Visseroth
- Nov 4, 2011
So I've been fighting with trying to get SSH keys to work. Finally figured it out and got it working. Setup the same user name on each server and over ssh I am able to connect without using a password.
Perfect! Right?!?
Not so fast.
I created the RSync Tasks to push folders recursively and pull others. A rule per folder I want to push or pull as I don't want to push and pull everything but when I click on one of the rules and hit "Run Now" and "OK" and watch the logs nothing happens.
I've checked /var/logs/cron and nothing there shows it running. I've watched the messages at the bottom of the gui on both, nothing suggests it's running and I'm running PfSense for a firewall with the rule for SSH logged. So I would have seen the attempted connection, but nothing happens.
Now I do have "Validate remote Path" checked in the RSync task and when I modify the rule I can see on my firewall the SSH connection, so RSync does validate when modifying the task, but nothing happens when I tell it to run the rule now.
Anyone have any suggestions or ideas?
Perfect! Right?!?
Not so fast.
