GrahamA
 - Mar 15, 2021
Hello!
I've only recently got started with TrueNAS, having upgraded from my old Synology DS218j, however I want to use that old Synology NAS as a backup for my new TrueNAS system.
What I'm trying to do is use Duplicati to backup my important data to my DS218j, I've created a jail from the Duplicati plugin and mounted my important datasets.
I've come across enough threads like this one pointing out that child datasets must be explicitly mounted—but haven't seen any proposing a solution beyond manually mounting those datasets.
I want to backup the `iocage` dataset itself, now obviously I can't mount `iocage` within a jail because of recursion, so I've created a replication task to replicate `iocage` to another dataset called `backups`. The issue then is that there's a fair few child datasets of the iocage dataset, and manually mounting them all is a bit laborious, especially if I then add a new jail and have to go back through and edit the mount points.
So my question is simply: is there a better way to do this?
With thanks,
Graham
With thanks,
Graham
