S.M.A.R.T service won't start after fresh upgrade to FreeNAS 11.1-U1 from 9.10.2-U6
splaisan
I would love to agree but I have no single USB attached, only SATA's so the only thing I can do is turn my SATA's off and loose the SMART for them??
Sounds like your HBA is doing something it shouldn't.
splaisan
I found that my smartd.conf file is empty
[root@freenas ~]# cat /usr/local/etc/smartd.conf
# smartd.conf generated by /etc/ix.rc.d/ix-smartd
Should I do something about it to recreate a working environment?
A little big more digging into this and it seems that the SMART status of my disks is not accessed
[root@freenas ~]# smartctl --info /dev/da2 -T permissive
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor:			   DELL
Product:			  PERC H710
Revision:			 3.13
User Capacity:		1,999,844,147,200 bytes [1.99 TB]
Logical block size:   512 bytes
>> Terminate command early due to bad response to IEC mode page
The built-in Dell DRAC backend tells me that the status of all disks is OK but for some reason the newer incl 11.5 versions of FN do not get this info (it used to be OK before 11.5)
PS: /etc/ix.rc.d/ix-smartd is NOT running and refuses to start
That means smartd is failing the discovery process. Something in at least one of your drives or the HBA isn't playing nice there. I had the same issue with an LSI 9271 RAID controller in JBOD mode. If you manually edited smartd.conf after boot, then it would start. I ended up replacing the 9271 with a 9207-8i SAS controller. My guess is it is you HBA. :-(
splaisan
thanks Elliot.
I am afraid I have something like described in https://forums.freenas.org/index.ph...-freenas-9-10-1-running-on-dell-r730xd.46594/
[root@freenas ~]# camcontrol devlist
<DELL PERC H710 3.13>			  at scbus0 target 0 lun 0 (pass0,da0)
<DELL PERC H710 3.13>			  at scbus0 target 1 lun 0 (pass1,da1)
<DELL PERC H710 3.13>			  at scbus0 target 2 lun 0 (pass2,da2)
<DELL PERC H710 3.13>			  at scbus0 target 3 lun 0 (pass3,da3)
<DELL PERC H710 3.13>			  at scbus0 target 4 lun 0 (pass4,da4)
<DELL PERC H710 3.13>			  at scbus0 target 5 lun 0 (pass5,da5)
<DELL PERC H710 3.13>			  at scbus0 target 6 lun 0 (pass6,da6)
<DELL PERC H710 3.13>			  at scbus0 target 7 lun 0 (pass7,da7)
<DELL PERC H710 3.13>			  at scbus0 target 8 lun 0 (pass8,da8)
<DELL PERC H710 3.13>			  at scbus0 target 9 lun 0 (pass9,da9)
<DELL PERC H710 3.13>			  at scbus0 target 10 lun 0 (pass10,da10)
<DELL PERC H710 3.13>			  at scbus0 target 11 lun 0 (pass11,da11)
<DELL PERC H710 3.13>			  at scbus0 target 12 lun 0 (pass12,da12)
my dmesg says for each da#:
da12: <DELL PERC H710 3.13> Fixed Direct Access SPC-3 SCSI device
My original PERC H710 config was likely RAID and not HBA (whatever this means - I am not an IT) and I expect I cannot change this without having to fully reconfigure my storage and loose my data which is not an option.
I will have to leave without SMART I think !
Sorry if my input makes no sense, I am not a computer scientist (only a biologist;-)
I think I know what is going on. Each of your physical disks is defined as RAID0 virtual disk. When that is the case, the RAID controller obscures the physical info about the disk. It depends on the FreeBSD support for your RAID controller as to whether you will get any notification if there is a disk problem. One of my older system had a proprietary external box, and I had to use the HP RAID controller. The FreeBSD support in the "ciss" driver was pretty good, so I got notification when a drive failed. What driver is attached to your controller?
splaisan
First of all tank you very much for taking your time to help me.
How can I answer your question "What driver is attached to your controller?", any command I can run in the FN terminal or look for in the iDRAC7?
The server is a Dell PowerVault NX3200 which used to be running under Windows server2008 but was recycled with freenas and is now slave of a RHEL server (connect using the second ethernet port).
The Dell PERC H710 is mastering the drives (2HD 2.5" in RAID1 for the FN OS and all others 3.5" 2TB disks in RAID0 for the storage tank)
We configured the storage disks in the Dell RAID configuration as single physical AND virtual entities to allow FN to handle the RAID pooling rather than let the Dell PERC do the RAID (this seemed a better choice at the time of installation - apparently something like what you describe - for the expert who helped me).
At build time this was running just fine including SMART and the problem appeared after upgrading FN later on and rebooting.
rem: All hardware firmware from Dell were applied before install, all the remaining is from the FN standard install.
From a FN shell, you can use the following command: dmesg -a > /tmp/dm.txt
The you can transfer that someplace and look for the info on the dirve controller. In my case, I have two controllers. Here is what I would be looking for:
mps0: <Avago Technologies (LSI) SAS2308> port 0x7000-0x70ff mem 0xdf140000-0xdf1
4ffff,0xdf100000-0xdf13ffff irq 32 at device 0.0 numa-domain 0 on pci3
mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd
mps0: IOCCapabilities: 5a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,Even
tReplay,MSIXIndex,HostDisc>
mps1: <Avago Technologies (LSI) SAS2308> port 0xf000-0xf0ff mem 0xfbd40000-0xfbd
4ffff,0xfbd00000-0xfbd3ffff irq 56 at device 0.0 numa-domain 1 on pci13
mps1: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd
mps1: IOCCapabilities: 5a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,Even
Now I want to look at the drives. I'll just show one since there are a bunch in my system:
da8 at mps1 bus 0 scbus1 target 16 lun 0
da8: da0: Serial Number 9XG7N91W
da8: Serial Number 9XG2V96J
da8: 600.000MB/s transfers
da8: Command Queueing enabled
da8: 953869MB (1953525168 512 byte sectors)
You could just start with this since you listed the drives: dmesg -a | grep da11. In my case, that yields this output:
root@freenas2:/tmp # dmesg -a | grep da11
da11 at mps1 bus 0 scbus1 target 19 lun 0
da11: <ATA ST91000640NS BK03> Fixed Direct Access SPC-4 SCSI device
da11: Serial Number 9XG1A5MW
da11: 600.000MB/s transfers
da11: Command Queueing enabled
da11: 953869MB (1953525168 512 byte sectors)
Now I know I am looking for mps1, so I do this: dmesg -a | grep '^mps1'. That give me this data:
root@freenas2:/tmp # dmesg -a | grep '^mps1'
mps1: <Avago Technologies (LSI) SAS2308> port 0xf000-0xf0ff mem 0xfbd40000-0xfbd4ffff,0xfbd00000-0xfbd3ffff irq 56 at device 0.0 numa-domain 1 on pci13
mps1: IOCCapabilities: 5a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,MSIXIndex,HostDisc>
Make sense?
splaisan
perfect sense, here is the result:
grep mrsas dmesg_log.txt
AVAGO MegaRAID SAS FreeBSD mrsas driver version: 06.712.04.00-fbsd
mrsas0: <AVAGO Thunderbolt SAS Controller> port 0xfc00-0xfcff mem 0xddffc000-0xddffffff,0xddf80000-0xddfbffff irq 42 at device 0.0 numa-domain 0 on pci4
mrsas0: Using MSI-X with 16 number of vectors
mrsas0: FW supports <16> MSIX vector,Online CPU 24 Current MSIX <16>
mrsas0: MSI-x interrupts setup success
mrsas0: Disestablish mrsas intr hook
da0 at mrsas0 bus 0 scbus0 target 0 lun 0
da2 at mrsas0 bus 0 scbus0 target 2 lun 0
da1 at mrsas0 bus 0 scbus0 target 1 lun 0
da3 at mrsas0 bus 0 scbus0 target 3 lun 0
da4 at mrsas0 bus 0 scbus0 target 4 lun 0
da7 at mrsas0 bus 0 scbus0 target 7 lun 0
da9 at mrsas0 bus 0 scbus0 target 9 lun 0
da12 at mrsas0 bus 0 scbus0 target 12 lun 0
da8 at mrsas0 bus 0 scbus0 target 8 lun 0
da6 at mrsas0 bus 0 scbus0 target 6 lun 0
da5 at mrsas0 bus 0 scbus0 target 5 lun 0
da11 at mrsas0 bus 0 scbus0 target 11 lun 0
da10 at mrsas0 bus 0 scbus0 target 10 lun 0
Starting smartd_daemon.
Starting pbid...
Aug 23 14:02:43 freenas smartd[3105]: Configuration file /usr/local/etc/smartd.conf parsed but has no entries
Hope there is a fix for mrsas!
maybe the solution is close to that of
viniciusferrao in https://forums.freenas.org/index.php?threads/mrsas-driver-instead-of-mfi-driver.34632/page-2 !
I tried adding 'hw.mfi.mrsas_enable = 1' to /boot/device.hints as described in https://forums.freenas.org/index.ph...dell-servers-with-perc-h730-controller.46631/ but did not add 'mrsas_load = YES' which is maybe why it did not improve. I do not dare to touch these too much.
(my PERC is H710 and not H730 but it should be close)
my current /boot/device.hints (when I would edit it, is it persistent or gets overwritten at next boot?)
# $FreeBSD$
hint.fdc.0.at="isa"
hint.fdc.0.port="0x3F0"
hint.fdc.0.irq="6"
hint.fdc.0.drq="2"
hint.fd.0.at="fdc0"
hint.fd.0.drive="0"
hint.fd.1.at="fdc0"
hint.fd.1.drive="1"
hint.atkbdc.0.at="isa"
hint.atkbdc.0.port="0x060"
hint.atkbd.0.at="atkbdc"
hint.atkbd.0.irq="1"
hint.psm.0.at="atkbdc"
hint.psm.0.irq="12"
hint.sc.0.at="isa"
hint.sc.0.flags="0x100"
hint.uart.0.at="isa"
hint.uart.0.port="0x3F8"
hint.uart.0.flags="0x10"
hint.uart.0.irq="4"
hint.uart.1.at="isa"
hint.uart.1.port="0x2F8"
hint.uart.1.irq="3"
hint.ppc.0.at="isa"
hint.ppc.0.irq="7"
hint.atrtc.0.at="isa"
hint.atrtc.0.port="0x70"
hint.atrtc.0.irq="8"
hint.attimer.0.at="isa"
hint.attimer.0.port="0x40"
hint.attimer.0.irq="0"
hint.acpi_throttle.0.disabled="1"
hint.p4tcc.0.disabled="1"
What next :)
https://forums.freenas.org/index.php?attachments/post-477574_dmesg_log-txt.25334/&temp_hash=7a6b65184c5b6d75566c0603c2b270fd
The LSI 9271 controller I had also used mrsas, and I could never get it to work. I had all the drives configured in JBOD so FN could see them in their raw form. What you have is each single disk is its own RAID0 array. In that configuration you will never be able to read the raw disks. I opened a bug report for my issue, but it was closed rather brusquely stating that FN doesn't support hardware RAID controllers. The issue went away when I switched to a LSI 9207-8i.
splaisan
I will then wait until something breaks try something else then.
Have a nice WE and thanks a lot for sharing your experience
ric
Im currently using FreeNAS-11.2-RC1. I've disabled s.ma.r.t on the usb drive, and SMART wont turn on.
Troubleshooting: Ticked enable S.M.A.R.T on boot, power cycle system, disabled smart on usb.
Please help me resolve this issue. Appreciate it.
For starters, update to RC2.
Then, navigate to where smartd.conf should be. If it's not there, create an empty file of the same name and try again.
ric
I found the smartd.conf location on my freenas but this file is empty.
What I should put in this file?
Nothing. Set the SMART settings in the GUI to what you need, save, and make sure all disks are selected for your SMART tests.
ric
I've selected all the disks, SMART still wont start.
FreeNAS-11.2-RELEASE
#cat /var/log/messages
Dec 11 06:45:25 freenas wbwd0: <Nuvoton NCT6776 (0xc3/0x33) Watchdog Timer> at port 0x2e-0x2f on isa0
Dec 11 06:45:25 freenas ichwd0: <Intel Lynx Point watchdog timer> at port 0x1830-0x1837,0x1860-0x187f on isa0
Dec 11 06:45:25 freenas ichwd0: ICH WDT present but disabled in BIOS or hardware
Dec 11 06:45:25 freenas device_attach: ichwd0 attach returned 6
Dec 11 06:45:25 freenas orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff,0xc9000-0xc97ff on isa0
Dec 11 06:45:25 freenas coretemp0: <CPU On-Die Thermal Sensors> on cpu0
Dec 11 06:45:25 freenas est0: <Enhanced SpeedStep Frequency Control> on cpu0
Dec 11 06:45:25 freenas coretemp1: <CPU On-Die Thermal Sensors> on cpu1
Dec 11 06:45:25 freenas est1: <Enhanced SpeedStep Frequency Control> on cpu1
Dec 11 06:45:25 freenas ZFS filesystem version: 5
Dec 11 06:45:25 freenas ZFS storage pool version: features support (5000)
Dec 11 06:45:25 freenas Timecounters tick every 1.000 msec
Dec 11 06:45:25 freenas freenas_sysctl: adding account.
Dec 11 06:45:25 freenas freenas_sysctl: adding directoryservice.
Dec 11 06:45:25 freenas freenas_sysctl: adding middlewared.
Dec 11 06:45:25 freenas freenas_sysctl: adding network.
Dec 11 06:45:25 freenas freenas_sysctl: adding services.
Dec 11 06:45:25 freenas ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
Dec 11 06:45:25 freenas ipmi0: IPMI device rev. 1, firmware rev. 1.42, version 2.0
Dec 11 06:45:25 freenas ipmi0: Number of channels 2
Dec 11 06:45:25 freenas ipmi0: Attached watchdog
Dec 11 06:45:25 freenas ugen1.1: <Intel EHCI root HUB> at usbus1
Dec 11 06:45:25 freenas ugen2.1: <Intel EHCI root HUB> at usbus2
Dec 11 06:45:25 freenas uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Dec 11 06:45:25 freenas uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
Dec 11 06:45:25 freenas ugen0.1: <0x8086 XHCI root HUB> at usbus0
Dec 11 06:45:25 freenas uhub2: <0x8086 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
Dec 11 06:45:25 freenas uhub1: 2 ports with 2 removable, self powered
Dec 11 06:45:25 freenas uhub0: 2 ports with 2 removable, self powered
Dec 11 06:45:25 freenas uhub2: 21 ports with 21 removable, self powered
Dec 11 06:45:25 freenas ugen1.2: <vendor 0x8087 product 0x8008> at usbus1
Dec 11 06:45:25 freenas uhub3 on uhub0
Dec 11 06:45:25 freenas uhub3: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.05, addr 2> on usbus1
Dec 11 06:45:25 freenas ugen2.2: <vendor 0x8087 product 0x8000> at usbus2
Dec 11 06:45:25 freenas uhub4 on uhub1
Dec 11 06:45:25 freenas uhub4: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.05, addr 2> on usbus2
Dec 11 06:45:25 freenas uhub3: 6 ports with 6 removable, self powered
Dec 11 06:45:25 freenas uhub4: 8 ports with 8 removable, self powered
Dec 11 06:45:25 freenas ugen0.2: <vendor 0x0000 product 0x0001> at usbus0
Dec 11 06:45:25 freenas uhub5 on uhub2
Dec 11 06:45:25 freenas uhub5: <vendor 0x0000 product 0x0001, class 9/0, rev 2.00/0.00, addr 1> on usbus0
Dec 11 06:45:25 freenas uhub5: 4 ports with 3 removable, self powered
Dec 11 06:45:25 freenas ugen0.3: <vendor 0x0557 product 0x2419> at usbus0
Dec 11 06:45:25 freenas ukbd0 on uhub5
Dec 11 06:45:25 freenas ukbd0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 2> on usbus0
Dec 11 06:45:25 freenas kbd2 at ukbd0
Dec 11 06:45:25 freenas ugen0.4: <Logitech USB Keyboard> at usbus0
Dec 11 06:45:25 freenas ukbd1 on uhub2
Dec 11 06:45:25 freenas ukbd1: <USB Keyboard> on usbus0
Dec 11 06:45:25 freenas kbd3 at ukbd1
Dec 11 06:45:25 freenas ugen0.5: <Corsair Slider 3.0> at usbus0
Dec 11 06:45:25 freenas umass0 on uhub2
Dec 11 06:45:25 freenas umass0: <Corsair Slider 3.0, class 0/0, rev 3.00/a.00, addr 4> on usbus0
Dec 11 06:45:25 freenas umass0:  SCSI over Bulk-Only; quirks = 0x8100
Dec 11 06:45:25 freenas umass0:5:0: Attached to scbus5
Dec 11 06:45:25 freenas ada0 at ata2 bus 0 scbus0 target 0 lun 0
Dec 11 06:45:25 freenas ada0: <Samsung SSD 840 PRO Series DXM05B0Q> ACS-2 ATA SATA 3.x device
Dec 11 06:45:25 freenas ada0: Serial Number S1ANNEAD510589X
Dec 11 06:45:25 freenas ada0: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
Dec 11 06:45:25 freenas ada0: 122104MB (250069680 512 byte sectors)
Dec 11 06:45:25 freenas ada0: quirks=0x3<4K,NCQ_TRIM_BROKEN>
Dec 11 06:45:25 freenas ada1 at ata2 bus 0 scbus0 target 1 lun 0
Dec 11 06:45:25 freenas ada1: <WDC WD30EFRX-68EUZN0 80.00A80> ACS-2 ATA SATA 3.x device
Dec 11 06:45:25 freenas ada1: Serial Number WD-WMC4N0333692
Dec 11 06:45:25 freenas ada1: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
Dec 11 06:45:25 freenas ada1: 2861588MB (5860533168 512 byte sectors)
Dec 11 06:45:25 freenas ada1: quirks=0x1<4K>
Dec 11 06:45:25 freenas ada2 at ata3 bus 0 scbus1 target 0 lun 0
Dec 11 06:45:25 freenas ada2: <WDC WD30EFRX-68EUZN0 80.00A80> ACS-2 ATA SATA 3.x device
Dec 11 06:45:25 freenas ada2: Serial Number WD-WMC4N0335365
Dec 11 06:45:25 freenas ada2: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
Dec 11 06:45:25 freenas ada2: 2861588MB (5860533168 512 byte sectors)
Dec 11 06:45:25 freenas ada2: quirks=0x1<4K>
Dec 11 06:45:25 freenas ada3 at ata4 bus 0 scbus2 target 0 lun 0
Dec 11 06:45:25 freenas ada3: <WDC WD30EFRX-68EUZN0 80.00A80> ACS-2 ATA SATA 3.x device
Dec 11 06:45:25 freenas ada3: Serial Number WD-WCC4N0377785
Dec 11 06:45:25 freenas ada3: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
Dec 11 06:45:25 freenas ada3: 2861588MB (5860533168 512 byte sectors)
Dec 11 06:45:25 freenas ada3: quirks=0x1<4K>
Dec 11 06:45:25 freenas ada4 at ata5 bus 0 scbus3 target 0 lun 0
Dec 11 06:45:25 freenas ada4: <WDC WD30EFRX-68EUZN0 80.00A80> ACS-2 ATA SATA 3.x device
Dec 11 06:45:25 freenas ada4: Serial Number WD-WMC4N0337155
Dec 11 06:45:25 freenas ada4: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 8192bytes)
Dec 11 06:45:25 freenas ada4: 2861588MB (5860533168 512 byte sectors)
Dec 11 06:45:25 freenas ada4: quirks=0x1<4K>
Dec 11 06:45:25 freenas da0 at umass-sim0 bus 0 scbus5 target 0 lun 0
Dec 11 06:45:25 freenas da0: <Corsair Slider 3.0 1.00> Removable Direct Access SPC-4 SCSI device
Dec 11 06:45:25 freenas da0: Serial Number 2312615552040136
Dec 11 06:45:25 freenas da0: 400.000MB/s transfers
Dec 11 06:45:25 freenas da0: 15319MB (31373312 512 byte sectors)
Dec 11 06:45:25 freenas da0: quirks=0x2<NO_6_BYTE>
Dec 11 06:45:25 freenas random: unblocking device.
Dec 11 06:45:25 freenas Trying to mount root from zfs:freenas-boot/ROOT/11.2-RELEASE []...
Dec 11 06:45:25 freenas kernel: igb0: link state changed to UP
Dec 11 06:45:25 freenas kernel: igb1: link state changed to UP
Dec 11 06:45:25 freenas Waiting (max 60 seconds) for system process `vnlru' to stop... done
Dec 11 06:45:25 freenas Waiting (max 60 seconds) for system process `bufdaemon' to stop... done
Dec 11 06:45:25 freenas Waiting (max 60 seconds) for system process `syncer' to stop...
Dec 11 06:45:25 freenas Syncing disks, vnodes remaining... 0 0 done
Dec 11 06:45:25 freenas All buffers synced.
Dec 11 06:45:25 freenas Uptime: 2m47s
Dec 11 06:45:25 freenas Copyright (c) 1992-2018 The FreeBSD Project.
Dec 11 06:45:25 freenas Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
Dec 11 06:45:25 freenas         The Regents of the University of California. All rights reserved.
Dec 11 06:45:25 freenas FreeBSD is a registered trademark of The FreeBSD Foundation.
Dec 11 06:45:25 freenas FreeBSD 11.2-STABLE #0 r325575+fc3d65faae6(freenas/11.2-stable): Wed Dec  5 15:08:42 EST 2018
Dec 11 06:45:25 freenas root@nemesis.tn.ixsystems.com:/freenas-11.2-releng/freenas/_BE/objs/freenas-11.2-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64
Dec 11 06:45:25 freenas FreeBSD clang version 6.0.0 (tags/RELEASE_600/final 326565) (based on LLVM 6.0.0)
Dec 11 06:45:25 freenas VT(vga): resolution 640x480
Dec 11 06:45:25 freenas CPU: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz (3292.45-MHz K8-class CPU)
Dec 11 06:45:25 freenas Origin="GenuineIntel"  Id=0x306c3  Family=0x6  Model=0x3c  Stepping=3
Dec 11 06:45:25 freenas Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Dec 11 06:45:25 freenas Features2=0x7ffafbff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,SDBG,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
Dec 11 06:45:25 freenas AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
Dec 11 06:45:25 freenas AMD Features2=0x21<LAHF,ABM>
Dec 11 06:45:25 freenas Structured Extended Features=0x2fbb<FSGSBASE,TSCADJ,BMI1,HLE,AVX2,SMEP,BMI2,ERMS,INVPCID,RTM,NFPUSG>
Dec 11 06:45:25 freenas XSAVE Features=0x1<XSAVEOPT>
Dec 11 06:45:25 freenas VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID
Dec 11 06:45:25 freenas TSC: P-state invariant, performance statistics
Dec 11 06:45:25 freenas real memory  = 34359738368 (32768 MB)
Dec 11 06:45:25 freenas avail memory = 33267654656 (31726 MB)
Dec 11 06:45:25 freenas Event timer "LAPIC" quality 600
Dec 11 06:45:25 freenas ACPI APIC Table: <SUPERM SMCI--MB>
Dec 11 06:45:25 freenas FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
Dec 11 06:45:25 freenas FreeBSD/SMP: 1 package(s) x 1 core(s) x 2 hardware threads
Dec 11 06:45:25 freenas WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
Dec 11 06:45:25 freenas ioapic0 <Version 2.0> irqs 0-23 on motherboard
Dec 11 06:45:25 freenas SMP: AP CPU #1 Launched!
Dec 11 06:45:25 freenas Timecounter "TSC-low" frequency 1646222712 Hz quality 1000
Dec 11 06:45:25 freenas random: entropy device external interface
Dec 11 06:45:25 freenas random: registering fast source Intel Secure Key RNG
Dec 11 06:45:25 freenas random: fast provider: "Intel Secure Key RNG"
Dec 11 06:45:25 freenas kbd1 at kbdmux0
Dec 11 06:45:25 freenas nexus0
Dec 11 06:45:25 freenas vtvga0: <VT VGA driver> on motherboard
Dec 11 06:45:25 freenas cryptosoft0: <software crypto> on motherboard
Dec 11 06:45:25 freenas aesni0: <AES-CBC,AES-XTS,AES-GCM,AES-ICM> on motherboard
Dec 11 06:45:25 freenas padlock0: No ACE support.
Dec 11 06:45:25 freenas acpi0: <SUPERM SMCI--MB> on motherboard
Dec 11 06:45:25 freenas acpi0: Power Button (fixed)
Dec 11 06:45:25 freenas cpu0: <ACPI CPU> on acpi0
Dec 11 06:45:25 freenas cpu1: <ACPI CPU> on acpi0
Dec 11 06:45:25 freenas hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Dec 11 06:45:25 freenas Timecounter "HPET" frequency 14318180 Hz quality 950
Dec 11 06:45:25 freenas Event timer "HPET" frequency 14318180 Hz quality 550
Dec 11 06:45:25 freenas Event timer "HPET1" frequency 14318180 Hz quality 440
Dec 11 06:45:25 freenas Event timer "HPET2" frequency 14318180 Hz quality 440
Dec 11 06:45:25 freenas Event timer "HPET3" frequency 14318180 Hz quality 440
Dec 11 06:45:25 freenas Event timer "HPET4" frequency 14318180 Hz quality 440
Dec 11 06:45:25 freenas Event timer "HPET5" frequency 14318180 Hz quality 440
Dec 11 06:45:25 freenas Event timer "HPET6" frequency 14318180 Hz quality 440
Dec 11 06:45:25 freenas atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
Dec 11 06:45:25 freenas atrtc0: Warning: Couldn't map I/O.
Dec 11 06:45:25 freenas atrtc0: registered as a time-of-day clock, resolution 1.000000s
Dec 11 06:45:25 freenas Event timer "RTC" frequency 32768 Hz quality 0
Dec 11 06:45:25 freenas attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Dec 11 06:45:25 freenas Timecounter "i8254" frequency 1193182 Hz quality 0
Dec 11 06:45:25 freenas Event timer "i8254" frequency 1193182 Hz quality 100
Dec 11 06:45:25 freenas Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
Dec 11 06:45:25 freenas acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0
Dec 11 06:45:25 freenas pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
Dec 11 06:45:25 freenas pci0: <ACPI PCI bus> on pcib0
Dec 11 06:45:25 freenas xhci0: <Intel Lynx Point USB 3.0 controller> mem 0xf4500000-0xf450ffff irq 16 at device 20.0 on pci0
Dec 11 06:45:25 freenas xhci0: 32 bytes context size, 64-bit DMA
Dec 11 06:45:25 freenas xhci0: Port routing mask set to 0xffffffff
Dec 11 06:45:25 freenas usbus0 on xhci0
Dec 11 06:45:25 freenas usbus0: 5.0Gbps Super Speed USB v3.0
Dec 11 06:45:25 freenas ehci0: <Intel Lynx Point USB 2.0 controller USB-B> mem 0xf4513000-0xf45133ff irq 16 at device 26.0 on pci0
Dec 11 06:45:25 freenas usbus1: EHCI version 1.0
Dec 11 06:45:25 freenas usbus1 on ehci0
Dec 11 06:45:25 freenas usbus1: 480Mbps High Speed USB v2.0
Dec 11 06:45:25 freenas pcib1: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
Dec 11 06:45:25 freenas pci1: <ACPI PCI bus> on pcib1
Dec 11 06:45:25 freenas pcib2: <ACPI PCI-PCI bridge> at device 0.0 on pci1
Dec 11 06:45:25 freenas pci2: <ACPI PCI bus> on pcib2
Dec 11 06:45:25 freenas vgapci0: <VGA-compatible display> port 0xe000-0xe07f mem 0xf5000000-0xf5ffffff,0xf6000000-0xf601ffff irq 16 at device 0.0 on pci2
Dec 11 06:45:25 freenas vgapci0: Boot video device
Dec 11 06:45:25 freenas pcib3: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
Dec 11 06:45:25 freenas pci3: <ACPI PCI bus> on pcib3
Dec 11 06:45:25 freenas igb0: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0xd000-0xd01f mem 0xf6300000-0xf637ffff,0xf6380000-0xf6383fff irq 18 at device 0.0 on pci3
Dec 11 06:45:25 freenas igb0: Using MSIX interrupts with 3 vectors
Dec 11 06:45:25 freenas igb0: Ethernet address: 0c:c4:7a:00:c5:36
Dec 11 06:45:25 freenas igb0: Bound queue 0 to cpu 0
Dec 11 06:45:25 freenas igb0: Bound queue 1 to cpu 1
Dec 11 06:45:25 freenas pcib4: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
Dec 11 06:45:25 freenas pci4: <ACPI PCI bus> on pcib4
Dec 11 06:45:25 freenas igb1: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0xc000-0xc01f mem 0xf6200000-0xf627ffff,0xf6280000-0xf6283fff irq 19 at device 0.0 on pci4
Dec 11 06:45:25 freenas igb1: Using MSIX interrupts with 3 vectors
Dec 11 06:45:25 freenas igb1: Ethernet address: 0c:c4:7a:00:c5:37
Dec 11 06:45:25 freenas igb1: Bound queue 0 to cpu 0
Dec 11 06:45:25 freenas igb1: Bound queue 1 to cpu 1
Dec 11 06:45:25 freenas pcib5: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0
Dec 11 06:45:25 freenas pci5: <ACPI PCI bus> on pcib5
Dec 11 06:45:25 freenas pci5: <network, ethernet> at device 0.0 (no driver attached)
Dec 11 06:45:25 freenas pci5: <network, ethernet> at device 0.1 (no driver attached)
Dec 11 06:45:25 freenas ehci1: <Intel Lynx Point USB 2.0 controller USB-A> mem 0xf4512000-0xf45123ff irq 23 at device 29.0 on pci0
Dec 11 06:45:25 freenas usbus2: EHCI version 1.0
Dec 11 06:45:25 freenas usbus2 on ehci1
Dec 11 06:45:25 freenas usbus2: 480Mbps High Speed USB v2.0
Dec 11 06:45:25 freenas isab0: <PCI-ISA bridge> at device 31.0 on pci0
Dec 11 06:45:25 freenas isa0: <ISA bus> on isab0
Dec 11 06:45:25 freenas atapci0: <Intel Lynx Point SATA600 controller> port 0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf090-0xf097,0xf080-0xf083,0xf070-0xf07f,0xf060-0xf06f irq 19 at device 31.2 on pci0
Dec 11 06:45:25 freenas ata2: <ATA channel> at channel 0 on atapci0
Dec 11 06:45:25 freenas ata3: <ATA channel> at channel 1 on atapci0
Dec 11 06:45:25 freenas atapci1: <Intel Lynx Point SATA600 controller> port 0xf050-0xf057,0xf040-0xf043,0xf030-0xf037,0xf020-0xf023,0xf010-0xf01f,0xf000-0xf00f irq 19 at device 31.5 on pci0
Dec 11 06:45:25 freenas ata4: <ATA channel> at channel 0 on atapci1
Dec 11 06:45:25 freenas ata5: <ATA channel> at channel 1 on atapci1
Dec 11 06:45:25 freenas acpi_button0: <Power Button> on acpi0
Dec 11 06:45:25 freenas acpi_tz0: <Thermal Zone> on acpi0
Dec 11 06:45:25 freenas acpi_tz1: <Thermal Zone> on acpi0
Dec 11 06:45:25 freenas uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
Dec 11 06:45:25 freenas uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
Dec 11 06:45:25 freenas uart2: <16550 or compatible> port 0x3e8-0x3ef irq 7 on acpi0
Dec 11 06:45:25 freenas ipmi0: <IPMI System Interface> port 0xca2,0xca3 on acpi0
Dec 11 06:45:25 freenas ipmi0: KCS mode found at io 0xca2 on acpi
Dec 11 06:45:25 freenas ichwd0: <Intel Lynx Point watchdog timer> on isa0
Dec 11 06:45:25 freenas uhub0: <0x8086 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
Dec 11 06:45:25 freenas uhub2: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
Dec 11 06:45:25 freenas uhub2: 2 ports with 2 removable, self powered
Dec 11 06:45:25 freenas uhub0: 21 ports with 21 removable, self powered
Dec 11 06:45:25 freenas uhub3 on uhub1
Dec 11 06:45:25 freenas uhub3: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.05, addr 2> on usbus2
Dec 11 06:45:25 freenas uhub4 on uhub2
Dec 11 06:45:25 freenas uhub4: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.05, addr 2> on usbus1
Dec 11 06:45:25 freenas uhub5 on uhub0
Dec 11 06:45:25 freenas uhub4: 6 ports with 6 removable, self powered
Dec 11 06:45:25 freenas uhub3: 8 ports with 8 removable, self powered
Dec 11 06:45:25 freenas ukbd1 on uhub0
Dec 11 06:45:25 freenas umass0 on uhub0
Dec 11 06:45:25 freenas GEOM_MIRROR: Device mirror/swap0 launched (2/2).
Dec 11 06:45:25 freenas GEOM_MIRROR: Device mirror/swap1 launched (2/2).
Dec 11 06:45:25 freenas GEOM_ELI: Device mirror/swap0.eli created.
Dec 11 06:45:25 freenas GEOM_ELI: Encryption: AES-XTS 128
Dec 11 06:45:25 freenas GEOM_ELI:     Crypto: hardware
Dec 11 06:45:25 freenas GEOM_ELI: Device mirror/swap1.eli created.
Dec 11 06:45:25 freenas hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI> UCP/8/48/0x3f8<EDG,THR,REA,WRI,INV,QUA,PRC> UCF/1/48/0x60<REA,WRI>
Dec 11 06:45:25 freenas kernel: igb0: link state changed to DOWN
Dec 11 06:45:25 freenas kernel: igb1: link state changed to DOWN
Dec 11 06:45:25 freenas ums0 on uhub5
Dec 11 06:45:25 freenas ums0: <vendor 0x0557 product 0x2419, class 0/0, rev 1.10/1.00, addr 2> on usbus0
Dec 11 06:45:25 freenas ums0: 3 buttons and [Z] coordinates ID=0
Dec 11 06:45:25 freenas uhid0 on uhub0
Dec 11 06:45:25 freenas uhid0: <USB Keyboard> on usbus0
Dec 11 06:45:25 freenas ntpd[2513]: ntpd 4.2.8p11-a (1): Starting
Dec 11 06:45:28 freenas root: /etc/rc: WARNING: failed precmd routine for minio
Dec 11 06:45:36 freenas bridge0: Ethernet address: 02:5a:d8:70:fa:00
Dec 11 06:45:36 freenas kernel: bridge0: link state changed to UP
Dec 11 06:45:36 freenas kernel: igb0: promiscuous mode enabled
Dec 11 06:45:36 freenas epair0a: Ethernet address: 02:2c:d0:00:05:0a
Dec 11 06:45:36 freenas epair0b: Ethernet address: 02:2c:d0:00:06:0b
Dec 11 06:45:36 freenas kernel: epair0a: link state changed to UP
Dec 11 06:45:36 freenas kernel: epair0b: link state changed to UP
Dec 11 06:45:36 freenas kernel: igb0: link state changed to DOWN
Dec 11 06:45:36 freenas kernel: epair0a: promiscuous mode enabled
Dec 11 06:45:37 freenas epair1a: Ethernet address: 02:2c:d0:00:06:0a
Dec 11 06:45:37 freenas epair1b: Ethernet address: 02:2c:d0:00:07:0b
Dec 11 06:45:37 freenas kernel: epair1a: link state changed to UP
Dec 11 06:45:37 freenas kernel: epair1b: link state changed to UP
Dec 11 06:45:37 freenas kernel: epair1a: promiscuous mode enabled
Dec 11 06:45:37 freenas epair2a: Ethernet address: 02:2c:d0:00:07:0a
Dec 11 06:45:37 freenas epair2b: Ethernet address: 02:2c:d0:00:08:0b
Dec 11 06:45:37 freenas kernel: epair2a: link state changed to UP
Dec 11 06:45:37 freenas kernel: epair2b: link state changed to UP
Dec 11 06:45:37 freenas kernel: epair2a: promiscuous mode enabled
Dec 11 06:45:41 freenas kernel: igb0: link state changed to UP
Dec 11 06:45:51 freenas tap0: Ethernet address: 00:bd:cd:be:fc:00
Dec 11 06:45:51 freenas kernel: tap0: promiscuous mode enabled
Dec 11 06:45:53 freenas kernel: tap0: link state changed to UP
Dec 11 06:46:18 freenas epair3a: Ethernet address: 02:2c:d0:00:09:0a
Dec 11 06:46:18 freenas epair3b: Ethernet address: 02:2c:d0:00:0a:0b
Dec 11 06:46:18 freenas kernel: epair3a: link state changed to UP
Dec 11 06:46:18 freenas kernel: epair3b: link state changed to UP
Dec 11 06:46:18 freenas kernel: epair3a: changing name to 'vnet0:4'
Dec 11 06:46:19 freenas kernel: epair3b: changing name to 'epair0b'
Dec 11 06:46:19 freenas kernel: vnet0:4: promiscuous mode enabled
Dec 11 06:46:30 freenas epair4a: Ethernet address: 02:2c:d0:00:0a:0a
Dec 11 06:46:30 freenas epair4b: Ethernet address: 02:2c:d0:00:0b:0b
Dec 11 06:46:30 freenas kernel: epair4a: link state changed to UP
Dec 11 06:46:30 freenas kernel: epair4b: link state changed to UP
Dec 11 06:46:30 freenas kernel: epair4a: changing name to 'vnet0:5'
Dec 11 06:46:31 freenas kernel: epair4b: changing name to 'epair0b'
Dec 11 06:46:31 freenas kernel: vnet0:5: promiscuous mode enabled
Dec 11 06:46:56 freenas dhclient: New IP Address (igb0): 192.168.1.103
Dec 11 06:46:56 freenas dhclient: New Subnet Mask (igb0): 255.255.255.0
Dec 11 06:46:56 freenas dhclient: New Broadcast Address (igb0): 192.168.1.255
Dec 11 06:46:56 freenas dhclient: New Routers (igb0): 192.168.1.1
Dec 11 06:46:57 freenas dhclient: New Routers (igb0): 192.168.1.1
Dec 11 07:38:30 freenas ugen0.4: <Logitech USB Keyboard> at usbus0 (disconnected)
Dec 11 07:38:30 freenas ukbd1: at uhub0, port 11, addr 3 (disconnected)
Dec 11 07:38:30 freenas ukbd1: detached
Dec 11 07:38:30 freenas uhid0: at uhub0, port 11, addr 3 (disconnected)
Dec 11 07:38:30 freenas uhid0: detached
Are you trying to run SMART on the USB flash drive? If so, don't, that generally causes pain.
ric
I dont think SMART is running on the USB because USB flash drive is where Boot pool installed and SMART is not enabled on this drive, and the four HDDs (lz4) are only Enabled SMART.
netaccs
Hello to all.
Freenas 11 stable. After updating there is warning is "smartd_daemon is not running"
The system boots from flashdrive - da8. I recreate tasks for making short disk check Excluding (not selected) the flashdrive - da8.
da8 at umass-sim0 bus 0 scbus8 target 0 lun 0
da8: <JetFlash Transcend 16GB 1100> Removable Direct Access SPC-4 SCSI device
In /var/log/messages I have:
smartd[21283]: Unable to register device /dev/da8 (no Directive -d removable). Exiting.
less /usr/local/etc/smartd.conf
/dev/da0 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
-s S/(01|02|03|04|05|06|07|08|09|10|11|12)/../(1|2|3|4|5|6|7)/(00|06|12|18)\
/dev/da1 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/da2 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/da3 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/da4 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/da5 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/da6 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/da7 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/ada1 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/ada2 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/ada3 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/ada4 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/ada0 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py\
/dev/da8 -a -n never -W 0,0,0 -m root -M exec /usr/local/www/freenasUI/tools/smart_alert.py
Where is the mistake?
I think I found solution
Storage → Volumes → View Disks, select flashdrive -> Edit button -> uncheck the Enable S.M.A.R.T. checkbox
Thanks in advance !
