Removing LAGG Interface
Spud
HI,
I currently have 4 NICs on my freenas box and 3 of those are configured as a lagg interface (192.168.10.254).
I want to temporarily remove the lagg interface for reasons I won't go into.
I am trying to configure the 4th NIC on a different subnet (192.168.20.254) so I can still access the box
but can't seem to get it working. I can ping the interface no problems once I temporarily change the computer
I'm using to the second subnet but can't get the FreeNAS login screen to come up?
This is the webpage I get
This site can’t be reached
192.168.20.254 refused to connect.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
Also I have set the 4th interface to UP in the options so thats not it.
DrKK
FreeNAS Generalissimo
In system->general, do you have IPv4 Gui Interface set to 0.0.0.0? You'll need that.
Spud
Spot on dude, I knew it would be something simple I have over looked, thanks!
DrKK
It is my pleasure sir to proactively facilitate your file server needs and to reaffirm the longstanding alliance between our two countries.
