bigjay517
- Jan 14, 2015
I have a jail named autobackup which I have assigned a dataset to in order to zfs recv backups from another server.
When trying to stop my jail using iocage stop autobackup I receive the error 'RuntimeError: cannot unmount 'tank/autobackup/athena/wireguard': not currently mounted'.
Here is the complete error:
I don't understand why iocage thinks this dataset is mounted. The iocage fstab is empty.
Here is the dataset structure I am working with.
Could it be due to a property of the dataset which is maintained during the zfs recv? Which property does iocage use to determine if it should mount/unmount datasets during start/stop?
Thanks in advance for any ideas!
[root@freenas /mnt/tank/users/jason]# iocage stop autobackup * Stopping autobackup + Executing prestop OK + Stopping services OK Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_stop.py", line 187, in __stop_jail__ iocage_lib.ioc_common.checkoutput( File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_common.py", line 619, in checkoutput out = su.check_output(*args, **kwargs) File "/usr/local/lib/python3.9/subprocess.py", line 424, in check_output return run(*popenargs, stdout=PIPE, timeout=timeout, check=True, File "/usr/local/lib/python3.9/subprocess.py", line 528, in run raise CalledProcessError(retcode, process.args, subprocess.CalledProcessError: Command '['setfib', '0', 'jexec', 'ioc-autobackup', 'zfs', 'umount', 'tank/autobackup/athena/wireguard']' returned non-zero exit status 1. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/bin/iocage", line 10, in <module> sys.exit(cli()) File "/usr/local/lib/python3.9/site-packages/click/core.py", line 764, in __call__ return self.main(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/click/core.py", line 717, in main rv = self.invoke(ctx) File "/usr/local/lib/python3.9/site-packages/click/core.py", line 1137, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "/usr/local/lib/python3.9/site-packages/click/core.py", line 956, in invoke return ctx.invoke(self.callback, **ctx.params) File "/usr/local/lib/python3.9/site-packages/click/core.py", line 555, in invoke return callback(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/iocage_cli/stop.py", line 67, in cli ioc.IOCage(jail=jail, rc=rc).stop( File "/usr/local/lib/python3.9/site-packages/iocage_lib/iocage.py", line 1843, in stop ioc_stop.IOCStop( File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_stop.py", line 62, in __init__ raise e File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_stop.py", line 59, in __init__ self.__stop_jail__() File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_stop.py", line 200, in __stop_jail__ raise RuntimeError( RuntimeError: cannot unmount 'tank/autobackup/athena/wireguard': not currently mounted
[root@freenas /mnt/tank/users/jason]# iocage fstab autobackup -l +-------+-------------+ | INDEX | FSTAB ENTRY | +=======+=============+ +-------+-------------+
Datasets on Server Sending athena/caddy /pihole /plex /wireguard Datasets on TrueNAS after zfs recv tank/autobackup/athena/caddy /pihole /plex /wireguard
