerts aside.
as you can see I waited a bit before opening a thread about this issue, but this behavior has always stayed the same for almost 9 months.
I am not sure what to do, I can still RMA the disk since it's within the warranty period, but not seeing any error on the drive and having zero issues with my data up until now, makes me think this might be something different. maybe those two blocks are unreadable? but then the read error count should go up, and yet it is zero.
shall I run some specific test? any help would be greatly appreciated, thanks.
	when I run
sudo smartctl -x /dev/sde I get thisCode:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build)
Vendor:               SEAGATE
Product:              ST18000NM004J
Revision:             E001
Compliance:           SPC-5
User Capacity:        18,000,207,937,536 bytes [18.0 TB]
Logical block size:   512 bytes
Physical block size:  4096 bytes
LU is fully provisioned
Rotation Rate:        7200 rpm
Form Factor:          3.5 inches
Logical Unit id:      0x5000c500d85c582f
Serial number:        ZR56JHQZ0000C216GKBL
Device type:          disk
Transport protocol:   SAS (SPL-3)
Local Time is:        Thu Mar 16 04:05:39 2023 CET
SMART support is:     Available - device has SMART capability.
SMART support is:     Enabled
Temperature Warning:  Enabled
Read Cache is:        Enabled
Writeback Cache is:   Enabled
SMART Health Status: OK
Grown defects during certification <not available>
Total blocks reassigned during format <not available>
Total new blocks reassigned <not available>
Power on minutes since format <not available>
Current Drive Temperature:     33 C
Drive Trip Temperature:        60 C
Manufactured in week 51 of year 2021
Specified cycle count over device lifetime:  50000
Accumulated start-stop cycles:  60
Specified load-unload count over device lifetime:  600000
Accumulated load-unload cycles:  12008
Elements in grown defect list: 0
Vendor (Seagate Cache) information
  Blocks sent to initiator = 3677215160
  Blocks received from initiator = 3828203624
  Blocks read from cache and sent to initiator = 469201710
  Number of read and write commands whose size <= segment size = 133715517
  Number of read and write commands whose size > segment size = 3781631
Vendor (Seagate/Hitachi) factory information
  number of hours powered up = 6534.43
  number of minutes until next internal SMART test = 49
Error counter log:
           Errors Corrected by           Total   Correction     Gigabytes    Total
               ECC          rereads/    errors   algorithm      processed    uncorrected
           fast | delayed   rewrites  corrected  invocations   [10^9 bytes]  errors
read:          0        0         0         0          0     272153.845           0
write:         0        0         0         0          0      67948.050           0
verify:        0        0         0         0          0        208.749           0
Non-medium error count:        0
[GLTSD (Global Logging Target Save Disable) set. Enable Save with '-S on']
SMART Self-test log
Num  Test              Status                 segment  LifeTime  LBA_first_err [SK ASC ASQ]
     Description                              number   (hours)
# 1  Background short  Failed in segment -->       -    6532       35143810608 [0x3 0x11 0x0]
# 2  Background short  Completed                   -    6508                 - [-   -    -]
# 3  Background short  Completed                   -    6484                 - [-   -    -]
# 4  Background short  Completed                   -    6460                 - [-   -    -]
# 5  Background short  Failed in segment -->       -    6436       35145130168 [0x3 0x11 0x0]
# 6  Background short  Completed                   -    6412                 - [-   -    -]
# 7  Background short  Failed in segment -->       -    6388       35145130168 [0x3 0x11 0x0]
# 8  Background short  Completed                   -    6364                 - [-   -    -]
# 9  Background short  Completed                   -    6340                 - [-   -    -]
#10  Background short  Failed in segment -->       -    6316       35143810608 [0x3 0x11 0x0]
#11  Background short  Completed                   -    6292                 - [-   -    -]
#12  Background short  Failed in segment -->       -    6268       35145130168 [0x3 0x11 0x0]
#13  Background short  Completed                   -    6244                 - [-   -    -]
#14  Background short  Completed                   -    6220                 - [-   -    -]
#15  Background short  Completed                   -    6196                 - [-   -    -]
#16  Background short  Failed in segment -->       -    6172       35143810608 [0x3 0x11 0x0]
#17  Background short  Failed in segment -->       -    6148       35143810608 [0x3 0x11 0x0]
#18  Background short  Failed in segment -->       -    6124       35145130168 [0x3 0x11 0x0]
#19  Background short  Completed                   -    6100                 - [-   -    -]
#20  Background short  Failed in segment -->       -    6076       35143810608 [0x3 0x11 0x0]
Long (extended) Self-test duration: 65535 seconds [1092.2 minutes]
Background scan results log
  Status: no scans active
    Accumulated power on time, hours:minutes 6534:26 [392066 minutes]
    Number of background scans performed: 0,  scan progress: 0.00%
    Number of background medium scans performed: 0
   #  when        lba(hex)    [sk,asc,ascq]    reassign_status
   1  843:45  0000000820a74870  [1,18,4]   Recovered via rewrite in-place
   2  844:01  000000082a91c0c0  [1,18,8]   Recovered via rewrite in-place
   3  844:01  000000082a973580  [3,11,0]   Recovered via rewrite in-place
   4  844:02  000000082ac4d178  [1,18,8]   Recovered via rewrite in-place
   5  844:08  000000082ec152d8  [3,11,0]   Require Write or Reassign Blocks command
   6  844:09  000000082ec15b78  [3,11,0]   Require Write or Reassign Blocks command
   7  844:09  000000082ed020b8  [3,11,0]   Require Write or Reassign Blocks command
   8  844:09  000000082ed03ab8  [3,16,0]   Require Write or Reassign Blocks command
   9  844:09  000000082ed03aa0  [3,11,0]   Require Write or Reassign Blocks command
  10  844:10  000000082ebbfe30  [3,11,0]   Require Write or Reassign Blocks command
 49152  844:01  0001000105523818  [1,18,8]   Recovered via rewrite in-place
 49153  844:02  0001000105589a2f  [1,18,8]   Recovered via rewrite in-place
Protocol Specific port log page for SAS SSP
relative target port id = 1
  generation code = 2
  number of phys = 1
  phy identifier = 0
    attached device type: SAS or SATA device
    attached reason: unknown
    reason: unknown
    negotiated logical link rate: phy enabled; 12 Gbps
    attached initiator port: ssp=1 stp=1 smp=1
    attached target port: ssp=0 stp=0 smp=0
    SAS address = 0x5000c500d85c582d
    attached SAS address = 0x500605b00fe37e22
    attached phy identifier = 2
    Invalid DWORD count = 1
    Running disparity error count = 1
    Loss of DWORD synchronization = 126
    Phy reset problem = 26
    Phy event descriptors:
     Invalid word count: 1
     Running disparity error count: 1
     Loss of dword synchronization count: 126
     Phy reset problem count: 26
relative target port id = 2
  generation code = 2
  number of phys = 1
  phy identifier = 1
    attached device type: no device attached
    reason: unknown
    negotiated logical link rate: phy enabled; unknown
    attached initiator port: ssp=0 stp=0 smp=0
    SAS address = 0x5000c500d85c582e
    attached SAS address = 0x0
    attached phy identifier = 0
    Invalid DWORD count = 0
    Running disparity error count = 0
    Loss of DWORD synchronization = 0
    Phy reset problem = 0
     Invalid word count: 0
     Running disparity error count: 0
     Loss of dword synchronization count: 0
     Phy reset problem count: 0
SMART Self-test log
Failed in segment --> but doesn't show the segment.also the
LBA_first_err sectors are just those two, and every failed test involves one of those two sectors (35143810608 or 35145130168).this drive has been in use almost a year and never had any issue, weird S.M.A.R.T. alerts aside.
Error counter log:
