replacing the hard drive
mst
hello,
I have raidz3-0 with some faulted and removed drives. I have checked all drives are inserted. I dont have any spare so I can replaced. On one of them I can only do deteach, replace, on the other one: offline, deteach, or replace.
Should I de teach them?
Hi @mst. Can you please provide more information?
For example
Which ones exactly?
If your drives have gone bad you will need replacement drives. Even if all of your drives are currently good it is a good idea to have at least 1 backup drive ready in case of a failure.
In general it looks like your faulted drive has gone bad. If so, you will need to replace it. For the "removed" drive, double-check all cable connections to be sure something didn't work loose.
Have you received any SMART errors for your system?
Take a look at the Forum Rules and try to post as much information as it described there.
