Issues with Installing OpenVPN with NordVPN in Transmission Jail.
PontWapiti
Hello !
Couple of days ago, I decided to try to setup a NAS with Freenas as I had an unused pc that met hardware requirements.
I manage to set up with a plex media server and it works fine.
However, now I am trying to install Transmission with OpenVPN using NordVPN.
For the Transmission part, it works fine but I can't manage to make OpenVPN up and running.
I followed this tuto to try to set up Open VPN : https://www.reddit.com/r/freenas/comments/41fhz3/configuration_guide_for_openvpn_and_ipfw_so_that/
I installed OpenVPN and Nano :
pkg update
pkg install nano
pkg install openvpn
Then I created a folder for OpenVPN config:
mkdir /usr/local/etc/openvpn
cd /usr/local/etc/openvpn
I get my NordVPN config file:
wget https://downloads.nordcdn.com/configs/files/ovpn_udp/servers/nl411.nordvpn.com.udp.ovpn --no-check-certificate
I move it to my /openvpn folder and rename it openvpn.conf:
mv nl411.nordvpn.com.udp.ovpn /usr/local/etc/openvpn/openvpn.conf
And now here is the step where Im stucked because NordVPN works a bit different than PIA :
I try to get my certification and key files from Nordvpn :
wget https://downloads.nordcdn.com/configs/archives/certificates/servers.zip --no-check-certificate
And I unzip it in my NordVPN folder :
unzip servers.zip -d NordVPN/
Now the problem is Nord VPN provide a .zip with all the files for the NordVPN servers so I scroll until I find the file for my server (nl411) and copy them in my /openvpn folder :
cp nl411_nordvpn_com_ca.crt ..
cp nl411_nordvpn_com_tls.key ..
Now at this point I don't know what to do. I have 2 files one .crt file and one .key file but no .pem file for example.
I created a .txt file with my credentials :
nano pass.txt
p1234567
exam.ple.pass.word
And I edit the openvpn.conf to try to point to the correct files but when I open the openvpn.conf I can't find any line that would fit for point the right files.
I could fine one line auth-user-pass so I added the path of my .txt with the credentials :
nano openvpn.conf
auth-user-pass /usr/local/etc/openvpn/pass.txt
but I can't find anything regarding the nl411_nordvpn_com_ca.crt and nl411_nordvpn_com_tls.key files so I don't know how to say to the openvpn.conf file to use these 2 files.
I tried to launch OpenVPN so I configured rc.conf to start openvpn on startup :
nano /etc/rc.conf
openvpn_enable="YES"
openvpn_configfile="/usr/local/etc/openvpn/openvpn.conf"
then I launch openvpn:
service openvpn start
I run :
# tail /var/log/messages
May 9 00:52:35 transmission openvpn[7711]: VERIFY WARNING: depth=0, unable to get certificate CRL: CN=nl411.nordvpn.com
May 9 00:52:35 transmission openvpn[7711]: VERIFY WARNING: depth=1, unable to get certificate CRL: C=PA, O=NordVPN, CN=NordVPN CA3
May 9 00:52:35 transmission openvpn[7711]: VERIFY WARNING: depth=2, unable to get certificate CRL: C=PA, O=NordVPN, CN=NordVPN Root CA
May 9 00:52:35 transmission openvpn[7711]: VERIFY ERROR: CRL not loaded
May 9 00:52:35 transmission openvpn[7711]: OpenSSL: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
May 9 00:52:35 transmission openvpn[7711]: TLS_ERROR: BIO read tls_read_plaintext error
May 9 00:52:35 transmission openvpn[7711]: TLS Error: TLS object -> incoming plaintext read error
May 9 00:52:35 transmission openvpn[7711]: TLS Error: TLS handshake failed
May 9 00:52:35 transmission openvpn[7711]: SIGUSR1[soft,tls-error] received, process restarting
May 9 00:52:35 transmission openvpn[7711]: Restart pause, 40 second(s)
So I guess it has to deal with the certificates but as mentioned above I have no clue how to point the openvpn.conf to the righ certificates files.
If you have any idea of what could be the problems that would be great !
I hope I was clear in my explanations, if not please let me know !
Thanks a lot,
PontWapiti
scrappy
Try installing ca_root_nss package
PontWapiti
Hey Scrappy,
Thanks for your help !
Should I just run a
pkg install ca_root_nss
I look more into when I get back from work.
Thanks!
PontWapiti
scrappy
PontWapiti
Thanks again for the help Scrappy.
I installed the ca_root_nss but I keep getting the same errors regarding the VPN certificates files ("unable to get certificate").
Any more ideas ?
I can't figure out how to use properly those .crt and .key files my VPN provided me...
Cheers,
PontWapiti
silverback
I have no experience with nordvpn, but with Airvpn the keys and certs are imbedded in the .ovpn file. When I open the Airvpn .ovpn file with a text editor I can see the openvpn settings with the keys and certs. And I copy the whole text file to /openvpn.conf. Apologies if this is obvious or irrelevant.
scrappy
_Adrian_
Following
nyxtyr
Clearest guide I could find so far however I am still unable to get this working on my truenas system. Any help or other guides would be greatly appreciated.
