Hi, I mostly use my freenas set-up as a media server.
First time post, so I'll try and follow the posting rules as best I can.
Situation: FreeNas GUI reported that a pool was degraded. This also coincided with the pool being too full, so I had a disk handy that I could add (which was recognized as ada4) . Via the gui, I did the following:
->Clicked on the Storage Tab
->Selected my volume (myprimarystorage)
->Clicked 'View Status' at the bottom of the page
->Selected the degraded disk (8103502573423647997)
->Clicked on the 'Replace' option at the bottom of the page
->Selected the new disk (ada4) and clicked on 'Replace Disk' to start the process.
The process seemed quite slow, so I checked around on the forums and ran the following command to find out more:
To get the following output:
So here are my questions:
1. Is it ok to shutdown the server while this process is occuring? I'd use either the command line GUI shutdown option or the web interface GUI button, not a hard power-off.
2. If I can shutdown, can I just remove the bad drive, restart the server, add the new drive to the pool and let it set itself up again (i've ordered another drive just in case)
3. Not storage related - Can I update to FreeNas 9.10 without losing the settings/zpools/jails that I have currently set up?
Additional details regarding my set-up:
Motherboard: Asus Sabertooth X58
CPU: Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz
RAM: 8GB
Storage:
zpool status -vTo get the following output:
pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0h0m with 0 errors on Thu Mar 23 03:45:58 2017 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 gptid/a26c1b01-b16d-11e4-a4a2-bcaec543a0ab ONLINE 0 0 0 errors: No known data errors pool: myprimarystorage state: DEGRADED status: One or more devices is currently being resilvered. The pool will continue to function, possibly in a degraded state. action: Wait for the resilver to complete. scan: resilver in progress since Tue Apr 18 11:39:22 2017 51.5G scanned out of 21.8T at 10.4M/s, 607h53m to go 11.0G resilvered, 0.23% done config: NAME STATE READ WRITE CKSUM myprimarystorage DEGRADED 0 0 0 raidz1-0 DEGRADED 0 0 0 gptid/fbb02c3d-b16f-11e4-9823-bcaec543a0ab ONLINE 0 0 0 replacing-1 UNAVAIL 0 0 0 8103502573423647997 UNAVAIL 0 0 0 was /dev/gptid/fccbf3d0-b16f-11e4-9823-bcaec543a0ab gptid/d8786603-23d7-11e7-a9f9-bcaec543a0ab ONLINE 0 0 0 (resilvering) gptid/fd2c3e81-b16f-11e4-9823-bcaec543a0ab ONLINE 0 0 0 gptid/fd9598aa-b16f-11e4-9823-bcaec543a0ab ONLINE 0 0 0 gptid/7deafcdf-1ed5-11e5-8938-bcaec543a0ab ONLINE 0 0 0
RAM: 8GB
Storage:
- 8GB USB Stick as the OS - FreeNAS-9.3-STABLE-201502070132
- 6xSeagate ST5000DM000 5TB HDD in RAIDZ1
