Hi, i've been struggling with this issue for over a month and have put well over 100 hours into fixing it. I'm quite familiar with hardware etc but not very familiar with FreeNAS/linux etc.
I setup a FreeNAS Server with
- a AMD motherboard,
- 2x , 3TB Seagate HDD's
- FreeNAS bootable USB
I no longer wanted to use the drives in FreeNAS and just removed the bootable usb thinking that I will be able to format the drives in Windwos/Linux etc.
The drives will NOT format in Disk Utility on windows, or even mount on Linux.
- I've tried to use Disk Utility to Initialise them, but I get an I/O error and they are listed as 3.9GB in capacity
- I've tried to Clean them using Disk Part, the clean function works but it doesn't change anything (they stay listed as 3.9GB)
- I"ve tried to use DBAN to nuke the drives/overwrite them with 0's, this didnt do anything either
- I've attempted to get into my motherboard raid configuration but I cant get this to work as I'm not 100% of how to do this.
- The drives no longer come up in FreeNAS
Can someone please assist me? I've got $150 drives that are totally bricked right now....
Thank you, I really appreciate any help. I am at the point of rage with this issue.
