Back that NAS up
- Jun 27, 2022
I use Truenas core 13.0-U1.1. I have followed
Configuration guide for OpenVPN and IPFW so that Transmission connects ONLY via PIA VPN in a jail
TrueNAS: Add VPN Connection to a Jail
I have Ivacys Openvpn zip file, selected an OVPN file, copied/renamed .conf file with the "ca /path/ca.crt" file line, "tls-auth /path/Wdc.key 1" and the "auth-user-pass /path/pass.txt" line.
Path = real path.
I disabled all firewall settings, so when its off, internet works, I see my IP. When I try to connect, nothing happens and internet is out.
Messages file from /Var/Logs/Messages is attached. Thanks for any help!
Path = real path.
