Hey, new guy over here :)
I built a TrueNAS Scale "server" from an old i7 Desktop with 32GB RAM, 4 4TB WD RED disks in a RaidZ1 configuration and have to say i really like TrueNAS so far :)
Anyways, i have defined a number of Rsync jobs which run just fine if i trigger them manually (initial sync took quite some time, however that is not unexpected).
My problem:
The source (Synology NAS) is running 24/7, my TrueNAS Scale machine is woken up daily at 23:50 (to give some time for it to boot up) and then there are a few jobs running that use it as a backup target (aside from the Rsync tasks, those are VM/Container snapshots from my Proxmox cluster).
So far so good, at 02:00AM, i set up a Cron job in TrueNAS to shut it down again, which also works...
Now, i noticed that i am missing new data in at least one of the Rsync tasks which are in the source NAS but aren't being synced to TrueNAS even like 2 days later.
- i can't seem to find a history of the Rsync tasks, it seems the logs are gone after a shutdown/reboot?
All Rsync Tasks show "Success", however there's no indication when the last run, last successful run has been done?
I've set up GMail OAuth emailing (works), however it seems i had to set my Email Alert Services level to "INFO" to also receive the Task notifications (seems to be working now after triggering one Rsync task again).
Anyways, does anyone have any pointers how to get down to the issue of Rsync tasks apparently not running successfully?
Ideally, i'd like the TrueNAS to shut down itself after every task for the day is done, i.e. all Rsync tasks, any scheduled resilvering is done, all SMART tests are done so i don't have to resort to the cronjob workaround like i'm doing right now...
Can that be done somehow?
Thank you in advance!
My problem:
