On both source and destination I have a pool, then 5 datasets. I created the datasets on the destination manually so they would not be read-only )according to previous posts). Also, testing worked fine wen I only had the main pool with one dataset, and one dataset on the destination.
Source:
etc.etc. - essentially, the snapshots for the corresponding datasets are supposed to go to their remote "datasetx_snaps." Only one of the snapshot tasks is currently creating snapshots (which IS correct because of the timing), but it's snapshots are going to the other remote datasets as well......
Why are the "store01/host_storage@auto-20190212.xxxx-xx" snapshots going not only to " store01/host_storage_snaps", but also to "store01/pacs_snaps", "store01/pp_storage_snaps" and "store01/vv_storage_snaps"
Again, it seemed to work fine when I was only working with 1 original dataset and 1 remote dataset.
Thanks, Rich
Source:
- store1/dataset1
- store1/host_storage
- store1/pacs
- store1/pp_storage
- store1/vv_storage
- store1/dataset1_snaps
- store1/host_storage_snaps
- store1/pacs_snaps
- store1/pp_storage_snaps
- store1/vv_storage_snaps
Pool/Dataset: store1/dataset1
Remote ZFS Pool/Dataset: store1/dataset1_snaps
Feb 12 16:55:02 pod-11pri /autorepl.py: [tools.autorepl:291] Checking dataset store01/host_storage Feb 12 16:55:02 pod-11pri /autorepl.py: [tools.autorepl:336] ds = host_storage_snaps/host_storage, remotefs = store01/host_storage_snaps Feb 12 16:55:03 pod-11pri /autorepl.py: [tools.autorepl:131] Sending zfs snapshot: /sbin/zfs send -V -p store01/host_storage@auto-20190212.1552-1d | /usr/local/bin/lz4c | /usr/local/bin/pipewatcher $$ | /usr/local/bin/ssh -i /data/ssh/replication -o BatchMode=yes -o StrictHostKeyChecking=yes -o ConnectTimeout=7 -p 22 10.10.179.168 "/usr/bin/env lz4c -d | /sbin/zfs receive -F -d 'store01/host_storage_snaps' && echo Succeeded" Feb 12 16:55:05 pod-11pri uwsgi: [middleware.notifier:178] Popen()ing: /bin/ps -a -x -w -w -o pid,command | /usr/bin/grep '^ *43451' Feb 12 16:55:05 pod-11pri /autorepl.py: [tools.autorepl:150] Replication result: Succeeded Feb 12 16:55:05 pod-11pri /autorepl.py: [tools.autorepl:131] Sending zfs snapshot: /sbin/zfs send -V -p -i store01/host_storage@auto-20190212.1552-1d store01/host_storage@auto-20190212.1557-1d | /usr/local/bin/lz4c | /usr/local/bin/pipewatcher $$ | /usr/local/bin/ssh -i /data/ssh/replication -o BatchMode=yes -o StrictHostKeyChecking=yes -o ConnectTimeout=7 -p 22 10.10.179.168 "/usr/bin/env lz4c -d | /sbin/zfs receive -F -d 'store01/host_storage_snaps' && echo Succeeded" Feb 12 16:55:06 pod-11pri /autorepl.py: [tools.autorepl:150] Replication result: Succeeded Feb 12 16:55:06 pod-11pri /autorepl.py: [tools.autorepl:131] Sending zfs snapshot: /sbin/zfs send -V -p -i store01/host_storage@auto-20190212.1557-1d store01/host_storage@auto-20190212.1602-1d | /usr/local/bin/lz4c | /usr/local/bin/pipewatcher $$ | /usr/local/bin/ssh -i /data/ssh/replication -o BatchMode=yes -o StrictHostKeyChecking=yes -o ConnectTimeout=7 -p 22 10.10.179.168 "/usr/bin/env lz4c -d | /sbin/zfs receive -F -d 'store01/host_storage_snaps' && echo Succeeded" Feb 12 16:55:07 pod-11pri /autorepl.py: [tools.autorepl:150] Replication result: Succeeded <trim> Feb 12 16:55:16 pod-11pri /autorepl.py: [tools.autorepl:291] Checking dataset store01/pacs Feb 12 16:55:17 pod-11pri /autorepl.py: [tools.autorepl:336] ds = pacs_snaps/pacs, remotefs = store01/pacs_snaps Feb 12 16:55:18 pod-11pri /autorepl.py: [tools.autorepl:131] Sending zfs snapshot: /sbin/zfs send -V -p store01/host_storage@auto-20190212.1552-1d | /usr/local/bin/lz4c | /usr/local/bin/pipewatcher $$ | /usr/local/bin/ssh -i /data/ssh/replication -o BatchMode=yes -o StrictHostKeyChecking=yes -o ConnectTimeout=7 -p 22 10.10.179.168 "/usr/bin/env lz4c -d | /sbin/zfs receive -F -d 'store01/pacs_snaps' && echo Succeeded" Feb 12 16:55:19 pod-11pri /autorepl.py: [tools.autorepl:150] Replication result: Succeeded Feb 12 16:55:19 pod-11pri /autorepl.py: [tools.autorepl:131] Sending zfs snapshot: /sbin/zfs send -V -p -i store01/host_storage@auto-20190212.1552-1d store01/host_storage@auto-20190212.1557-1d | /usr/local/bin/lz4c | /usr/local/bin/pipewatcher $$ | /usr/local/bin/ssh -i /data/ssh/replication -o BatchMode=yes -o StrictHostKeyChecking=yes -o ConnectTimeout=7 -p 22 10.10.179.168 "/usr/bin/env lz4c -d | /sbin/zfs receive -F -d 'store01/pacs_snaps' && echo Succeeded" Feb 12 16:55:20 pod-11pri /autorepl.py: [tools.autorepl:150] Replication result: Succeeded <-trim> Feb 12 16:55:30 pod-11pri /autorepl.py: [tools.autorepl:291] Checking dataset store01/pp_storage Feb 12 16:55:30 pod-11pri /autorepl.py: [tools.autorepl:336] ds = pix_storage_snaps/pp_storage, remotefs = store01/pp_storage_snaps Feb 12 16:55:31 pod-11pri /autorepl.py: [tools.autorepl:131] Sending zfs snapshot: /sbin/zfs send -V -p store01/host_storage@auto-20190212.1552-1d | /usr/local/bin/lz4c | /usr/local/bin/pipewatcher $$ | /usr/local/bin/ssh -i /data/ssh/replication -o BatchMode=yes -o StrictHostKeyChecking=yes -o ConnectTimeout=7 -p 22 10.10.179.168 "/usr/bin/env lz4c -d | /sbin/zfs receive -F -d 'store01/pp_storage_snaps' && echo Succeeded" Feb 12 16:55:33 pod-11pri /autorepl.py: [tools.autorepl:150] Replication result: Succeeded Feb 12 16:55:33 pod-11pri /autorepl.py: [tools.autorepl:131] Sending zfs snapshot: /sbin/zfs send -V -p -i store01/host_storage@auto-20190212.1552-1d store01/host_storage@auto-20190212.1557-1d | /usr/local/bin/lz4c | /usr/local/bin/pipewatcher $$ | /usr/local/bin/ssh -i /data/ssh/replication -o BatchMode=yes -o StrictHostKeyChecking=yes -o ConnectTimeout=7 -p 22 10.10.179.168 "/usr/bin/env lz4c -d | /sbin/zfs receive -F -d 'store01/pp_storage_snaps' && echo Succeeded" Feb 12 16:55:33 pod-11pri /autorepl.py: [tools.autorepl:150] Replication result: Succeeded Feb 12 16:55:33 pod-11pri /autorepl.py: [tools.autorepl:131] Sending zfs snapshot: /sbin/zfs send -V -p -i store01/host_storage@auto-20190212.1557-1d store01/host_storage@auto-20190212.1602-1d | /usr/local/bin/lz4c | /usr/local/bin/pipewatcher $$ | /usr/local/bin/ssh -i /data/ssh/replication -o BatchMode=yes -o StrictHostKeyChecking=yes -o ConnectTimeout=7 -p 22 10.10.179.168 "/usr/bin/env lz4c -d | /sbin/zfs receive -F -d 'store01/pp_storage_snaps' && echo Succeeded" Feb 12 16:55:34 pod-11pri /autorepl.py: [tools.autorepl:150] Replication result: Succeeded <-trim> Feb 12 16:55:43 pod-11pri /autorepl.py: [tools.autorepl:291] Checking dataset store01/v_storage Feb 12 16:55:44 pod-11pri /autorepl.py: [tools.autorepl:336] ds = vv_storage_snaps/vv_storage, remotefs = store01/vv_storage_snaps Feb 12 16:55:45 pod-11pri /autorepl.py: [tools.autorepl:131] Sending zfs snapshot: /sbin/zfs send -V -p store01/host_storage@auto-20190212.1552-1d | /usr/local/bin/lz4c | /usr/local/bin/pipewatcher $$ | /usr/local/bin/ssh -i /data/ssh/replication -o BatchMode=yes -o StrictHostKeyChecking=yes -o ConnectTimeout=7 -p 22 10.10.179.168 "/usr/bin/env lz4c -d | /sbin/zfs receive -F -d 'store01/vv_storage_snaps' && echo Succeeded" Feb 12 16:55:46 pod-11pri /autorepl.py: [tools.autorepl:150] Replication result: Succeeded Feb 12 16:55:46 pod-11pri /autorepl.py: [tools.autorepl:131] Sending zfs snapshot: /sbin/zfs send -V -p -i store01/host_storage@auto-20190212.1552-1d store01/host_storage@auto-20190212.1557-1d | /usr/local/bin/lz4c | /usr/local/bin/pipewatcher $$ | /usr/local/bin/ssh -i /data/ssh/replication -o BatchMode=yes -o StrictHostKeyChecking=yes -o ConnectTimeout=7 -p 22 10.10.179.168 "/usr/bin/env lz4c -d | /sbin/zfs receive -F -d 'store01/vv_storage_snaps' && echo Succeeded" Feb 12 16:55:47 pod-11pri /autorepl.py: [tools.autorepl:150] Replication result: Succeeded Feb 12 16:55:47 pod-11pri /autorepl.py: [tools.autorepl:131] Sending zfs snapshot: /sbin/zfs send -V -p -i store01/host_storage@auto-20190212.1557-1d store01/host_storage@auto-20190212.1602-1d | /usr/local/bin/lz4c | /usr/local/bin/pipewatcher $$ | /usr/local/bin/ssh -i /data/ssh/replication -o BatchMode=yes -o StrictHostKeyChecking=yes -o ConnectTimeout=7 -p 22 10.10.179.168 "/usr/bin/env lz4c -d | /sbin/zfs receive -F -d 'store01/vv_storage_snaps' && echo Succeeded" Feb 12 16:55:48 pod-11pri /autorepl.py: [tools.autorepl:150] Replication result: Succeeded
Thanks, Rich
