Ah thats realy good then its jsut a case of the user (me) beeing to stupid. I did read the manual about 5 times now and it must be the case that i just dont get it.
what i did:
create a periodic snapshot task which will snapshot main/jails/myjail ever 2h.
so lets say the first created snapshot was called 1, the one made 2h later was called 2 and so on. i got 1,2,3,...,10. now 10 is the last. now under storage->snapshots i only have 3 buttons (clone, destroy, rollback) next to the snapshot number 10. all other snapshots 1,2,...,9 have only 2 buttons (clone, destroy). i would like to rollback to state 5. as there is no button next to 5 the first thing i did was to rollback to 10 in the hope that afterwards i can roll back to 9 and so on. doing so rolls back to 10 but doesnt kill the last snapshot so this doesnt allow me to go further back in time.
i then checked (on the left side) the snapshots 5,6,7,8,9,10 and hit the rollback button next to 10. this would take me back to 10 and not 5 aswell.
for testing i was then marking snapshot 8,9,10 on the left side and delete them in the hope that this would enable me to roll back to 7. doing so created a new snapshot (lets call it A) which combines the differential information in the deleted snapshots (8,9,10) if i understood that correclty. rolling back to A brings me back to 10 effectively. so thats no gain.
so i concluded i can only roll back to the very last snapshot doing this (10). i then stopped execution of the jail and created a clone of 5. i sshed into the main system and went to the place where the jail and its clone are now mounted (main/jails/myjail next to mail/jails/myjailCLONE_OF_5). i triied to manualy delete all files in main/jails/myjail in order to replace them by the files in mail/jails/myjailCLONE_OF_5. as root i couldnt delete some of the system files (like main/jails/myjail/etc/passwd) due to "permission denied" or similar error. i was kinda exspecting that this wouldnt work and thought of the whole thing as beeing a very bad idea (i got the idea from "the manual") due to the main/jails/myjail beeing included/mounted/bound somehow by the top level operating system. so as this raw copy of clone approach was a fail i rolled back the myjail to 10 (the last snapshot i had) i order to clean up the mess.
so where is "da button" or what did i miss in the manual?
thanks for your time!
