ReplicationError("Dataset 'Raptor' does not have any matching snapshots to replicate")
Volkodav
Hi everyone! I am trying to move my Apps from one pool(Raptor) to another(Main) since I am maxed out on 8 disks on the same machine so I can remove this disk and connect another one for 8 Tb for non-critical data with no redundancy. TrueNAS-SCALE-22.12.2
Main pool is 1 x RAIDZ2 | 5 wide | 931.51 GiB
Raptor is apps only (no idea why I decided to have them separately)
Plan B is to remove my other disk (Storage) ,connect the new one instead and then copy all the data back from Storage(in USB enclosure)if it's possible to a new bigger drive.
Plan A is preferable as it saves me 3 Tb of storage instead of replacing 3TB with 8TB. I've read all the relevant threads and tried a few options in Replication Task settings to no avail. Please advise
When I check my snapshots there are over 150 of them - I created another one today - no success same error.
