FreeBSD jail not seeing data in ZFS child datasets
Sawtaytoes
DISCLAIMER: I created the correct user and group used in the jail and gave it the correct ACL privileges.
When mounting a dataset, it shows child datasets as folders, but in those folders, there is no data.
Do you know how I can recursively mount child datasets when mounting a parent dataset?
EDIT: I have a lot of folders, and mounting these individually and having to keep them in sync by stopping the jail and restarting it is super annoying.
Don't mount the parent, just make a fake equivalent in the jail and then mount all the children in there.
Sawtaytoes
I have to do that for every single dataset?
What happens if I actually store data in a parent dataset that has child datasets? Right now, that's not the case, but I'm curious what happens if I do.
You would have difficulty with that... it would be a poor dataset structure design for use in a jail.
Sawtaytoes
Is there an automated process to assign mountpoints all future child datasets and restart the jail after the mountpoints are added?
I have to mount something like 20 datasets right now and potentially more in the future. Remembering all the steps necessary to set this up is a huge pain. That's why it'd be way easier to mount the parent recursively.
Sawtaytoes
My thinking at this point is to take all my datasets and make them into a single one.
Subdirectories rather than datasets would be best if there's no reason you need different datasets in your use case.
