Evan Richardson
- Dec 11, 2015
I've got an array of 24 disks, 4x 6 drive Z2 vdevs. I'm in the process of expanding the pool by replacing 2 drives at a time, one in each vdev (so as to not loose more than 2 drives of redundancy at once). The replacement is fairly fast, around 12 hours per drive (8->14TB replacements). However Even though I replace two disks at once, it seems truenas only replaces one at a time:
you can see that one disk from raidz2-0 and one disk from raidz2-1 are being replaced, started within 5 minutes of each other, but only the disk in raidz2-0 shows any activity (the activity form raidz2-1 is probably from minor usage of the array during the resilver).
A few years ago I worked for a cloud storage company and we used solaris and ZFS, and we were able to trigger multiple rebuilds at once, in parallel. Even using the CLI, it seems that this is not the case with truenas (as I'd expect to see both vdevs chugging away at replacing their disks). Is this by default, or can this behavior be changed?
Edit:
The command I ran was
due to the current Truenas 13 bug with doing it via the UI.
capacity operations bandwidth pool alloc free read write read write ------------------------------------------------ ----- ----- ----- ----- ----- ----- freenas-boot 25.0G 33.5G 0 0 0 0 ada0p2 25.0G 33.5G 0 0 0 0 ------------------------------------------------ ----- ----- ----- ----- ----- ----- sirius 109T 98.1T 2.43K 195 738M 145M raidz2-0 25.4T 18.1T 2.40K 195 731M 145M da20p2 - - 494 0 146M 0 da22p2 - - 557 0 146M 0 gptid/ceaabe76-db25-11e7-a7b6-0025905decac - - 537 0 146M 0 gptid/cf4ec403-db25-11e7-a7b6-0025905decac - - 557 0 146M 0 gptid/cffae5f2-db25-11e7-a7b6-0025905decac - - 311 0 147M 0 replacing-5 - - 0 194 0 144M gptid/d0ac6387-db25-11e7-a7b6-0025905decac - - 0 0 0 0 da4p2 - - 0 194 0 144M raidz2-1 23.6T 19.9T 7 0 1.96M 0 da21p2 - - 0 0 0 0 gptid/d97a286d-3359-11eb-b62b-90e2ba266fca - - 1 0 503K 0 gptid/d313bbc9-db25-11e7-a7b6-0025905decac - - 1 0 503K 0 da23p2 - - 1 0 503K 0 gptid/d461b238-db25-11e7-a7b6-0025905decac - - 1 0 503K 0 replacing-5 - - 0 0 0 0 gptid/d51a1be0-db25-11e7-a7b6-0025905decac - - 0 0 0 0 da6p2 - - 0 0 0 0 raidz2-2 25.2T 18.3T 3 0 1006K 0 gptid/1875a1fb-4bd6-11e8-bf99-0025905decac - - 0 0 251K 0 gptid/19249b47-4bd6-11e8-bf99-0025905decac - - 0 0 251K 0 gptid/19f4a663-4bd6-11e8-bf99-0025905decac - - 0 0 251K 0 gptid/1aad2fe0-4bd6-11e8-bf99-0025905decac - - 0 0 251K 0 gptid/1b7e61a6-4bd6-11e8-bf99-0025905decac - - 0 0 0 0 gptid/1c4fd8b3-4bd6-11e8-bf99-0025905decac - - 0 0 0 0 raidz2-5 34.7T 41.7T 15 0 3.93M 0 gptid/0edc7301-591a-11ec-99c7-90e2ba266fca - - 3 0 1006K 0 gptid/0fa198ca-591a-11ec-99c7-90e2ba266fca - - 3 0 1006K 0 gptid/1083ec3e-591a-11ec-99c7-90e2ba266fca - - 3 0 1006K 0 gptid/10cdfbc8-591a-11ec-99c7-90e2ba266fca - - 3 0 1006K 0 gptid/10f313e6-591a-11ec-99c7-90e2ba266fca - - 0 0 0 0 gptid/115b2ec3-591a-11ec-99c7-90e2ba266fca - - 0 0 0 0 logs - - - - - - gptid/85e90938-a24a-11eb-bc80-90e2ba266fca 2M 260G 0 0 0 0
Edit:
python3 replace_disk.py sirius gptid/d0ac6387-db25-11e7-a7b6-0025905decac da4
