RSYNC extra options
namboy
Neophyte
I have an Rsync task from one 16Tb NAS to another 16TB NAS - running successfully. However, once the initial sync of all the data is done, I would like to configure the task to replace any/all the 'new' files. There will be many times that I find an 'old' image file that was processed incorrectly and I re-process it. Now, the name of the 'new' file will remain the same, but the time/date and maybe file size will change and I would like to add an Rsync option to replace such a file during a scheduled sync operation. Has anyone done such a thing? Suggestions on where to look for command line parameters to add??
fracai
Neophyte Sage
That should be the default behavior.
If any files are going to be removed on the source and you want them removed at the destination, add '--delete'.
