dasunsrule32
- Dec 5, 2012
I also opened a Jira ticket for the issue: NAS-125385
It appears the dashboard is pointing to the
My IPMI and sensors report the same CPU temperature, but SCALE reports it 20 degrees less.
Looking for this to be resolved. Not sure if it's affecting the fans as a result, since they never seem to go up much when in SCALE.
Thank you. :)
Tdie
, rather than the Tctl
while using the k10temp
driver when a Ryzen processor is in use.My IPMI and sensors report the same CPU temperature, but SCALE reports it 20 degrees less.
sensors k10temp-pci-00c3 Adapter: PCI adapter Tctl: +55.4°C Tdie: +35.4°C
Thank you. :)
