Micheal Hodges
- Aug 23, 2013
I have been testing, successfully, rsync backups from Windows machines to our FreeNAS at the home office. Initially, we used Deltacopy client/server on the Windows machine to create a copy of the critical data, then used the FreeNAS to pull the data from that directory to the FreeNAS. We started testing without SSH and everything is fine that way, but I obviously can't use that as a secure backup plan. So, we started testing a Push from the Windows machines directly to the FreeNAS. Without SSH, everything works fine. When I use SSH, I get the infamous 'Unable to fetch directory names. rsync: read error: Connection reset by peer (104)'.
To make it more interesting, the first time I attempt a connection to the FreeNAS appliance without SSH, it works. If I then try to establish a connection via SSH, it fails. Then, if I go back to without SSH, it still fails.
Additional parameters in Deltacopy are -e "ssh -l (user) -i (keyname)"
SSH is on in FreeNAS
Rsync is on, ports are all setup.
Rsync module is configured. I've tried the username that is in Deltacopy, root, other created usernames.
I've tried different groups *(specifically daemon and wheel)
It's very strange to me. I apologize if this has been discussed already. I searched the forums and didn't see this specific problem.
If anyone is able to point me in a direction, it is much appreciated. I can post logs from our syslog appliance and from Deltacopy if needed.
Thanks
Thanks
