SOLVED Replication tasks: lz4c missing?
zamana
Hi!
I'm strugling to get my zpool storage replicated to another server, and after read this thread, I got a look in /var/log/debug.log e finally found this in several files in /tmp:
root@freenas[/tmp]# cat repl-99191
/usr/bin/env: ‘lz4c’: No such file or directory
cannot receive: failed to read from stream
Failed to write to stdout: Broken pipe
Is that means that my remote system (a Promox with ZoL, by the way) is missing something?
Thanks.
Regards.
zamana
Hi!
Thank you for the reference.
By the way, problem solved by installing liblz4-tool, which contains the lz4c binary.
Thanks.
Regards.
